Old 10-06-2008, 05:47 PM   #101
BACKYARD88
On the fast track to nowhere..
BACKYARD88's Avatar
Re: my '68 chevy (no name yet)
Looks like plenty to me. You should PM Nathan Porter(porterbuilt) and ask him to have a look, I'd bet he could tell you real quick
-Mike Owen-
Norwood, Houston, Cecilia, Jackson, Monroe and counting
BACKYARD88 is offline   Reply With Quote
Old 10-06-2008, 07:37 PM   #102
yfz450_0569
That was done the same time I posted it on here, just waiting for him to reply, it's taking longer than usual.
yfz450_0569 is offline   Reply With Quote
Old 10-09-2008, 09:23 PM   #103
yfz450_0569
Is it best for the front wheels to be in a little, out a little, or just perfectly straight with the frame at ride height and now weight on the front end?
Old 10-14-2008, 03:04 PM   #104
yfz450_0569
Update coming soon...
Just some questions for now. Where can I get sway bars to fit with this frame? Is the front the same as what would originally fit? And what would fit in the rear?
Old 10-15-2008, 12:22 AM   #105
abadsvt
abadsvt's Avatar
There is a few different options. One is get a hold of Nathan and I believe he worked something out with a sway bar company to narrow the sway bar to fit the dropmembers track with or get a custom sway bar and piece it together yourself. If you decide to do the custom sway bar here is a link to a good company that has what you need.
Bars: http://www.1speedway.com/standard_swaybars.htm
Arms:http://www.1speedway.com/Swaybar_Arms.htm
Josh
(Project truck)
1970 C10 under complete transformation
My current build thread http://67-72chevytrucks.com/vboard/s...d.php?t=212871
Other project: C5 corvette swap into 70 c10 http://67-72chevytrucks.com/vboard/s...=1#post2413517 On Hold
abadsvt is offline   Reply With Quote
Old 10-18-2008, 06:52 PM   #106
yfz450_0569
Now I got the rear section of the frame all welded together, and measured and the front should be ready to weld together begining of next week. Here's some pictures:
Old 10-18-2008, 08:10 PM   #107
uno67
uno67's Avatar
shawing, shawing, shawing ching ching wowow nice throw a fender and a bed side on there i know you want to
uno67 is offline   Reply With Quote
Old 10-18-2008, 09:27 PM   #108
68 short step
nice
68 short step is offline   Reply With Quote
Old 10-18-2008, 11:32 PM   #109
BACKYARD88
BACKYARD88's Avatar
Looking good
-Mike Owen-
Old 10-19-2008, 12:00 AM   #110
boostin20
boostin20's Avatar
Who makes those a-arms?
boostin20 is offline   Reply With Quote
Old 10-19-2008, 11:13 AM   #111
Riveted1
Tasty Cakes!
Riveted1's Avatar
Air Ride Tech.
Lookin great BTW!
I'm a little and a lot
Ground beef: A cow with no legs.
'66 Chevy SWB "Penny"
'67 Chevy Big Window SWB- aka "Pearl"
'72 Burb- "Betty" "It's not a hearse dammit"
'99 Chevy Ext. cab Silverado
Riveted1 is offline   Reply With Quote
Old 10-21-2008, 11:05 AM   #112
yfz450_0569
Pretty much at a stand-still on my truck for a few days till more parts come in and I get more money to get more stuff. I was bored so I took some pictures of all the rust on the cab. If I can get some 22.5s for a dually sold then I should have the money I need to finish it up most of the way.
Pretty bad? How would you recomend fixing these spots? I already have the rocker panels, left cab corner and a few other sheet metal pieces, but I am looking for the cheapest and possibly the easiest way to still fix it nicely.
My dad also has a 1950 Chevy pickup that he might let me restore, he has it at a body shop right now, been sitting for nearly 5 months and they still haven't done anything, so maybe I'll get to do the work I'm already kinda excited.
Old 10-22-2008, 09:29 AM   #113
my67chevytruck
Under Construction
my67chevytruck's Avatar
Use patch panels for the bigger area's and bend up some correct gauge sheetmetal to repair the smaller areas..... should be pretty simple. I would wirewheel the areas especially around the kick panels to make sure you cut out all the rust and fix what needs to be fixed... good luck.
