Old 01-19-2008, 10:44 AM   #101
jasonb72
PorterBuilt Man Crush
Re: Porterbuilt 69
What do you need, and I will supply!!!!!
The 72 will live again
jasonb72 is offline   Reply With Quote
Old 01-19-2008, 10:57 AM   #102
onetonk5
Cereal Killer
onetonk5's Avatar
Re: Porterbuilt 69
How do you get anything done with all these folks nose's up your butt?
If I dont do it....somebody else will.
onetonk5 is offline   Reply With Quote
Old 01-19-2008, 11:08 AM   #103
Blaz-air
Digital Dude
Blaz-air's Avatar
Re: Porterbuilt 69
Dude, have you seen his butt?
Carter Hickman
www.hokdigitalpaintbooth.com
carterhickmandesigns.com
Blaz-air is offline   Reply With Quote
Old 01-19-2008, 12:33 PM   #104
n2billet
Village Idiot....
n2billet's Avatar
Re: Porterbuilt 69
[QUOTE=porterbuilt;2535005]I still can't feel the tip of my left ring finger!
This has nothing to do with you not being able to carry your end of the trans! It has everything to do with that silver band on that finger!
http://www.hubgarage.com/mygarage/n2billet
-67 SWB Custom Porterbuilt Front and rear 20/22's Hazel Sold
-71 StepSide Porterbuilt Stage 2 with 20/22's Stella Mae Sold
n2billet is offline   Reply With Quote
Old 01-19-2008, 01:43 PM   #105
PBFAB.COM
PBFAB.COM's Avatar
Re: Porterbuilt 69
Some days I too wonder!
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 01-19-2008, 01:47 PM   #106
RunninLo
3DrDwn--the 'burb not the band
RunninLo's Avatar
Re: Porterbuilt 69
Originally Posted by Rokcrln View Post
Josh I am sure he will take an early payment just to keep you off that bike! Nate is just that kind of a stand up guy
Kevin
LFD Inc.
I could only be so lucky.... I've had an order with CC # supplied with another vender for over 4 months and still no suspension. It's sad I could build something myself if I had the time but I never thought I'd have trouble spending the money. I need a rear set-up that goes in as quick and smooth as the DM did in the front so I will continue to wait. Did just get my new frame in for the racebike and a few extra parts should be at the dealer next week so spending should slow down on it soon. Of course I do need to spend some at performance machine getting new brakes for my knucklehead and that will hurt some. Always something....
Slo and Lo that is the tempo.
'72 burb build page here:
http://67-72chevytrucks.com/vboard/s...d.php?t=259256
'89 GMC Dually crew build page coming soon.
88 4x4 crew DD
duallys past/present pics here:
http://67-72chevytrucks.com/vboard/s...46#post4001246
89 1 ton Dually rear flip kit install here:
http://67-72chevytrucks.com/vboard/s...d.php?t=354327
RunninLo is offline   Reply With Quote
Old 01-19-2008, 01:47 PM   #107
PBFAB.COM
PBFAB.COM's Avatar
Re: Porterbuilt 69
Well... since it felt so good yesterday I had to get some more today! It's been so long that I almost had forgotten how much fun this stuff can be!
I cleaned up a couple hours early and busted out the driver's side fender. I shaved the marker light and went ahead and stripped the exterior.... mocked it up and stared at it for a while! I also had to unbolt the rear wheels and set it down on the drums so the rake wasn't so bad. Still not close to ride height in the rear... but will have to do for now!
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 01-19-2008, 01:48 PM   #108
PBFAB.COM
PBFAB.COM's Avatar
Re: Porterbuilt 69
two more...
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 01-19-2008, 02:00 PM   #109
FnLow69
FnLow69's Avatar
Re: Porterbuilt 69
looks sweet, what do you use to get the fender that smooth?
FnLow69 is offline   Reply With Quote
Old 01-19-2008, 02:03 PM   #110
Rokcrln
Rokcrln's Avatar
Re: Porterbuilt 69
So Nate when is this rear suspension going to be available. I am sure their are alot of us waiting to order? So what morot are you going with a 5.3 or 6.0L and what HP are you thinking it will put out after the two hair driers are fired up?
Nice job on the marker removal. It takes me way to long to do a seamless job like that but it is getting faster by the day.
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 01-19-2008, 02:14 PM   #111
PBFAB.COM
PBFAB.COM's Avatar
Re: Porterbuilt 69
I made the marker fillers by taking a sheet of 18ga. that was roughly 12"x12" and rolled it on my english wheel until the contour matched the fender as close as I could get it (didn't take too long, the radius is subtle). I then cut out the filler piece (just big enough to remove the stamped marker recess hole), laid it on the fender over the marker light recess; traced my filler piece, cut-out the marked hole and marker recess, then made sure it all fit tight, fired up the TIG welder and stitched it in, allowing it to cool and using the hammer and dolly to keep it straight. Then I stripped the whole fender with a 36 grit DA, 60 grit DA, and finally an 80 grit DA.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 01-19-2008, 02:17 PM   #112
PBFAB.COM
PBFAB.COM's Avatar
Re: Porterbuilt 69
Kevin
LFD Inc.
