Old 12-04-2009, 10:27 PM   #101
mcbassin
Still Learning
mcbassin's Avatar
Re: 1969 Short Wide
Originally Posted by 68 short step View Post
how many miles are on the 4.8?
Not a low mile motor like some of yours. This one is supposed to have around 100k miles. It looks really clean and no visible leaks. Who knows? PO thought it was a 5.3, It could be higher or lower. Does the pcm retain this info? I would be interested to know.
Mike
mcbassin is offline   Reply With Quote
Old 12-04-2009, 11:11 PM   #102
my67chevytruck
Under Construction
my67chevytruck's Avatar
Re: 1969 Short Wide
mike, if that camaro is in the way let me know!
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 12-04-2009, 11:16 PM   #103
mcbassin
Still Learning
mcbassin's Avatar
Re: 1969 Short Wide
No problem Heath, I will give you a chance at it too if I decide to sell it. If I had a big enough shop I would have already started on this one too. My building isn't big enough for the boat and even one project really.
Old 12-05-2009, 12:11 AM   #104
68 short step
Re: 1969 Short Wide
Mike
no the PCM doesnt tell the mi., but will tell ya the VIN #, which in turn will tell ya the engine size.. with the VIN also you can run a carfax and see when the last reportable inccodent/inspection was, and look at the mileage, to give you a approximent mileage.
68 short step is offline   Reply With Quote
Old 12-05-2009, 12:11 AM   #105
68 short step
Re: 1969 Short Wide
also how did you determine it was a 4.8 instead of a 5.3?
Old 12-05-2009, 12:27 AM   #106
mcbassin
Still Learning
mcbassin's Avatar
Re: 1969 Short Wide
This was the first clue:
Then verified the back of the block...sure enough 4.8. I was bummed at the time, but I've moved on and am actually looking forward to installing it....eventually. Now I know exactly the things to look for when inspecting one before buying it.
I will be back on the cab tomorrow. and start tearing the rusty front suspension.
Old 12-05-2009, 10:25 AM   #107
68 short step
Re: 1969 Short Wide
the 4.8 isnt anything to be ashamed of, you're gonna love it, and the power diffrence isnt gonna be a big diffrence...just switching from carbed to FI is a huge improvement....keep the progress pics coming
Old 12-05-2009, 01:30 PM   #108
Rokcrln
Rokcrln's Avatar
Re: 1969 Short Wide
Yeah the 4.8 will be great and 100k is just broken in. My last work truck was a 2000 w/6.0L that I beat for over 300K and all it needed was a water pump at about 220K. Then our shop bought a wimpy 089 with a 5.3L I took it for a drive because I had just bought a 20K 5.3L for my Tahoe and was worried it may not be enough power for what I wanted. Well it felt like it had more power and get up and go then my 6.0L did so I was very happy with that. Then when I opened the hood I found out it was only the 4.8L! I then took that truck and loaded a full 71 cab in the bed along with a tail gate and lift gate for a 65 burb, I then hooked my 16' steel deck car trailer up with a 70 2WD Blazer with an extra set of quarter panels on it and left for Arizona. It was the smoothest tow I have done and even took the "Grape Vine" at 65 mph the entire way with out a problem and got 14 mpg loaded.
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 12-05-2009, 02:50 PM   #109
1LoC10
Insert Title Here
1LoC10's Avatar
Re: 1969 Short Wide
I have a 4.8 in my crew cab with heavy chrome 20's on it.... and it gets up and moves just fine, in a little short wide it should be fine
BOBBY
_69 SWB_
1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all <<
1LoC10 is offline   Reply With Quote
Old 12-05-2009, 02:58 PM   #110
1LoC10
Insert Title Here
1LoC10's Avatar
Re: 1969 Short Wide
Heres my two trucks side by side...lol
if a 4.8 will move the big one, it will be a great engine in the little one..lol
BOBBY
_69 SWB_
Old 12-05-2009, 07:11 PM   #111
mcbassin
Still Learning
mcbassin's Avatar
Re: 1969 Short Wide
Thanks guys for confirmation of what I already thought. I am pressing on with the 4.8. I'm sure it will have plenty of power for this rig. I am going back to work on the cab in a little while (hope to get some pics).
1loc10, you were right on the money. The pic with my son is of the 67 and the 68 is pictured below. I get them mixed up. One of these days, both of them will be back on the road.
