Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1988 - 1998 GMT400 Chevy & GMC Pickups Message Board > projects and builds 88-98
Old 09-10-2010, 04:46 PM   #101
69c10stepside
Large Member
69c10stepside's Avatar
Re: '89 GMC C1500 build thread
Back to work on this thing.. Recently promoted at work, and at the same time, been adding about 15-20 hours a week to my schedule there. Go figure. Will get some updates going on this thing in the next month, weather is starting to agree with my wanting to work.
1989 GMC C1500 ECSB
1972 Gmc Jimmy
1972 Chevy C10 SWB Sold
69c10stepside is offline   Reply With Quote
Old 12-17-2010, 11:51 PM   #102
greystoke
Made any progress on this beauty?
"Fear makes the wolf look bigger"
http://67-72chevytrucks.com/vboard/s...d.php?t=305629
greystoke is offline   Reply With Quote
Old 12-19-2010, 01:33 AM   #103
89chevsj
error 404
89chevsj's Avatar
I've been curious about how a 94-98 door panel looks with the older dash pics anyone?
89 Chevy swb 350 "SJ" DD turned parts truck. SOLD
90 Chevy ext cab loooongbed. "storm trooper" Rust In Peace.
06 Kia sorento wife's car
06 charger srt8 "lucifer" my toy
'12 Kia optima
89chevsj is offline   Reply With Quote
Old 12-21-2010, 09:10 AM   #104
scotts62
One day...
scotts62's Avatar
I put a '95 door and panel on my crew cab but just havent changed panels yet, it looks ok i guess..
Ill try and snap a pic later.
Scott
93 crew cab build
Project 62
Old 01-04-2011, 05:00 PM   #105
69c10stepside
Large Member
I do have the rearend lined out for the truck now, have all the materials to paint the truck, going to refocus on the dash layout with the moonies, even if I have to take it all out and put it at my desk at work!
1989 GMC C1500 ECSB
1972 Gmc Jimmy
Old 03-13-2011, 06:46 PM   #106
69c10stepside
Large Member
Typed up all that I did to the truck this weekend, and I guess I took too long and my page timed out when I went to post it.
Anyways, removed the fuel tank and installed the fuel pump that I am going to use. I am going to use a fuel cell now I guess, after seeing some possible issues with the header on the driver side of the transmission and routing of the exhaust back from it. I plan on using a fuel cell from summit, 20g aluminum.. Anybody have any good guides for installing a fuel cell? Never have done one before..
1989 GMC C1500 ECSB
1972 Gmc Jimmy
Old 03-27-2011, 09:30 PM   #107
69c10stepside
Large Member
Updates.. I scrapped the idea of making the moonies work in the dash. Not that I couldn't do it, just don't have the patience for it anymore!
Bought a set of autometer arctic whites to put in it, and started the template for them. Forgot to order the tach with them when I bought them, but I went ahead and set the template up for where it works, I think. The pictures show how it looks as where I usually have the steering wheel while I am driving.
Also bought some seats out of a 2005 gmc regular cab and put them in, now I am trying to decide if I am going to highlight spots of my dash with the charcoal grey color, redo it all in charcoal grey, or.. who knows.
Also bought a 20 gallon aluminum fuel cell from summit, haven't done anything with it yet as my bed is still off.
1989 GMC C1500 ECSB
1972 Gmc Jimmy
Old 03-28-2011, 09:32 AM   #108
Richie
4:13
Richie's Avatar
Just read this whole build.Wow,great job.I like the grey two tone with what you have now but if it were mine I would have it all grey.Maybe light/dark charcoal.I have just never been a fan of red/maroon.But that is just me.Others like it and hate blue.I just happen to like the blue/green side of things.Either way,grey goes with everything.I think you are doing a great job.It will look good with those guages.As far as the fuel cell goes,I would think between the rear frame rails would be a good place to start.If you weren't keeping the spare tire it would probably fit there or mount it to the bed floor right behind the cab.Good luck and can't wait to see more.
Richie is offline   Reply With Quote
Old 03-28-2011, 03:59 PM   #109
69c10stepside
Large Member
The more I think about it, the darker I want it to be. I really liked the dash it had in it from factory with the two different colors of red/maroon/burgandy whatever it was, but I think that it should be more of a out with the old and in with the dark. Maybe go with the idea of the two tone but black/charcoal grey. Need to figure out what I am going to do with the headliner in that situation, I am not sure if the dye would cause all of the glue to release or not.
1989 GMC C1500 ECSB
1972 Gmc Jimmy
Old 03-31-2011, 11:48 AM   #110
69c10stepside
Large Member
For the rearend.. going to use a 14 bolt 6, 3.73 gears. Taking axles out to have them welded and redrilled for 5x5. Center hub on axle is 3" wide where hub opening on my wheels is around 3.5". Ditching the huge drum brakes, will find a viable disc brake solution for it.
Found a vacuum leak, which would explain my random issues I had with fast idle.
1989 GMC C1500 ECSB
1972 Gmc Jimmy
Old 04-06-2011, 10:57 PM   #111
69c10stepside
Large Member
Had an hour or so to burn tonight to work on the pickup.. The hour turned out to be a lot longer then what I thought.. Test fitted how the tach would look in the dash, I don't quite have everything outlined out right, but it is close.
Also started/finished the install of my shifter, and really like how it turned out.
Finished test fitting fuel cell and related parts.
