#101 |
high-Tech Red Neck
Re: Here is a "Not Your Typical" 4wd Blazer build
Just a thought but you could always throw a 203/205 doubler into the mix, and wind up with a truck that can do the low speed as well. Hell you could run 3.08 gears, then when you stuck it in 4 low on the 205, that would be like having a 5.97 geared rear end... And you would still have a lower gear than that with the doubler...
"He used to be a pretty nice feller, now he's a welder!" |
#102 |
.....I am working on it.....
Thanks, but I dont have a use for that. This will probably see more higher speeds then anything else. And to top it off, I will rarely use the 4wd.
#103 |
Thought I would bring this back. I have not done much the past month or so except for this weekend. Got the front and rear seats mocked up. The driver has a seat slider installed for the wifey
![]() Front stuff... |
#106 |
GEARHEAD
Is it normal to mount the seats to the cage? Seems like it would be more comfortable mounted to the cab floor so there is some cushion through the cab mounts. With htem bolted to the cage, and hence the frame, you'd feel every little bump and vibration. Or are there dampeners between the seats and cage?
If no one knows what you're doing, they can't tell you you're doing it wrong HG's Dream Car Build - Shelby Cobra Kit Build your own adjustable track bar 71 ![]() 72 ![]() HG's Plow Truck '78 ![]() Bigass Farm Truck HG's thread of miscellaneous stuff |
#107 |
I guess that is why the seats are called "Suspension Seats".......... Seriously, In offroad, you dont want anything but your suspension to flex, let alone rely on sheet metal to hold you in place. Even though the stock location is beefed up some, it will not hold up the high speed offroad abuse. By mounting the seats to the chassis/cage/frame, you gain a solid mount that will unlikely fail in the event of a barrel roll. Dont get me wrong, these are not those big comfy captain chairs like in the newer cars, because when you are haulin ass in the desert, you want your ass planted firm in the seat so you cant move. This is a typical mounting type for this type of application.
#108 |
![]() Join Date: Nov 2006
Man you are doing a nice job! Can't wait to see it done.
Looks like you spend alot of time at desert races ![]() |
#109 |
Thanks!!
I do, just went to the Score Primm 300. And probably the Laughlin race in January. Last edited by sandking; 09-22-2008 at 10:29 PM. |
#110 |
#111 | |
GEARHEAD
On second thought, that would kinda suck. Mudding and wooded trails it is then.
#112 |
![]() Join Date: Oct 2006
very nice work! Its moveing along faster than mine.
#113 |
how did you attach the cage to the frame??
#114 |
Thanks.
Do you have a build goin on? |
#115 |
1/8" plate to the frame then the tube to the plate. It's not done yet, but you can see the route I am going here........
#116 |
Very nice work. This is the same set up I was gonna do to my '75 C10. Still havent decided if I want front a-arms or convert to 4x4 w/radius arms. But I would like to build a prerunner(of sorts). Great work.
-Lance
------------------------------------------------------ -Lance 2000 Chevy C2500, 5.7, 4L80e 1999 Suburban K2500, 7.4, 4L80e 1980 Camaro..son's car...PROJECT |
#117 |
so I missed this one for the last month....
Yes, I do have a build going on, between the customer vehicals. Mine is "project Rolling Thunder" its been a while since I updated it, maby I will dothat tonight. any update on yours????? |
#118 |
Thanks!! To be honest with you, if you dont really need or want the 4wd, the a-arms are a way better suspension for wide open desert. If this Blazer was purchased as a 2wd, it would have center mounted a-arms without a question.
#119 |
Not much done since these last few pics. I might get some things done this weekend. I have new fenderwells and patch panels for the bed area. In the pics, you can see the rusted areas by the rear fenders. Then I need to fab all of the harness mounts and finish the seat stuff.
#120 |
high-Tech Red Neck
Man she is looking good, what bender are you using?
#122 |
I'm bored at work & thought I would check on your build...so how's it going???
'72 C to K20 "Cannibalizer" http://67-72chevytrucks.com/vboard/s...32#post8653432 '85 K30 "Big Nassy" '06 3500 Duramax ...tow truck '06 Silverado SS...DD '06 C1500 WT...DD '07 Classic C1500 WT...DD Built & sold cause can't keep 'em all: '72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190 '55 Chevy straight axle gasser https://www.trifive.com/forums/showthread.php?t=173938 '69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541 '86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619 |
#123 |
It is moving slow. Got the rust cut out of the rear inner fender area and got the new fender wells mocked in place. Thats about it for the next few weeks. I will update when I get more done.
#124 |
epic ride! very nice fabrication. please update when more work is done. I'm very interested.
#125 |
Hey Sandking very nice build. I remember when you were selling your sand truck and starting this. I can't wait to see it a full roller going to be sikk for sure.
