Old 04-06-2009, 05:05 PM   #101
HotRodYJ
HotRodYJ's Avatar
Re: Cross Member Drop?
Originally Posted by meansting04 View Post
This is an great build, you have a lot of talent and skill. I will follow this one. Keep up the good work.
Thanks for the compliment. Not sure about the talent and skill part of it, I just like to do things a little different and think outside the box.
66 Chevy Stepside tandem project
My junk: http://67-72chevytrucks.com/vboard/s...d.php?t=480902
HotRodYJ is offline   Reply With Quote
Old 04-14-2009, 09:59 PM   #102
74 C-30
Dually Pride
74 C-30's Avatar
wow nice progress! looks awesome, cant definatrly tell theres alot of time into that!
btw USA6x6 is no longer.....
If I have to explain, you wouldn't understand.
'74 Chevy C-30 350/4 speed/dually
'94 Ford Ranger
74 C-30 is offline   Reply With Quote
Old 04-14-2009, 10:17 PM   #103
joe231
joe231's Avatar
WOW!!!
That thing is hella COOL!!
Nice work!!
CHEVY ONLY
Old 04-15-2009, 12:13 PM   #104
Primer70
Superbad
Primer70's Avatar
Originally Posted by HotRodYJ View Post
The only advantage to the NP203 would be the center diff. and trying to find a divorced NP203 can be hard to do. I've never seen one myself. I like the NP205 better because it is a much stronger gear driven case. A simple shifter will take care of any issue of trying to drive both axles on dry pavement allowing you to shift from 2 wd to 4 hi. You cannot run this set-up in 4lo with the case turned backwards as I have done. The front axle would try to turn twice as fast as the rear axle if you did since the front axle is driven by what is normally the input from the transmission before the gear reduction inside the t-case. I seriousley don't think I'll have any issue. Check out USA6x6 sometime. The set-up they offer for about $3000 uses a gear driven set-up off of the front axle to give drive to the second axle and no possible way to stop the engagement of the second axle. Apparently it works just fine.
Yeah, I forgot about the differences is output speeds with turning the t-case around. I haven't seen a divorced 203 in person, I've seen pictures of them & adds for them being sold on Craigslist.
USA6x6 went outta business? I read lots of bad stuff about there customer service online, but you can hear that for just about any company online.
Primer70 is offline   Reply With Quote
Old 04-15-2009, 12:55 PM   #105
protrash64
Resistance is Futile
protrash64's Avatar
I havent checked in on this for awhile.....looks really cool with the frame altogether. Nice work; looks like a lot of figuring this out.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 04-15-2009, 02:17 PM   #106
c10addict
c10addict's Avatar
Subscribed... Points to you my friend for creativity and some nice fab work...
68 C10 Shorty TPI,Bagged, and all the good stuff. Classic trucks feature June 06, On the cover of Jegs Christmas Catalog 08
67 C10 Shorty Shop truck project Bagged and Z'd under destruction and getting nowhere fast.
64 C10 Shop Truck/Daily driver, Bagged, Dropmember, SOLD!!!! Gone but not forgotten..
54 GMC under the knife getting a S10 chassis swap and bagged. See my build thread...
07 GMC Sierra 5/7 drop, 22's and 24's Air ride on my mind..
http://67-72chevytrucks.com/vboard/s...d.php?t=339340
See pics of my trucks in my profile
c10addict is offline   Reply With Quote
Old 04-19-2009, 03:20 PM   #107
HotRodYJ
HotRodYJ's Avatar
Been working a few nights on a little more low buck old school flare for the truck. These valve covers are the old school finned aluminum that I really wanted. My Dad ran this particular set on his 37 Pontiac street rod for the past 30 years. These covers were old enough even back then that he bead blasted them and clear coated them before putting them in that car. I media blasted them again last week to get that 30 year old clear coat off of them and started polishing. Polishing is free it just takes time. I'm really happy with how these are turning out, they actually look better in person. Now just one more to go.
Before and after....
Old 04-19-2009, 04:42 PM   #108
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Cant wait to see her done..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 04-28-2009, 08:27 AM   #109
OLDIRON69
subscribed!
05 2500HD 6.0 excab
69 LWB-Gone but not forgotten!
68 Dodge Charger 383/727
69 Dodge Charger-440/4spd
OLDIRON69 is offline   Reply With Quote
Old 06-27-2009, 12:27 AM   #110
joe231
joe231's Avatar
how is this beast coming?