It's a 5.7 out of a 02 SS Camaro. Came with headers, ported heads, under-drive pulleys, SPEC racing clutch, and who knows what internals... looked like the guy spent a bunch of money and then wrecked his car with all that extra power?
I will be trying to keep it at around 600 hp. It will be capable of much more, but I would have to upgrade everything to be able to use that kind of power.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 01-19-2008, 02:22 PM   #113
FnLow69
FnLow69's Avatar
Re: Porterbuilt 69
600hp that sound a little conservative with twin turbos.
Old 01-19-2008, 02:28 PM   #114
PBFAB.COM
PBFAB.COM's Avatar
Re: Porterbuilt 69
Very conservative... with the proper tuning and internal upgrades it could make over 1000hp. I just don't want to spend the extra coin and or brake stuff!!! 600hp is plenty for me!
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 01-19-2008, 10:43 PM   #115
jkade
jkade's Avatar
Re: Porterbuilt 69
Originally Posted by porterbuilt View Post
two more...
Are those a set of saltsters I see in the back ground??
jkade is offline   Reply With Quote
Old 01-20-2008, 12:23 AM   #116
PBFAB.COM
PBFAB.COM's Avatar
Re: Porterbuilt 69
They're Boyd Cotterpin "ACE" wheels... they are BAD ACE!!!!!
I thought they looked cool in pics, but in person... WOW!
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 01-20-2008, 04:33 AM   #117
abadsvt
abadsvt's Avatar
Re: Porterbuilt 69
Hey Nate how bout some pics of the conv. belair? Is that the one you were wanting to do the c5 drivetrain too?
Josh
(Project truck)
1970 C10 under complete transformation
My current build thread http://67-72chevytrucks.com/vboard/s...d.php?t=212871
Other project: C5 corvette swap into 70 c10 http://67-72chevytrucks.com/vboard/s...=1#post2413517 On Hold
abadsvt is offline   Reply With Quote
Old 01-20-2008, 06:45 AM   #118
jugernot
Life, Be In It.....
jugernot's Avatar
Re: Porterbuilt 69
Kevin
LFD Inc.
What Rear Suspension. Is there a link to it, I need some pics......please.
Project Name: LEMON DROP. Reconstruction started "December 2000". Projected completion date "Who knows"
http://67-72chevytrucks.com/vboard/s...d.php?t=200082
jugernot is offline   Reply With Quote
Old 01-20-2008, 06:52 AM   #119
Rokcrln
Rokcrln's Avatar
Re: Porterbuilt 69
No you don't your frame is done, powder coated and finished! Now get back to work
Kevin
LFD Inc.
Old 01-20-2008, 07:34 AM   #120
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: Porterbuilt 69
They're Boyd Cotterpin "ACE" wheels... they are BAD ACE!!!!!!
Cool Wheel!
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 01-20-2008, 08:22 AM   #121
Rokcrln
Rokcrln's Avatar
Re: Porterbuilt 69
I missed that the first time around
Kevin
LFD Inc.
Old 01-20-2008, 10:34 AM   #122
babyblueoval
babyblueoval's Avatar
Re: Porterbuilt 69
Nate,
I see you're running the "Porterbuilt Signature" Wheels on the truck.
Jim
'71 Blazer-Porterbuilt Dropmember C4/LS1/6L80E
'57 VW beetle - Oct. 2006 Hot VW's pg. 87 - 350hp intercooled, turbocharged, EFI 2.3liter and 5spd in the works
'87 BMW 325i - daily driver
babyblueoval is offline   Reply With Quote
Old 01-20-2008, 11:06 AM   #123
PBFAB.COM
PBFAB.COM's Avatar
Re: Porterbuilt 69
Originally Posted by N2TRUX View Post
Cool Wheel!
The image makes the center look like it has a sheen to it or maybe a brushed finish...at least that's what I thought. Actually, the center is a rough cast looking piece... pretty darn cool.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 01-20-2008, 11:13 AM   #124
atp
Re: Porterbuilt 69
Looks great! - any luck on the swaybar?
I am getting closer on mine. Ran fuel lines today. Curious if you have any close up on the motor mounts?
atp is offline   Reply With Quote
Old 01-20-2008, 01:43 PM   #125
jugernot
Life, Be In It.....
jugernot's Avatar
Re: Porterbuilt 69
Kevin
LFD Inc.
I know I know. There are ton of other things I can use the money for to finish the project. I actually just bought some Second Skin Damplifier sound deadening mat and a blazer gas filler tube for this mod.
http://67-72chevytrucks.com/vboard/s...=1#post2489088
