Old 04-09-2008, 03:00 PM   #101
c10addict
c10addict's Avatar
Re: project INCREDIBLE HULK
Wow... Coming along good! All the best parts going on it! Looks Killer!
68 C10 Shorty TPI,Bagged, and all the good stuff. Classic trucks feature June 06, On the cover of Jegs Christmas Catalog 08
67 C10 Shorty Shop truck project Bagged and Z'd under destruction and getting nowhere fast.
64 C10 Shop Truck/Daily driver, Bagged, Dropmember, SOLD!!!! Gone but not forgotten..
54 GMC under the knife getting a S10 chassis swap and bagged. See my build thread...
07 GMC Sierra 5/7 drop, 22's and 24's Air ride on my mind..
http://67-72chevytrucks.com/vboard/s...d.php?t=339340
See pics of my trucks in my profile
c10addict is offline   Reply With Quote
Old 04-10-2008, 01:49 AM   #102
68 short step
Originally Posted by Ackattack View Post
what shocks are those? I've been thinking of some QA1 shocks for mine, but haven't really looked/measured enough to know which ones to get. Did the frame bracket come with the kit too?
they are double adjustable QA1, yes the upper shock mount brackets came with the kit.
68 short step is offline   Reply With Quote
Old 04-12-2008, 06:40 AM   #103
killer71
killer71's Avatar
hey dude...you got the hulk lookin good...Will you be painting the frame or will you guys powder coat it???
R.I.P.
Killer 71
10/26/07
killer71 is offline   Reply With Quote
Old 04-13-2008, 06:18 AM   #104
68 short step
killer it'll be painted..
got some motor mount ls1 adaptor plates, so i was able to mock-up the mock-up engine... and with this truck i set the motor 1" further back for 2 reasons 1) is cause these control arms are beefier then stock, and i fear the headers will interfer with them on the dr. side. and 2) cause we're gonna run a f-body oil pan for ground clearance....also got the center x-member drilled out and the trailing arms out, cause all this is gonna get replaced with new ECE stuff.. here are the pics
Old 04-14-2008, 04:24 AM   #105
Hart_Rod
Hart_Rod's Avatar
If you use these headers, I don't think you'll have a problem with clearance, .
R/
Hart_Rod is offline   Reply With Quote
Old 04-14-2008, 06:42 AM   #106
68 short step
hart-rod ive seen them headers a thousand times from when you posted them, quit flaunting those awsome looking headers, you lucky ginny pig you
Old 04-14-2008, 05:08 PM   #107
71Hulk
Originally Posted by GRIMSS View Post
Some nice look'n work your doing there. Do you have any idea of what those two greens are called? That's kind of the look i'm wanting to have.
GRIMSS: don't have a clue but you can buy the bed and all you'll have to do is match it!
71Hulk is offline   Reply With Quote
Old 04-14-2008, 08:53 PM   #108
Hart_Rod
Hart_Rod's Avatar
I wasn't trying to brag , I'm just excited that after 2 years of inquiries, we, (LS1 modders, ), finally have an awesome looking set of headers to complete are LS builds. BTW, did 71HULK finally pick up a motor worthy of the rest of the truck?
Old 04-14-2008, 10:57 PM   #109
68 short step
i know, im just giving ya a hard time, and im glad someone finally came out with such a product....him and i are discussing it now, and have been...he only wants the best of the best in this one, im all for it tho
Old 04-19-2008, 03:12 AM   #110
68 short step
alright, got most all the suspension mocked-up...the rear also has the hidden receiver hitch set-up....fully dumped the lience plate 'box' is about 4.5" from the ground.....looks pretty cool IMO... with it being that low the relocation bracket from the ECE panhard bar kit wont work... it locates the panhard bar almost touching the bottom of the frame (second to last pic).. so im gonna make a bracket to locate it to the actual trailing arm, lowering the attaching point to a better position for a truck being lowered this much (last pic).....
Old 04-19-2008, 03:19 AM   #111
Hart_Rod
Hart_Rod's Avatar
Dude! I didn't know you were building a slammed dually!!!!
