Old 08-16-2011, 06:51 PM   #101
Kim57
Kim57's Avatar
Re: Future gasser '57 chevy
Looking real nice. Love the color.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 08-16-2011, 07:54 PM   #102
Daze57
Daze57's Avatar
very very clean motor
Daze57 is offline   Reply With Quote
Old 08-20-2011, 11:53 AM   #103
WIDESIDE72
WIDESIDE72's Avatar
Your 57 is a SWEET truck, but don't take this the wrong way...I have to ask if those late model seats really go with the restof the gasser theme.
WIDESIDE72 is offline   Reply With Quote
Old 08-20-2011, 12:05 PM   #104
jayman68
Fun Stuff
jayman68's Avatar
Looks great. Fast progress, between post dates anyway.
Jay
68 C10(project)
88 Honda Accord(DD)
93 Chevy Astro EXT 2wd
jayman68 is offline   Reply With Quote
Old 10-14-2011, 10:31 PM   #105
509nat
509nat's Avatar
It took awhile to track down a windshield installer for my truck. I finally lucked out and found a father (Dave) and son (Chris) team and they got the job done. I installed new emblems as well.
509nat
509nat is offline   Reply With Quote
Old 10-14-2011, 10:42 PM   #106
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Thumbs up Re: Future gasser '57 chevy
Here is some inspiration 509nat
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
Old 10-14-2011, 10:57 PM   #107
509nat
509nat's Avatar
Thanks for the videos for inspiration!!!
Old 10-14-2011, 11:14 PM   #108
Kim57
Kim57's Avatar
The truck is looking good.
Kim
My build thread
Old 10-14-2011, 11:32 PM   #109
509nat
509nat's Avatar
Got the short stepside box from body and paint!
509nat
Old 10-15-2011, 01:32 AM   #110
jocko
jocko's Avatar
caramba, that's SWEET! First time I've seen this thread! Very nice truck.
Old 10-15-2011, 05:24 PM   #111
509nat
509nat's Avatar
Notice!
In the past few weeks I found out a few things after missing around with the frontend, where I added the 2" lift blocks to help raise the front height up and added the after market power steering kit. On the maiden road test found out real quick what bump steer and steering wobble are all about, which I discovered real fast. It was back to drawing board and research for answers. I still wanted the high boy look so I ordered new front springs fabbed with 6" archs. I also read an article on positive caster from a gasser link. I measured 0 degree caster on my exiting setup with a magnetic degee finder on the I-beam and the drag link had a 3.5" offset with pitman arm. The article mentioned using a 10 degree positive caster setup and making the drag ling parallel with with the pitman arm. I installed the new springs with 6 degree shims for now and corrected the drag link 3.5" offset to pitman arm. Waiting to do another road test to see if changes are headed in the right direction.
509nat
Old 10-15-2011, 05:38 PM   #112
entourageguy
Yellow truck club
entourageguy's Avatar
a little bit scary
Brian ......
My hub garage address
http://www.hubgarage.com/mygarage/59apache
I gue$$ everything has it'$ price
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
350 700r lokar shifter
power MII front end, shockwaves
tilt, 4 wheel discs
4-link and bags
10 bolt limited
entourageguy is offline   Reply With Quote
Old 10-16-2011, 10:35 AM   #113
Coupeguy2001
Coupeguy2001's Avatar
I would think a straight tube axle would cure a lot of the problems associated with your steering,. also a 1" block under the front springs is max..
The other thing that is alarming is where you put the front brake lines/ hose connections.
If you put them through the frame, and you possibly broke a leaf spring or rhe axle shifted position, the front brake line wouldn't be in the way of getting hit. The axle can't go any higher than the frame.
Just saying....
Other than that, I'm jealous.
small suggestions....
1. I would powdercoat the oval piece in the grille white instead of black....it would add to the whitewalls.
2. Paint the sheet metal under the grille blue . It would help the "complete" look of the front.
3. use seats that don't stick up in the rear window.
4. Add the 57 year only V on the doors. They kind of break up the slab look of truck doors since the doors are so tall.
But then, it's not mine, but I would do those things if it were.
Coupeguy2001 is offline   Reply With Quote
Old 10-16-2011, 01:32 PM   #114
509nat
509nat's Avatar
Coupeguy2001,
Thanks for chimming in on some very good points and suggestions. In the near future some more changes are in store for this project truck.
Old 11-08-2011, 03:15 PM   #115
509nat
509nat's Avatar
I took the truck out for a spin after re-doing the the suspension work and it drives three times better than before and much more stable! New pictures!
590nat
Old 11-08-2011, 04:26 PM   #116
509nat
509nat's Avatar
Pictures from bottom side!
Old 11-08-2011, 04:33 PM   #117
509nat
509nat's Avatar
Fenders and tailgate installed and other pieces!
Old 11-08-2011, 05:12 PM   #118
OrrieG
OrrieG's Avatar
looking good, that front end is just screaming for a Moon gas tank between the bumper brackets...
OrrieG is offline   Reply With Quote
Old 11-08-2011, 06:02 PM   #119
Kim57
Kim57's Avatar
Looks real nice. I agree with the Moon tank idea.
Kim
My build thread
Old 11-08-2011, 07:35 PM   #120
hopped up
hopped up's Avatar
i would changs those seats for some econoline buckets. also drop the rear a few inches.
hopped up is offline   Reply With Quote
Old 11-08-2011, 07:58 PM   #121
1Bad62Pro/Street
Talking Re: Future gasser '57 chevy
Did you lite the tires up a little?
Old 11-08-2011, 08:25 PM   #122
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Moon tank and lower seats and it would be perfect but as it sits right now its *****in looking..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 11-09-2011, 08:47 AM   #123
robozride
Am i missing something here? I see that there is a cross member under the bellhousing... but dont you need a cross member for the tail shaft?
robozride is offline   Reply With Quote
Old 11-09-2011, 10:35 AM   #124
longbike
longbike's Avatar
Oh man that looks so good what a great color!
Do you remember what where you got your front fender lower patch panels from? they look like they fit up perfectly!
longbike is offline   Reply With Quote
Old 11-09-2011, 11:30 AM   #125
Yezzi
Yezzi's Avatar
Nice work! Everything looks great! You should be able to see everything with those seats : )
Yezzi is offline   Reply With Quote
