Old 05-21-2014, 08:58 PM   #101
lousblown55chevy
Re: Project 69 Blown Gasser!
Originally Posted by 88fordf150 View Post
I believe it is at about 10% under driven, I thought that might be a good range for a street truck. The fuel pump is rated at 110gph free flow with 6.5-8.0 psi.. These edelbrocks I hear like no more than 5psi? I plan on installing a AFR gauge to be on the safe side. I'm running the gears that came in the truck ( 3:73 ) but I added a posi unit. I'm sure it will be a tire fryer. Should be an experience seeing how I have never driven a blown anything before.
Just keep a close eye on the fuel press. under wide open throttle , and go easy on the timing. I have to say that once you drive a boosted car nothing else compares !
lousblown55chevy is offline   Reply With Quote
Old 05-21-2014, 09:04 PM   #102
lousblown55chevy
Here are a couple pics of my beast
Old 05-22-2014, 07:17 AM   #103
88fordf150
88fordf150's Avatar
Originally Posted by Keith Seymore View Post
Brad - looks great! Looks like some high quality workmanship going on there.
Whereabouts in Michigan are you located (roughly)?
Sidebar: regarding that SPID label - you may want to spellcheck that before printing a bunch up.
K
Jackson County about 6 miles from Michigan International Speedway. How about you?
Brad handshoe
88fordf150 is offline   Reply With Quote
Old 05-22-2014, 06:43 PM   #104
88fordf150
88fordf150's Avatar
Sweet car! 55 is one of my all time favorites.
Brad handshoe
Old 07-05-2014, 09:56 PM   #105
88fordf150
88fordf150's Avatar
Removed the mid-bearing support & add some welds to the trailing arms today.
Brad handshoe
Old 07-06-2014, 01:56 AM   #106
67chevy1series
67chevy1series's Avatar
I'm really considering doing those welds on my trailing arms... I just wonder how much of a difference it will make
67chevy1series is offline   Reply With Quote
Old 07-06-2014, 08:54 AM   #107
88fordf150
88fordf150's Avatar
There is only about 4 factory spot welds holding them together. I saw a post awhile back where someones had rusted and came apart! I probably should have welded the seam on the top & bottom, I only did the top.
Brad handshoe
Old 07-07-2014, 08:44 AM   #108
67chevy1series
wow I always noticed the rivets in the middle but I never counted how many there were... I guess I will break out the arc welder and lay some beads.. Trucks looking good, keep it up
Old 07-22-2014, 09:09 PM   #109
67chevy_hotrod
67chevy_hotrod's Avatar
Updates?
1967 Chevy CST 10
1969 Chevy C/20 Longhorn
1969 K10 Suburban
1972 Chevy Cheyenne Super 10 turned K30 (sold)
67chevy_hotrod is offline   Reply With Quote
Old 07-23-2014, 07:56 AM   #110
88fordf150
88fordf150's Avatar
Originally Posted by 67chevy_hotrod View Post
Updates?
Not much has happened lately. I'm getting ready to start a new job. The cash flow has been pretty slim here for awhile.
Brad handshoe
Old 07-27-2014, 11:17 PM   #111
67chevy_hotrod
I am sorry to here that just whatever you do dont get rid of this thing it will be a killer truck when its done! good luck with your new job as well!
1967 Chevy CST 10
1969 K10 Suburban
Old 07-28-2014, 08:04 AM   #112
88fordf150
88fordf150's Avatar
Thanks. It would have to be a case life or death for me to get rid of this truck. I plan to start work back on it real soon! Drive shaft, cab mounts, paint the bottom of floor & fire wall and then cab can go back on for the last time.
Brad handshoe
Old 08-15-2014, 06:13 PM   #113
88fordf150
88fordf150's Avatar
Started to do some work on the inner & outer roof panels.
Brad handshoe
Old 08-15-2014, 06:14 PM   #114
88fordf150
88fordf150's Avatar
one more pic.
Brad handshoe
Old 08-15-2014, 08:40 PM   #115
67chevy1series
Nice work! Keep the progress coming!
Old 08-20-2014, 01:15 AM   #116
67chevy_hotrod
Sweet! nice body work too! coming right along man i will tell you you got me so pumped on your build i cannot wait till this thing is tearing up the street!!
1967 Chevy CST 10
1969 K10 Suburban
Old 08-20-2014, 03:55 PM   #117
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Taking that outer roof skin off sure makes that inner panel repair a lot nicer. Great work!
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 03-15-2015, 09:10 AM   #118
Possmguts
Possmguts's Avatar
Im in.
"Hey... its only time and money right? Just do it."
67 Short Bed under major construction
http://67-72chevytrucks.com/vboard/s...=651356&page=8
Possmguts is offline   Reply With Quote
Old 03-16-2015, 01:13 AM   #119
moggey01
Nice. Good to see something different . I like it.
moggey01 is offline   Reply With Quote
Old 03-22-2015, 03:35 PM   #120
88fordf150
88fordf150's Avatar
Test fitted my roof panel today and moved my pedals back 3/4" or so.
Brad handshoe
Old 03-22-2015, 06:22 PM   #121
jjzepplin
jjzepplin's Avatar
Nice! How did the roof fit and which brand did you use?
Cool pedal Idea. I am 6-1 and might steal the idea from you...
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 03-22-2015, 07:58 PM   #122
88fordf150
88fordf150's Avatar
I don't honestly remember what brand the roof was, but it did fit nicely.
3/4 - 1" off the pedals will surely make a difference.
Brad handshoe
Old 03-23-2015, 09:44 PM   #123
swamp rat
swamp rat's Avatar
Great idea using tie down straps for the roof shell. Subscribed!
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 08-02-2015, 01:02 PM   #124
88fordf150
88fordf150's Avatar
Finished with the installation of the top. Started body work on the back of the cab. I want to spray the bottom of the cab floor so I can set the cab back on the frame for the last time! I plan on painting the bottom of the cab body color. Not really worried about stone chips and mud seeing how this isn't a daily driver.
Brad handshoe
Old 08-02-2015, 01:04 PM   #125
88fordf150
88fordf150's Avatar
Also picked up a new 3" driveshaft with solid u-joints.
Brad handshoe