Here is the 67:
Here is the 68:
Old 12-05-2009, 07:16 PM   #112
JohnC
JohnC's Avatar
Re: 1969 Short Wide
If it helps to keep them straight the 67 has a big 67 written on the front fender j/k
JohnC is offline   Reply With Quote
Old 12-05-2009, 07:21 PM   #113
mcbassin
Still Learning
mcbassin's Avatar
Re: 1969 Short Wide
Yea I saw that when I took the pics. I think the PO purchased that fender from a salvage or something the inner fender is marked the same way. I think the side markers on the 68 is the dead giveaway too.
Old 12-05-2009, 07:23 PM   #114
1LoC10
Insert Title Here
1LoC10's Avatar
Re: 1969 Short Wide
and 67 was the only year with a vent window
BOBBY
_69 SWB_
Old 12-05-2009, 11:39 PM   #115
mcbassin
Still Learning
mcbassin's Avatar
Re: 1969 Short Wide
Okay, back on track. I got a little time to work on the cab this evening. I was able to finish up the hacked areas on the lower front left and right thanks PO! Then moved on to the passenger rocker panel. It looks like the the PO replaced it but left some rust on the lower door pillar. It looks like the driver side is still ver solid and even the rocker looks solid with the exception of the huge dent probably from moving the cab around by the various owners so much. I don't know if the dent can be pulled or if I should just change it? Here are the pics:
Driver side before the patch
Fitting the patch
Pass. side
Pass side Welded
Driver Side
Front view
Pass. Rocker Panel cut out
Pillar
Driver side pillar
Driver rocker
Old 12-06-2009, 12:13 AM   #116
my67chevytruck
Under Construction
Re: 1969 Short Wide
keep at it...
Heath
FAQ how to's
1956 Chevy Apache
56 chevy truck :
67 truck build:
69 k10:
Old 12-06-2009, 04:10 PM   #117
JohnC
JohnC's Avatar
Re: 1969 Short Wide
Old 12-06-2009, 05:47 PM   #118
scotts62
One day...
scotts62's Avatar
Re: 1969 Short Wide
Oh my damn thats an ugly rocker
Keep up the good progress
Scott
93 crew cab build
Project 62
Old 12-06-2009, 08:43 PM   #119
highperf4x4
Re: 1969 Short Wide
Take lots of pics when you replace the rocker.........................
highperf4x4 is offline   Reply With Quote
Old 12-06-2009, 09:21 PM   #120
mcbassin
Still Learning
mcbassin's Avatar
Re: 1969 Short Wide
Yep, It's really weird the driver side is near perfect and I guess the passenger side didn't drain so it has some issues. Just look around and you'll see some way worse! I feel pretty fortunate to not have to do more rust repair it's a real PITA to tig weld around any rust. I have 4 other cabs and purchased this one because it is so solid.
Don't worry when I get the replacement panels I will document it proper with lots of close ups. Unfortunatetly, the PO already changed the pass. rocker and did a real crappy job and left a lot of rust.
Old 12-06-2009, 10:29 PM   #121
scotts62
One day...
scotts62's Avatar
Re: 1969 Short Wide
Yeah that always sucks when you get into fixing someone else's mess up when they could have not cut any corners the first time and it would still be in good shape.
Scott
93 crew cab build
Project 62
Old 12-07-2009, 09:38 AM   #122
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Re: 1969 Short Wide
Nice progress!
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 12-13-2009, 12:07 AM   #123
mcbassin
Still Learning
mcbassin's Avatar
Re: 1969 Short Wide
Got a little work done the cab today. I cut the rust out on the passenger side firewall, made some templets for the metal and cut the fillers and started welding them in. The welds look like crap but they are solid, I have been fighting with dirty thin metal and I dropped the tig torch and broke the ceramic tip, of course I didn't have any spares couldn't get enough gas to the weld. Finally, after fighting with it for a couple hours, I gave up. Here are the pics:
Old 12-13-2009, 12:12 AM   #124
scotts62
One day...
scotts62's Avatar
Re: 1969 Short Wide
Hey looks good!
Dont worry about the welds the filler will hide them nicely
Scott
93 crew cab build
Project 62
Old 12-13-2009, 12:37 AM   #125
brn agn
brn agn's Avatar
Re: 1969 Short Wide
Nice work! Thanks for sharing with us. Don't get too frustrated. It will be worth it in the end.
1969 C10 SWB Project Charity Case AKA "Roscoe"
1971 Cheyenne Super A Combined Effort
The Service Station-A practical ministry for those in need
brn agn is offline   Reply With Quote
