Old 03-06-2009, 01:46 AM   #101
Rorkrado
Rorkrado's Avatar
Re: Not so budget 3-link build
When are you going to be starting another project of your own? Some great reading, while you were building frank!
'66 c10 draggin' bumper
'41 business coupe in progress
Rorkrado is offline   Reply With Quote
Old 03-06-2009, 01:52 AM   #102
Twisted Minis
Twisted Minis's Avatar
I'm buying a new daily this Saturday. I am going to try to leave it alone, aside from installing some stereo stuff I have sitting in storage (my closet). Although I can see that being a big ordeal since I am so anal about things, and I am not so skilled when it comes to wood working. Lol.
But I am already working on (sort of, in my spare minutes) something new for myself. I'm building my own spindles for it right now.
If you can find it cheaper, I can fix it!
Twisted Minis is offline   Reply With Quote
Old 03-06-2009, 02:13 AM   #103
Rorkrado
Rorkrado's Avatar
thats awesome. spindles cant be an easy job.
ill trade you some wood working skills for some tig skills!
Old 03-06-2009, 10:43 AM   #104
SCOTI
SCOTI's Avatar
Specs/details & pics please .
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 03-06-2009, 11:54 AM   #105
Twisted Minis
I'll work on that. It's not much to look at yet, just a bunch of laser cut parts, rod ends and uni balls, and some spindle snouts. Nothing really assembled.
Old 03-12-2009, 02:00 AM   #106
Twisted Minis
I keep forgetting my camera, but the front is bagged, painted and assembled.
Built a new transmission cross member, cut out the old one, and installed the new one.
Old 03-12-2009, 07:03 AM   #107
AceX
>130dB Moderator
AceX's Avatar
I like it. Simple and effective, just how I like it.
Living Life @ 130dB
LED Tail Light Conversion; How-to
Friend. Father. Brother.
RIP El Jay
CLICK HERE and for less than $0.07 a day, you too can help support and build a better forum.
AceX is offline   Reply With Quote
Old 03-12-2009, 12:52 PM   #108
fixit-p
fixit-p's Avatar
I see that you first drew it out on your work bench but what really stands out for me is that you notched in some DOM at the ends where it bolts to the chassis instead of just drilling through the tube for the cross bolts.
fixit-p is offline   Reply With Quote
Old 03-13-2009, 12:35 AM   #109
Twisted Minis
Ya I generally draw stuff like that out in full scale. It helps me visualize, and then I can just measure of of it for the cuts.
Ya I don't really like just drilling a hole through the tube and running a bolt through it. It seems like the holes would oval out a bit faster to me. So I use some 1.25" DOM, and I stick some oilite bushings in them with a 3/4" ID. Then I use 3/4" .083 wall DOM as an inner sleeve to run a 9/16" bolt through. Just seems more precise to me.
Got the power wire measured out, and wrapped it in TechFlex. I found some red shrink wrap with glue inside, and I really like it. I ran it, and finally set the truck on the ground. Final pictures of that will wait until tomorrow when I get the bed on. I basically had to rebuild the entire exhaust system. I was hoping I wouldn't have to, but nothing was working. So I cut it behind the transmission crossmember and started over, moving the cat back about a foot, and it went smoother from there. It's basically a recycle exhaust system with the stock tubing, with the only new parts being the muffler I made, and a turn down out the back. I forgot to take pictures, but I will try to snap one tomorrow.
Old 03-13-2009, 11:45 PM   #110
Twisted Minis
Old 03-14-2009, 06:00 PM   #111
Rorkrado
Rorkrado's Avatar
Not only is the fabrication on this ol yota amazing, the truck is nice as well!
turned out great!
Old 03-16-2009, 10:31 PM   #112
Twisted Minis
Just got back from driving to So Cal after only a 2 hour test drive. I packed along every tool I could think of, along with a low profile jack, extra air line and fittings, etc. Didn't have to use a tool once, truck drove great all the way down there.
Old 03-18-2009, 10:37 PM   #113
Twisted Minis
Something else in the shop right now, the Crown Vic I bagged and put IRS in. It's been sitting in the parking lot awaiting payment for the last 4 months. Guy got a new job and got caught up on the bill, so it's getting finished. I had a new drive shaft built from scratch, as the stock one was some aluminum composite that no shop would touch, and said was impossible to balance. And I started the exhaust. It has to tuck into the drive line tunnel to stay above the frame rail, but luckily with IRS the drives haft doesn't need move any more than spinning in place.
