Old 09-06-2010, 10:31 PM   #101
67-C10
67-C10's Avatar
Re: Project 67 C-10
Race back in may i broke the wheel studs off in the middle of the corner that was fun, not. Some pics from the beach which rained for half the time there. Did catch 15 bluefish with my buddy the last day and got 138 pounds. Had to move the first few days cause the storm pushed the waves over the crest. Pics of the fenders and a cup car tire under the front end, thing is wide. The drivers side fenders is way out of wack with the top mount u can tell was in the jig wrong and the topholes of the innner fenderwheel are off about an inch. pass side is marginal.
67 C10 2wd Stepside (to be fleetside), Factory AC truck, Big Back Window, just got a 6.0/6l90e to jam in it now.....
Needed: paint and lots of it. and i'm sure lots more misc. parts.
Project 67 short step Build Thread
01 Sierra Crew 6.0
2015 Ford F150 Work gave me truck i really wouldn't buy a ford.
67-C10 is offline   Reply With Quote
Old 09-06-2010, 10:33 PM   #102
67-C10
67-C10's Avatar
Re: Project 67 C-10
fenders
01 Sierra Crew 6.0
Old 09-06-2010, 10:38 PM   #103
67-C10
67-C10's Avatar
Re: Project 67 C-10
I also can't find my paper showing how the core support gets bolted together bu think i got it right. some input would be good though. i got square washer then support then rubber then washer then frame then washer then rubber then washer then nut. i think.
01 Sierra Crew 6.0
Old 09-10-2010, 10:16 PM   #104
67-C10
67-C10's Avatar
Re: Project 67 C-10
Tacked all the patch panels in. got to finish them off with the good welder.
01 Sierra Crew 6.0
Old 09-11-2010, 10:23 AM   #105
67cheby
67cheby
67cheby's Avatar
Re: Project 67 C-10
same thing i am doing tacking them together with a cheap (gassless) mig and then going to my friends house and using his good mig to finish it up !!
67cheby is offline   Reply With Quote
Old 09-11-2010, 11:45 PM   #106
67-C10
67-C10's Avatar
Re: Project 67 C-10
Got kind of a hefty mig with little bit bigger wire i'm trying to finish it up with now. Had to wait to get the extemsion cord for it tonight and got to dark out to finish it up. My buddy's getting me a set of fenders this week. Owns a repair shop so he can get from one of the Keyparts vendors in the area so i ain't getting shafted for $200 to ship. Also just scored a front valance from board member.
01 Sierra Crew 6.0
Old 09-23-2010, 08:03 PM   #107
67-C10
67-C10's Avatar
Re: Project 67 C-10
Got my TriPlus Fenders in. Much beefier than the other repops i got. Still gonna have to make them fit a little but at least the drivers side i can make work this time. The inner fenderwells suck to line up.
01 Sierra Crew 6.0
Old 09-24-2010, 11:02 PM   #108
67-C10
67-C10's Avatar
Re: Project 67 C-10
Picked up a nice set of dougs headers off of Gaswagon(Jay) tonight. Gonna start fitting the front sheetmetal this weekend. Hope i can get the hood on. And my gas tank shipped from Boyds today. Should see by Wednesday.
01 Sierra Crew 6.0
Old 09-29-2010, 10:24 PM   #109
67-C10
67-C10's Avatar
Re: Project 67 C-10
Got my tank in but thats about the only thing that went right this week. Battery died in my car in the rain tuesday, wisdom teeth are killing me all this week too. Also the core support is tweaked about 1/4 inch on the bottom drivers side and found more rust where the cab suuport goes agoainst the inside of the rocker panel on the passenger side. I might grind down the cab corners to see whats hiding under there. Hoping its only a skim coat of bondo and not some oles cause then that will be getting cut out.
01 Sierra Crew 6.0
Old 10-06-2010, 09:50 PM   #110
67-C10
67-C10's Avatar
Re: Project 67 C-10
managed to get all the sheetmetal to the garage this weekend. Found some rust in the passenger side front rocker so need to get that squared away. Also sanded down the cab corners to make sure there weren't any holes only filed with bondo. Found a few small pinholes but that was it. Need to finish welding a few spots but pretty much all set. Tank is in somewhat, Bed is sitting on and i semi hung one fender. Had to make the new driver side fender to fit a little at the top but i think the door was more of an issue. also had the hood on but as we were trying to line it up the back wouldn't sit all the way down and then i pulled a nutsert out of the damn thing.