CHEVY ONLY
Old 06-28-2009, 04:33 PM   #111
HotRodYJ
HotRodYJ's Avatar
Slowly. Been working on some "Honey-do" projects the past couple months around the house. Back into bodywork a little on the truck so not alot to show right now. Over the next few weeks I hope to complete the body work and get it in final primer (cab and frontend). Also have to tear down my 4x4 version 700R4 and swap in a 2WD output shaft and tailgousing then put it back together. Once that's done it will be about ready to stick the motor in it for good and finish out the drivetrain.
Thanks for the nudge, I need it sometimes.
Old 06-28-2009, 11:58 PM   #112
joe231
joe231's Avatar
CHEVY ONLY
Old 07-01-2009, 03:47 PM   #113
CWT
Im kinda catching the end of this build. But why did you cut the floor out instead of droppin the engine mounts? I am getting geared up to do this on my 64 and use stock susp. Already seen it done on a friends truck and it worked out great. He cut a set of mounts down to lower the engine the same amount as the notch and it worked out great.
CWT is offline   Reply With Quote
Old 07-01-2009, 05:30 PM   #114
Mordachai
Fat Fendered Fleetside
Mordachai's Avatar
phenomenal build. Keep it up!
71 GMC lwb
56 Big window swb
93 GMC Sonoma (dd)
radiused fiberglass fender project for 67-72
Mordachai is offline   Reply With Quote
Old 07-11-2009, 04:25 PM   #115
hAetWagon
Schlongbed MEMBER (heh)#15
hAetWagon's Avatar
I was wondering this myself..
82 Chevy Blazer 4wd.RIP
1965 Chevy C10,350V8
Get it reliable,then puttin' it in the weeds..
"Old truck, all new headaches."
hAetWagon is offline   Reply With Quote
Old 07-11-2009, 04:46 PM   #116
joe231
joe231's Avatar
when you notch your cross-member the engine stays in the same place...if you Z the frame it moves everything up
oops I forgot this notch is different.....here is how to do it with out moving the engine up
http://www.captkaoscustoms.com/chopcross.html
CHEVY ONLY
Old 07-13-2009, 06:30 AM   #117
HotRodYJ
HotRodYJ's Avatar
I raised the trans tunnel 5", same amount as the crossmember move.
Old 07-13-2009, 12:28 PM   #118
hAetWagon
hAetWagon's Avatar
I gathered that. Why didn't you keep the motor mounts at the same height?
Old 07-13-2009, 01:09 PM   #119
HotRodYJ
HotRodYJ's Avatar
100 different ways to do anything. 5" seemed like alot to try to out of motor mounts. I did not pancake the crossmemebr at all.
Old 07-13-2009, 02:34 PM   #120
hAetWagon
hAetWagon's Avatar
Understood.
Old 08-12-2009, 07:04 PM   #121
royo
royo's Avatar
any updates
nickle and dime
royo is offline   Reply With Quote
Old 10-15-2009, 01:40 PM   #122
HotRodYJ
HotRodYJ's Avatar
Figure I better update before this thread drops off the radar. Still muddleing thru the body work. I've been making myself work even an hour a month on it, but I'm finally nearing the end. Almost to final primer stage on the cab, doors, front end, etc. Won't be long now I hope.
I scored a complete serpentine belt set-up and accessories off of an 84 Camaro. This give me PS, high output Alt, A/C, etc in a nice clean modern package and best of all it was FREE!!. So I pulled out my York compressor and started looking for a serp pulley for it. Too much money to buy new so I looked at other options. I ended up taking the smog pump pulley (from the Camaro set-up) and it happens to be almost the same size as the York V-belt pulley. Took it to my Dad's lathe and cut the outer ring off of the spare serpentine pullley, then turned down the OD of the V-belt York pully so the serp outer ring would slip on it and welded them together. Took 30 minutes, worked like a charm and saved me even more money. Luckily both pulleys where nice heavy solid units and not the cheap sheet metal pulleys. Made me some homemade mounts and the York now resides on the front of my motor awaiting a new longer belt.
With any luck, in two weeks I hope to order the sheet metal for bed sides and rear fender extension pieces so we can really see what this thing is going to look like for real.
Old 10-15-2009, 02:26 PM   #123
joe231
joe231's Avatar
Sounds cool.... But as you are well aware...... We need pics
CHEVY ONLY
Old 10-15-2009, 10:46 PM   #124
smbrouss70
smbrouss70's Avatar
Can you post some pics of this, I've been thinking about doing something similar.
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 10-16-2009, 03:51 PM   #125
HotRodYJ
HotRodYJ's Avatar
LOL... I'd be glad to post some pics if I could find where my wife hid the camera. It's never in the same place twice, so I can never find it.