:edit: Sorry for the bad quality pictures, blackberry isn't good for many things, and for sure isn't good for pictures!
1989 GMC C1500 ECSB
1972 Gmc Jimmy
Old 04-09-2011, 07:58 PM   #112
69c10stepside
Large Member
More pictures..
Have everything mounted the way I am going to keep it now, and I am about 75% done with the wiring of everything for the gauges.
I am still undecided as to how I am going to do my dash color, the red/grey combination that is in the pictures is growing on me. I figure I will do something along those lines.
1989 GMC C1500 ECSB
1972 Gmc Jimmy
Old 04-13-2011, 06:41 PM   #113
69c10stepside
Large Member
Here are some pictures of what I think I am going to be doing with my dash colors.
Finally got the wiring done to my gauges, everything short of hooking up the speedometer. Here is another rough picture (I know I need to just take my digital camera to the shop and leave it for some good pictures!) of the lights working on the gauges, I think I am going to use the green caps on the lights.
1989 GMC C1500 ECSB
1972 Gmc Jimmy
Old 04-13-2011, 07:12 PM   #114
gmt400
gmt400's Avatar
You did an awesome job on the swap and still maintaining much of the origional parts like the temp controls and column. Nice job on the gaugues too they look right at home but to be brutally honet The colors look out of place.
gmt400 is offline   Reply With Quote
Old 04-13-2011, 07:16 PM   #115
greystoke
that looks great, what was involved with the wiring? for instance the ac controls etc.
Old 04-13-2011, 09:16 PM   #116
69c10stepside
Large Member
Are you talking the colors of the dash/doors together? I didn't like it at first, but I changed my mind once I seen it outside! I will have to get some pictures of the interior outside of the shop (light inside is terrible) and see if that helps you see it the way I do. I am still trying to figure out what I am going to do to make the column work, I do have one for this style dash that I can use as a template to get some sort of spacer made.
Still have the '89 model wiring, just put the 96 dash over the top of it. So there wasn't much wiring other then on the gauges.
Added a picture, a frontend I haven't seen in a while, just for the sake of doing it.
Keep the questions/feedback coming, it helps me keep on keeping on.
1989 GMC C1500 ECSB
1972 Gmc Jimmy
Old 04-13-2011, 11:26 PM   #117
19723DR
19723DR's Avatar
Truck is coming together nicely.
I have the same dark red and gray interior pieces. I did notice when you armoral the dash it darkens it and makes it look a lot better. You could always dye whatever color you want, too. The gauges look really good as well.
72 Suburban 3 Door http://67-72chevytrucks.com/vboard/s...d.php?t=265728 family fun cruiser
71 Cheyenne Project http://67-72chevytrucks.com/vboard/s...d.php?t=299232 Almost finished
93 Silverado http://www.67-72chevytrucks.com/vboa...d.php?t=378258 Flamed, bagged, body dropped on 22's
98 Chevy short bed DD
97 Z71 3 Door
51 Suburban-S-10 swap
"What other hot rod can you carry 7 of your friends in"
19723DR is offline   Reply With Quote
Old 04-14-2011, 09:14 AM   #118
1967bigdaddy
1967bigdaddy's Avatar
Love the picture of that grille and hood, it looks dam tough. Like a beast ready to pounce. I'm assuming your going with a black bumper on that set up..... Right or wrong?
1967bigdaddy is offline   Reply With Quote
Old 04-14-2011, 09:25 AM   #119
69c10stepside
Large Member
Black bumper yes, anything past that I don't know yet. Really eyeing some insert and/or light bumpers.
1989 GMC C1500 ECSB
1972 Gmc Jimmy
Old 04-14-2011, 09:37 AM   #120
1967bigdaddy
If you go with lights in the bumper I,... know this is just me, but I would get them smoked. Keeping it looking tough.
Old 04-17-2011, 02:14 PM   #121
69c10stepside
Large Member
Pictures of the interior in the sun, with a good camera as I said I would do.. first 5, have 2 more to post..
1989 GMC C1500 ECSB
1972 Gmc Jimmy
Old 04-17-2011, 02:20 PM   #122
69c10stepside
Large Member
Looks different compared to the previous pictures of it I think. Still going to work the door sills, kick panels. Then take the door panels off and get the door jams/inside door skin painted.
1989 GMC C1500 ECSB
1972 Gmc Jimmy
Old 04-17-2011, 02:30 PM   #123
gmt400
gmt400's Avatar
Well after seeing it complete I think colors work nicely looks awesome. By the way I dont know where you plan on putting the cd player but that make a delete pocket for the cd slot that turns it into a cubby hole. I bought one for my 95 but I havent decided where I'm going to relocate it maybe in my center console or glove box.
Old 04-17-2011, 02:45 PM   #124
69c10stepside
Large Member
I am thinking of some kind of multimedia/monitor setup for the dash, hooked up to an itx type pc, that is hooked into my msd ignition. That is what I am planning on doing, but I have changed my mind so many times on everything else, who knows.
1989 GMC C1500 ECSB
1972 Gmc Jimmy
Old 04-25-2011, 01:39 PM   #125
69c10stepside
Large Member
No updates yet, haven't had much time to get anything done with all of the rain and work schedules.. Did get this though, makes it all worth while!
1989 GMC C1500 ECSB
1972 Gmc Jimmy
6.0, l92, lq4, ls1, vortec
