Old 02-11-2011, 02:29 PM   #101
cable666guy
cable666guy's Avatar
Re: A New 68 Build Thread
WOW! I sure wish you were closer to Philly than Pittsburgh, I'd love to see your truck in person!! Keep up the good work!!
cable666guy is offline   Reply With Quote
Old 02-11-2011, 09:45 PM   #102
ccracin
CCTek
ccracin's Avatar
Thanks very much for the compliments.
I took a minute and plotted the numbers. Not Bad. IMHO
Chad
68 swb Project
http://67-72chevytrucks.com/vboard/s...d.php?t=262840
72 swb Project SOLD
http://67-72chevytrucks.com/vboard/s...=1#post3993641
THANKS TO: Hermance Design (www.hermancedesign.com), Paradise Road Rod & Custom, Harry Opfer Welding, Tri-State Machine, Wegner Automotive Research, Nsane Hotrodz (www.nsanehotrodz.com), Clayton Machine Works, CCTek (http://www.candctek.com)
ccracin is offline   Reply With Quote
Old 02-18-2011, 01:17 PM   #103
ccracin
CCTek
ccracin's Avatar
Look what arrived today!
Great way to finish a tough week!
Chad
68 swb Project
72 swb Project SOLD
Old 02-18-2011, 03:01 PM   #104
67cheby
67cheby
67cheby's Avatar
WOW, WOW again
67cheby is offline   Reply With Quote
Old 02-18-2011, 03:10 PM   #105
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Very nice..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 02-22-2011, 11:06 PM   #106
ccracin
CCTek
ccracin's Avatar
A little more work on the Bear Claw latches. Getting the pins put in the doors. A lot of work for something simple! Enjoy.
A bit more touch up welding and grinding and we'll be good to go! Thanks for looking!
Chad
68 swb Project
72 swb Project SOLD
Old 02-22-2011, 11:07 PM   #107
VA72C10
VA72C10
VA72C10's Avatar
Looks good. And will be a great latch!
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 03-18-2011, 11:46 PM   #108
ccracin
CCTek
ccracin's Avatar
Another Project Done, Almost!
We have been working on getting seats mounted so that we can get to work mounting the brake pedal, steering column, and a/c unit. Since this is a truck and there is very, very limited space to put things, we decided to try and maximize the room we do have. We decided that under the seats was some space that could be used for things like the EZ EFI and EZ TCU computers as well as maybe the audio amplifier. There are so many electronic items we need all the space we can get. However, I was not about to have to take the seats in and out to get to this stuff. The Corbeau seats we are using have an adjustable back so here is what we came up with.
I think it's going to work out just fine. I just need to add some braces as there is a very slight amount of lateral movement in the front of the seat where the bear claws latch. I will also add a spring cylinder to hold the seat up and a linkage to trip both latches at once.
Pay no attention to that weld seam in the floor above. We didn't do that and it will get fixed!
Here's the real payoff!
This may not seem like much, but this is the first time he has been able to do this since the truck got torn down.
All comments are welcome as always!
Chad
68 swb Project
72 swb Project SOLD
Old 03-18-2011, 11:51 PM   #109
VA72C10
VA72C10
VA72C10's Avatar
very nice!!!! I love that idea and the bear claw latches are an excellent choice. The seats sit perfect under the window too!
Old 03-19-2011, 12:02 AM   #110
ccracin
CCTek
ccracin's Avatar
Thanks man, I was just posting in your thread. Looking good. We put alot of time into figuring it all out. I hate seeing seats in the back window. just one of my little issues.
Later,
Chad
68 swb Project
72 swb Project SOLD
Old 03-19-2011, 08:23 AM   #111
sourkraut
sourkraut's Avatar
just found your build. very nice work, keep it going!
"The way it is" truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=359200
sourkraut is offline   Reply With Quote
Old 03-19-2011, 09:16 AM   #112
67cheby
67cheby
67cheby's Avatar
very COOL progress
Old 03-21-2011, 01:59 PM   #113
mac72
Man those seats are cool.Do you have a part no. on them?
mac72 is offline   Reply With Quote
Old 03-22-2011, 03:09 AM   #114
BlackZ28
Sweet build, cant wait to see more!
BlackZ28 is offline   Reply With Quote
Old 03-26-2011, 07:57 PM   #115
ccracin
CCTek
ccracin's Avatar
Thanks. You can find them here:
http://www.corbeau.com/products/recl...ats/sportseat/
Chad
68 swb Project
72 swb Project SOLD
Old 03-26-2011, 08:43 PM   #116
DALTON
69 C-10 Short Fleet
DALTON's Avatar
Subscribed!
Tony Dalton
DALTON is offline   Reply With Quote
Old 03-28-2011, 08:05 AM   #117
mac72
Originally Posted by ccracin View Post
Very nice! thanks Mac
Old 04-09-2011, 09:30 PM   #118
ccracin
CCTek
ccracin's Avatar
A New Milestone!
Probably the first of many times, but the new motivation was set between the frame rails today. What a sense of satisfaction! We had to build a bracket to lift with. With the tranny and acc. drive installed, the regular load leveler would not work. Check it!
The lift bracket.
Now that we have it in the chassis, we will be measuring for the drive shaft and the new firewall. We have also decided to change the motor mounts on the chassis. We have a few ideas as to hiding things in the engine bay. This will require changing the mounts. Stay tuned, more to come on that. Now time to relax. Enjoy.
Chad
68 swb Project
72 swb Project SOLD
Old 04-11-2011, 09:54 AM   #119
67cheby
67cheby
67cheby's Avatar
that is SICK....love the motor
Old 04-13-2011, 08:08 PM   #120
FRENCHBLUE72
PROJECT 7DEUCE
That motor is titties love the front drive set-up..
MEMBER #6377
Project "7DEUCE"
Old 07-30-2011, 03:52 PM   #121
ccracin
CCTek
ccracin's Avatar
Finally More Progress
We are back from Columbus and back at it. My daughters have started cheerleading practice, so Dad gets to hit the garage on cheer nights! The fuel cell is now starting to come together. Thanks to help from Carl C and his Vaporworx technology I think we will have a solid fuel system. The tank material is 16ga 304SS. I modeled it in solidworks and had the material sheared and broke. Now I am doing my best to warp the h..l out of it trying to weld it together. Here is where I am so far.
Comments good and bad are always welcome!
Chad
68 swb Project
72 swb Project SOLD
Old 07-30-2011, 09:59 PM   #122
VA72C10
VA72C10
VA72C10's Avatar
nice work! Looks good from here!!!
Old 07-31-2011, 09:07 AM   #123
bcutt
bcutt's Avatar
Man I love your build!!
"Some of my finest hours have been spent on my back veranda, smoking hemp and observing as far as my eye can see."
- Thomas Jefferson
72 C10 SWB "Work in Progress"
bcutt is offline   Reply With Quote
Old 08-25-2011, 10:54 PM   #124
ccracin
CCTek
ccracin's Avatar
A bit more progress on the cell.
I like how it is coming together. It could be better, but not bad for learning to TIG as I go. Should be plenty strong and not leak. A little grinding and sanding and it will be good. Enjoy!
Whatcha think?
Chad
68 swb Project
72 swb Project SOLD
Old 08-25-2011, 11:24 PM   #125
eagleuh1
eagleuh1's Avatar
Serious fab skills. Looks real good. Your going to use a 2010 Camaro fuel pump assembly? Jim
eagleuh1 is offline   Reply With Quote