01 Sierra Crew 6.0
Old 11-06-2010, 04:51 PM   #111
tantrumpipeline
Master Procrastinator
tantrumpipeline's Avatar
Re: Project 67 C-10
Great job on all the work, gonna be a sweet ride when it's all done, making lots of progress considering your schedule, not sure how I missed this build, but I'm in for inspiration on mine.
My Buildhttp://67-72chevytrucks.com/vboard/s...d.php?t=395506
20 Duramax tow pig
68 2wd short stepper project
77 2wd short fleet beater
52 short project
tantrumpipeline is offline   Reply With Quote
Old 11-07-2010, 02:09 PM   #112
67-C10
67-C10's Avatar
Re: Project 67 C-10
Thanks, been slaking a bit lately but getting back on it again. Just got some seam sealer. And rust encapsulator in to get at a few of the hard to reach areas. I'm questioning the hood now that I ripped a weld nut through it and there are a few pin holes. We'll see trying to button up areas one at a time now.
01 Sierra Crew 6.0
Old 11-07-2010, 07:31 PM   #113
67-C10
67-C10's Avatar
Re: Project 67 C-10
Pretty much finished seam selaing all the cab. realy should have worn gloves with that stuff its sticks like superglue.
01 Sierra Crew 6.0
Old 11-07-2010, 09:30 PM   #114
spike38
spike38's Avatar
Re: Project 67 C-10
It should be getting a little cold up there, This time of year.
A friend of mine, Lives in Andover.
I see you got your household AC units put up for the winter.
Or is that shop ventilation.
I love the weather up there, No need for AC units.
But, A fireplace, Or wood burner is more valued.
Spike
spike38 is offline   Reply With Quote
Old 11-08-2010, 08:58 PM   #115
67-C10
67-C10's Avatar
Re: Project 67 C-10
Spike
Actually poor mans paint booth fans thats why the blades are all blue.
01 Sierra Crew 6.0
Old 11-08-2010, 09:20 PM   #116
spike38
spike38's Avatar
Re: Project 67 C-10
That works for me!!
Mine, won't be much different,
When I get to my clear coats.
Keep up the great work!
Spike
Old 12-10-2010, 11:17 PM   #117
67-C10
67-C10's Avatar
Re: Project 67 C-10
Allroght fixed the bolt i pulled out of the hood last weekend and got another set of hinges. the pass side is still a little saggy but much better than the others were. Gettign everything to line up is a pain and when you open the hood it's hitting the cowl on the pass side. Also had a few dates which may slow this process or not we'll see.<<Probably should finish the truck before pursuing the other interest>> But they sure are fun.
01 Sierra Crew 6.0
Old 12-12-2010, 08:27 PM   #118
67-C10
67-C10's Avatar
Re: Project 67 C-10
Got the frontend all squared away and started dissassembly of the bed. overall made decent progress this weekend. and now the hood doesn't hit the cowl.
01 Sierra Crew 6.0
Old 12-12-2010, 08:42 PM   #119
67chevy1series
67chevy1series's Avatar
Re: Project 67 C-10
do you have any pictures for us
67chevy1series is offline   Reply With Quote
Old 12-12-2010, 09:27 PM   #120
VA72C10
VA72C10
VA72C10's Avatar
Re: Project 67 C-10
cool!!! Keep at it!!!
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 12-12-2010, 09:59 PM   #121
67-C10
67-C10's Avatar
Re: Project 67 C-10
can't upload off android so had to wait to plug it in.
01 Sierra Crew 6.0
Old 12-12-2010, 10:02 PM   #122
67chevy1series
Re: Project 67 C-10
repo fender always seems to not line up on the front passenger with the hood
Old 12-12-2010, 10:47 PM   #123
VA72C10
VA72C10
VA72C10's Avatar
Re: Project 67 C-10
looking good!!!
Old 01-29-2011, 11:04 PM   #124
67-C10
67-C10's Avatar
Re: Project 67 C-10
Well been on hold for a little while playing the dating field or at least attempting.... Snow hasn't helped anything either... Starting to wonder if i should just work on the truck instead???? but those women sure are fun.. Anyways stripped the bed apart and replaced headboard and rear piece. also stripped and painted the cross sills. Working on the fenders now. Little masaging needed on the one that was full of filler. looked like someone hit a fence with it.
01 Sierra Crew 6.0
Old 02-01-2011, 10:03 PM   #125
67-C10
67-C10's Avatar
Re: Project 67 C-10
I'll get some progress pics up soon too. Dealt with snow for 2 hours when i got home tonight. Got like 20" of snow on the ground still and more to come. can't put it anywhere!!!!!!!!!
01 Sierra Crew 6.0