Old 04-19-2008, 03:27 AM   #112
gringoloco
A guy with a truck
gringoloco's Avatar
Lookin' good! A set of 1.5" or 2" lowering blocks would fix your panhard interference problem and allow for more air in the bags at ride height. This will give a better ride and help have your bags at the correct installed height- this will be especially true if you are running drop spindles up front.
How did you get that compressor to fit so nicely?
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 04-19-2008, 04:06 AM   #113
68 short step
where would i get a set of 1.5 blocks w/ loner U bolts? the truck was set-up for a 7" (bag) ride height....
you talkin bout the A/C compressor or the air system compressors?
Old 04-19-2008, 04:37 AM   #114
71Hulk
Pay Attention Please!
Old 04-19-2008, 07:57 AM   #115
Hart_Rod
Hart_Rod's Avatar
Agree with GringoLoco. Thats what I did to mine. I got the blocks and ubolts from CPP. This is the best pics I have of the setup.
Old 04-24-2008, 01:53 AM   #116
gringoloco
A guy with a truck
gringoloco's Avatar
CPP for the blocks w/ bolts. I think the kit is $60-70.
You have a little leeway in how tall the bag can be, but not much. Most (2600lb)bags are designed to be installed at ride height at 6" tall. You can waiver either way by a 1/2" or so, but outside of that they will not ride as well. You can use the blocks to keep the bags at 6" installed, but ride 2" lower than you would without them. Think of the bag as a non-adjustable coil spring when at ride height. The pressure will vary based on load, but the overall height should be 6". Clear as mud?
I was asking about the A/C compressor. It seems to fit very well. Is it smaller than the usual truck compressor?
-Chris
Old 04-24-2008, 05:23 AM   #117
68 short step
the a/c compressor and mounting bracket are for a truck/suv....dunno why you have any problems with mounting it there... ive done a couple of these swaps and they all tuck right there in the frame rail nicely...
Old 05-05-2008, 04:46 AM   #118
68 short step
getting some more work done....got the trans cooler installed, drilled and located the trans x-member, mounted the rear hight sesnors, and a little more cab body work.... the lwr part of the dr. side cowl was roted out, so it was cut out and a new peice made......
also the truck oil pan was traded out for a f-body pan....now the pan is bout 1.5 inches above the front x-member, just how we wanted it...
Old 05-05-2008, 04:47 AM   #119
68 short step
Old 05-05-2008, 05:07 AM   #120
68 short step
and now for the heart of the beast......
this is a 6.2L with a 6L80E trans... for those who arnt familur with these GEN4 engines, this is a big bad mamajama, it has 403 HP and 418torque stock with varitable valve timeing (VVT)... the 6L80E trans is a automatic 6 speed with 2 overdrives.... but this isnt gonna be a stock engine when we're done with it, so more HP will be gained
here is some pics of the engine and trans....also included is the 6l80e compaired to a 4l60e trans...
Old 05-05-2008, 05:08 AM   #121
68 short step
Old 05-05-2008, 03:10 PM   #122
71Hulk
I agree it is a beast...that thing is fat n heavy! Looks like you've been busy since i dropped it off! Can't wait to see the mock up of this big piece of meat!
Old 05-06-2008, 06:20 AM   #123
tk-mpl
tk-mpl's Avatar
Re: project INCREDIBLE HULK 6.2L with 6L80E
What did you get the 6.2L come out of. Can you spill the beans on the mods yet.... Is it DOD??
tk-mpl is offline   Reply With Quote
Old 05-06-2008, 07:05 AM   #124
68 short step
6.2 out of a denali.....mods, cant be spilled yet, but you'll see....the DOD, so to speak, is what they call variable valve technoligy (VVT) what this does is adjust the cam by advancing/retarding it while driveing...it does this on both the intake and exhaust...this, in effect, will give the engine good MPG, torque, and awsome driveability.
(in words of shaun @ mastmotorsports)
The VVT phases the cam across the RPM range to effectively improve the volumetric efficiency of the engine. Think of it as adjusting the installed centerline of the cam for optimum performance while the engine is operating. It allows the engine to produce better torque for a given RPM that would not normally be possible in a fixed cam application
Old 05-06-2008, 08:15 PM   #125
killer71
killer71's Avatar
So are we to assume that dod and vvt mean the samething or are they 2different terms?
R.I.P.
Killer 71
10/26/07
