Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Info Center > FAQ Truck Tech > Engine and Drivetrain
Old 10-08-2007, 11:49 AM   #101
Ace in the hole
Re: another cheap electric fan build!
Originally Posted by DennyB View Post
We would love to have the dimensions and location for the notch in the bottom
Here is what he emailed me-
heres pic,s of the schroud mod. slot hole 1/4" wide, 2 1/2" from back ( engine side ) of schroud. slot is 2 1/2" long and then make a slot on each end of 1/4" slot 1/2" long by 1/8" wide. if you have any questions please call me i,ll be glad to help ya.
bob
1970 K20, 350--- SOLD
05 silverado extended cab short box- duramax
Jeep wrangler unlimited
Ace in the hole is offline
Old 10-08-2007, 04:29 PM   #102
BCOWANWHEELS
center up hole from side to side in schroud. call me if ya,ll have any questions i,ll be glad to help anybody out.
bob
1 423 384 8938
I BELIEVE IN JOHN 3:16
BCOWANWHEELS is offline
Old 10-08-2007, 04:40 PM   #103
cysko9
MI '69
cysko9's Avatar
Originally Posted by Olden Days View Post
I ordered one of those (without measuring first) for my 70 big block truck. Just so you know, if you have a big block with a "long pump" setup there is not enough clearance.
Not enough clearance eh? that sucks... was this with a 4 core and stock shroud? I've got one of those serpentine kits on my BB, you think that might help with space??
1967 Chevy (Project Frankenstein)
1973 K5 Blazer
cysko9 is offline
Old 10-08-2007, 07:41 PM   #104
Brad
Out of the carpool lane.
Brad's Avatar
Just held a shroud up to my L6 today- it ain't gonna work.
Any guesses as to why?
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red
1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!)
2000 Honda VFR in the faster yellow!
2008 Husqvarna TE-610
1967 C-10 SWB 'Six Appeal'-Gone but not forgotten...
Brad is offline
Old 10-08-2007, 07:51 PM   #105
Too Long eh?
Brad
Try a dual fan shroud setup from a 3.8L Windstar Van. They supposedly pull alot of air, and the shroud lyes alot flatter than this set up. It's what I was going to use before I saw this thread
Palf70Step is offline
Old 10-08-2007, 08:55 PM   #106
dan468
dan468's Avatar
what kind of serpentine kit do you use?
68 C-10
Build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=414699
dan468 is offline
Old 10-08-2007, 09:17 PM   #107
Olden Days
Living In The Past
Olden Days's Avatar
Yes I am using 4 core radiator and stock BB shroud. Sorry , dont know what the clearance difference (if any) would be on the serpintine. Mine with long pump measures 3 1/8 from water pump shaft to the rad. the elec fan is 3". just cant squeak it in there and be safe. I will probably go with a dual stup like Palf70 showed.
Olden Days is offline
Old 10-08-2007, 09:39 PM   #108
BCOWANWHEELS
Brad Mine Worked Just Fine With My 250 I-6
Old 10-08-2007, 10:25 PM   #109
cysko9
MI '69
cysko9's Avatar
march performance serp kit.
is there any info on the windstar mod??
1973 K5 Blazer
cysko9 is offline
Old 10-09-2007, 12:56 AM   #110
Brad
Brad's Avatar
Hmmmmmm, interesting. I didn't unbolt anything but just held up the smallblock shroud and a late model Camaro fan and it looked like it would be too close. I figured the Jeep fan wouldn't be too different and didn't want to spend the $$$ only to have it not work.
Could you show good pics of it installed in your rig?
Brad is offline
Old 10-09-2007, 08:43 AM   #111
DennyB
Led Sled! Discs R 4 ME!
DennyB's Avatar
Is anyone running this with AC?
I'm still not cooling the way it should and I'm beginning to think I have a radiator issue. When its only about 75-80* it gets up to about 200* in traffic.
Thats with a lead connected to the ac unit so the fan runs constantly when the ac is on (gotta have It flowing through the condenser to keep the high side pressure in check). I think I'll run a smaller fan on the condenser to run when the ac is on.
Also with the ac on high and the fan running mine drops to 12V at idle. What alternator are you all running. Mine is new but factory spec. I think 60-70 amp. Anyone know of a high amp unit that fits? part number?
Ok, now some positive info.
I decided to go with a adjustable thermostat. They were nearly $70 at my local parts store. Found one at Autozone for $35 and its a nice unit and easy to wire and includes the ac override which can be used for the ac or hooked to a toggle for a manual over ride. TorqFlo part# 733647. This is the radiator probe type.
Also here is a site with some good relay wiring schematics.
http://www.aaroncake.net/rx-7/efaninstall.htm
DennyB is offline