Old 03-19-2009, 02:28 PM   #114
greystoke
whereabouts did you get your red techflex? That looks great
greystoke is offline   Reply With Quote
Old 03-19-2009, 08:54 PM   #115
Twisted Minis
You can get it on eBay. Interstate Battery carries it if you want it locally. I have an account there, and even then it's about twice the price I get it on eBay.
Old 03-19-2009, 09:21 PM   #116
Twisted Minis
Just about done with the exhaust. There is one rubber isolator on the cross member, but I need to wait until I build the strut rods for the rear axle (waiting on parts still) before I make hangers for the tips. I want to turn them out towards the wheels as much as possible, but I need to get the strut rods built first.
It's gonna be loud. When from 1 3/4 tube with flat spots in it and massive mufflers, to 2.5" all the way out with what is basically a glass pack.
Old 03-19-2009, 09:33 PM   #117
Rokcrln
Rokcrln's Avatar
Your work looks great. I grew up in Penngrove and started with sand rails up at Cow Mountain then got into 4x4's and rock crawlers for a bit up at Stony Ford and the Con. Now I am down to earth with 2x's. I to did a frame air tank and it worked out slick but the most fun one to build was an 8 point roll cage that was the air tank for the ARB's and air powered Margarita mixer
My current project is a 72 4 door Tahoe with a 6 link C4 vett rear air bag set up. The IRS's are allot more space friendly with out all the moving parts like a solid axle.
Kevin
LFD Inc.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Rokcrln is offline   Reply With Quote
Old 03-19-2009, 09:36 PM   #118
Rokcrln
Rokcrln's Avatar
Any more pics of your bag set up on the Jag rear you used?
Kevin
LFD Inc.
Old 03-19-2009, 09:42 PM   #119
Twisted Minis
Nice work!
Ya I have some more, I will try to dig them up. I wish I could have cut the floor out of this car like you did. The owner wanted the rear floor untouched. I had to notch and narrow the frame a bit to make it fit and make the car lay out. I tucked the pinion up as high as I could within reason, to get a good camber angle at ride height. I like where it's set at, but the pumpkin is still too close to the ground to get the exhaust underneath it. I was hoping to do full exhaust on this car, but there really isn't any way to do it without it looking bad, and running oval tube.
I wanted to post a picture of this too. Heres the new MIG welder. I now have a matching set and I love it. Was getting tired of the duty cycle on my Miller, and having a red and blue fleet. This thing welds beautifully.
Old 03-19-2009, 09:49 PM   #120
Twisted Minis
Found one of the axle before I put it in the car. I built a cradle that drops in and out so the axle isn't terribly difficult to remove. Easier than the stock jaguar at least.
The owner bought wheels off of the new Dodge Charger Police Interceptors. It's a slightly different bolt pattern (.7 MM), so I had the front hubs redrilled, and I pressed in some 14MM studs so it can run the stock lug nuts and center caps.
The rear just uses adapters since the Jaguar is a Chevy pattern. I lucked out on that since the Jaguar axle was about 2 inches narrower than the stock axle too.
Old 03-19-2009, 09:53 PM   #121
Twisted Minis
We have a show in Penngrove every year. My Dad lives there, and owns a candy store in Petaluma.
Old 03-19-2009, 10:04 PM   #122
Rokcrln
Rokcrln's Avatar
Was that the show down in the park a few months back? My parents still live in the house I grew up in just up from Penngrove school on Adobe Rd.
Yeah the IRS is working out great in the Tahoe because the rear floor is wood stock so I pulled it out and the new 03 Tahoe floor section is only 4" higher then stock so the 3dr row Tahoe seats still work out.
Kevin
LFD Inc.
Old 03-19-2009, 10:09 PM   #123
Twisted Minis
Ya it's in Penngrove park. We do it in September. That park is basically my Dad's back yard.
Old 03-19-2009, 11:06 PM   #124
Rokcrln
Rokcrln's Avatar
Do you know "Hutch" in the old fire house? I spent many hours sitting on a stool in his garage.
Were did you grow up?
Kevin
LFD Inc.
Old 03-19-2009, 11:20 PM   #125
Twisted Minis
I don't know Hutch.
I'm still growing up. But I haven't gone far. Went from Santa Rosa to Windsor in 7th grade. Been here since.
