Old 08-06-2008, 01:32 AM   #101
DA INFERNO
DA INFERNO's Avatar
Re: Dropmember Rear 63-72 Spy Pic
Dont think it was me, Truck has not been out for a while. I think its going back under the knife soon.
1964 CHEVY LB, 20" WHEELS, BAGGED
DA INFERNO is offline   Reply With Quote
Old 08-12-2008, 04:38 PM   #102
BarelyLegalFab
Looks good man, love the drop member you made for these guys a while back. Next time you do a write up on let me know i will send some of our arms , you can give them a try.
Richie
BarelyLegalFab is offline   Reply With Quote
Old 08-12-2008, 04:48 PM   #103
SCOTI
SCOTI's Avatar
Richie
Linky linky . . ......
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is online now   Reply With Quote
Old 08-12-2008, 04:57 PM   #104
BarelyLegalFab
would love to, but i dont want to piss any one off before i pay for the advertising. They are on our online store page and our myspace though. lol
i am sure they will send me all the info to advertise tonight, then i can post pics and ****.
Richie
Old 08-12-2008, 09:20 PM   #105
PBFAB.COM
PBFAB.COM's Avatar
Ok guys... Here's the updated pics of the production Dropmember Rear.
- Bolt-in notch with integrated bridge (available to lay frame from 26" to 32" tire diameters; designed for a 5" ride height)
-Sleeved bags mounted over the axle for increased stability and ride quality.
- Bolt-on arallel four-link with panhard bar (axle plunges .625" from ride height to dump; axle shifts lateraly .375 inches from ride height to dump)
-Carrier bearing crossmember (allows the use of two-piece drive-shaft, eliminating cab tunneling)
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 08-12-2008, 09:41 PM   #106
scotts62
One day...
scotts62's Avatar
Sweet man that looks good!
Scott
93 crew cab build
Project 62
Old 08-12-2008, 09:44 PM   #107
abadsvt
abadsvt's Avatar
Beautiful!!!!! You know if you came out with this a long time ago you could have saved me alot of time, money and a hell of alot less stress. Seriously though it looks sweet!! Nice job like always
Josh
(Project truck)
1970 C10 under complete transformation
My current build thread http://67-72chevytrucks.com/vboard/s...d.php?t=212871
Other project: C5 corvette swap into 70 c10 http://67-72chevytrucks.com/vboard/s...=1#post2413517 On Hold
abadsvt is offline   Reply With Quote
Old 08-12-2008, 10:19 PM   #108
jlaird
jlaird's Avatar
I've got a question about that carrier bearing x-member. The stock xmember bolts(rivets if you havent taken it off) to the top and bottom rails with (off the top of my head) about 20 bolts, and also has a reinforcing plate for the bottom rail. Your xmember bolts to the side rails with a total of 4 bolts. Are we losing any rigidity of the frame because the top and bottom rails are not tied together? Seems like the frame would twist a lot more especially since the closest xmember behind it is at the bridge.
Also, will that carrier bearing fit the stock driveshaft? If so, where did it come from.
Thanks nate,
Josh
jlaird is offline   Reply With Quote
Old 08-12-2008, 10:40 PM   #109
PBFAB.COM
PBFAB.COM's Avatar
Thanks nate,
Josh
The chassis pictured had the factory trailing arm crossmember removed. There will be a crossmember to replace the factory trailing arm crossmember installed when the chassis is complete. This carrier bearing crossmember is designed to be used in conjunction with a modified factory trailing arm crossmember, or an ECE drop trailing arm crossmember.
The carrier bearing is a factory replacement for a 71-72 LWB C10 truck.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 08-12-2008, 10:50 PM   #110
gringoloco
A guy with a truck
gringoloco's Avatar
Swanky! What mods would need to be done to a stock t-arm crossmember? Flatten the bottom? Are the axle brackets weld-on?
Looks
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 08-12-2008, 11:45 PM   #111
PBFAB.COM
PBFAB.COM's Avatar
Looks
Correct, the trailing arm crossmember needs to be pankaced, and the upper loop needs to be raised slightly. There will be a PB tubular crossmember for this in the near future (with a couple other cool features).
Currenlty the design features a bracket that welds to the axle tube and then the rest of the pieces bolt to it. That is the only piece of the entire kit that needs to be welded upon installation.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 08-12-2008, 11:53 PM   #112
jasonb72
PorterBuilt Man Crush
Ahhhh...Sh**, you are getting worse than the IPHONE How long will we need to wait to get the tubular cross member. I am never going to get this truck done. love ya Nate, **DISCLAIMER** no man crush implied.
The 72 will live again
jasonb72 is offline   Reply With Quote
Old 08-12-2008, 11:54 PM   #113
jasonb72
Will the empire drive line billet carrier bearing work on the crossmember?
Old 08-13-2008, 01:49 AM   #114
PBFAB.COM
PBFAB.COM's Avatar
Do you by chance have a dimensionon the mounting hole spread? If so, I can verify, and modify the mounting pad if necessary. I am assuming a generic mounting dimension isused... but that would make life too easy!
The carrier bearing crossmember can be moved up,down, forward or back to accomodate different configurations.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 08-13-2008, 01:50 AM   #115
PBFAB.COM
PBFAB.COM's Avatar
On the crossmember, it may be a few weeks until I have a chance to actually build it. The design is done, but I am just way behind right now on getting a number of these rear kits out.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 08-13-2008, 09:23 AM   #116
gringoloco
A guy with a truck
gringoloco's Avatar
I'm lookin' for a part time job...
-Chris
Old 08-13-2008, 10:18 AM   #117
Dinos63
chevy only
Dinos63's Avatar
nice work nate,might have home for one soon
CHEVY ONLY... Nothin Else !
Dinos63 is offline   Reply With Quote
Old 08-13-2008, 10:19 AM   #118
jasonb72
I hope you felt the love.
Old 08-13-2008, 11:11 AM   #119
PBFAB.COM
PBFAB.COM's Avatar
It's nice to know there's so many "man crushes" on this forum.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 08-13-2008, 11:28 AM   #120
C3500
Just wondering are you going to sell the 4-link separate from notch if someone wanted?
C3500 is offline   Reply With Quote
Old 08-13-2008, 12:21 PM   #121
PBFAB.COM
PBFAB.COM's Avatar
I will offer it seperately (don't have a price yet), but the axle brackets would be a different design. They would be a standard weld-on bracket.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 08-13-2008, 01:38 PM   #122
Tony@AirRideTech
Junior Member
Nate..... whats up brother!?!.... what rear airspring are you setting that thing up to use?
Tony@AirRideTech is offline   Reply With Quote
Old 08-13-2008, 01:55 PM   #123
C3500
cool thanks....brother
Old 08-13-2008, 01:56 PM   #124
PBFAB.COM
PBFAB.COM's Avatar
F9000.... of course!
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 08-13-2008, 02:17 PM   #125
Longstep70
Junior Member
So this kit now is designed specifically to work with a 4 link and not with the factory trailing arms, correct?
-Andy
Longstep70 is offline   Reply With Quote