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 10-22-2008, 10:18 AM   #114
yfz450_0569
It's already sandblasted so the weakest rust should all be gone. I might just get some guy that's good at bodywork to come look at all the rust and tell me just what I need to do. I think I have a pretty good idea, but I just want to make sure
Old 10-22-2008, 11:18 AM   #115
yfz450_0569
Is there any way I can change the title of my forum? I'm getting tired of "my '68 chevy (no name yet)". I think I have a name picked out for my truck, show n go or low n go.
Old 10-22-2008, 11:23 AM   #116
my67chevytruck
Under Construction
PM 70CST (moderator) and ask him if the title can be changed.
Heath
FAQ how to's
1956 Chevy Apache
56 chevy truck :
67 truck build:
69 k10:
Old 10-23-2008, 04:04 PM   #117
yfz450_0569
Re: "my '68 chevy project - show n go".
I've got my airtank tacked on and also my compressor brackets. Is it really bad to have the compressor welded to the frame? I just asked one guy so far and he said he didn't think it would hurt to do it and I didn't see a problem with it either so here goes. How does the set-up look? I plan on using an elbow so the hose will mount from the side not straight into the top like that.
Old 10-23-2008, 07:00 PM   #118
68 short step
i wouldnt weld the compressor to the frame, because in the event it went out replaceing it would turn a easy job into a chore.. plus, they are designed to be shock mounted, and you may shorten the life of the unit.....i do think it would work tho, just IMO you are creating more work for yourself...... but it looks like one heck of a job you are doing. keep it up
Old 10-23-2008, 09:56 PM   #119
BACKYARD88
BACKYARD88's Avatar
Also, without mounting it with some isolators is going to transmit 100% of the vibration into the frame and everything else. It would be a lot more quiet if you mounted it with the rubber isolators. It's surprising the things that will rattle, don't ask how I know Looking good though. Keep it up!!
-Mike Owen-
Old 10-24-2008, 08:36 AM   #120
Riveted1
Tasty Cakes!
Riveted1's Avatar
The vibration on the frame was the first thing I thought of. I wonder what the resonant frequency of a truck frame is? You might be able to get that thing dancin'! For a little fun: Sympathetic Vibrations
Old 10-24-2008, 08:47 AM   #121
BACKYARD88
BACKYARD88's Avatar
I see they got the name fixed for ya.
-Mike Owen-
Old 10-24-2008, 10:26 AM   #122
yfz450_0569
Sorry for any conufusioin, I meant the tank welded to the frame, I got the compressor mounts tacked on and the compressor bolted on, I wouldn't want to weld the compressor to the frame, I'd have problems with powdercoating and a bunch of others stuff later I'm sure lol, my bad on saying wrong
Old 10-24-2008, 11:56 AM   #123
revn67
revn67's Avatar
there will be no problem with welding your tank to the frame, but i assume you are using some sort of mounts for it still right? i wouldn't just weld the surface of the tank to the frame, i love the build so far and it'll definitely be a great looking truck when its done im sure...ecspecially with those wheels and big brakes!!!
67 small windowed,shortbed,fleetside, sbc 327, th350,12 bolt :under the knife:
71 cab for sale in parts classifieds!
2004 black chevy 1500
"finish your beer, theres sober kids in india!"
revn67 is offline   Reply With Quote
Old 10-24-2008, 12:19 PM   #124
pcorriveau951
pcorriveau951's Avatar
i dont see a problem with welding the tank to the frame, just one suggestion, please make sure you pressure test the tank before you send it out to get powdercoated, i have a buddy who welded on mounting brackets and powdercoated and there was a little pin hole that leaked and he had to have it recoated.
Very good looking project, i want those brakes, and keep up the progress.
pcorriveau951 is offline   Reply With Quote
Old 10-24-2008, 02:52 PM   #125
yfz450_0569
I took pieces of 2 inch flat metal to mount the tank maybe about 1/2 inch from the piece of tubing it sits on.
Does anybody else every get a little tired of working on their project day after day? I'm thinking about taking a little break and waiting for more money to come in so I can finish it better.
