Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 04-11-2010, 08:50 AM   #101
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
Re: Pro Street Trucks/Cars pics!!! im in love with the fatty tires!!
Originally Posted by Hart_Rod View Post
I'm guessing you didn't have any clearance issues? Yours are 14" wide correct?
hey Rob I pretty sure he is running a shortened axle and custom wheels...I'm jealious...but IMAO I have the biggest tire and wheels you can cram under with a stock axle and frame....
I could be wrong but I dont think you can put the 18.5 wide tires under our trucks if they are dropped
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Old 04-11-2010, 09:03 AM   #102
prostreetC-10
My Carbon Footprint
prostreetC-10's Avatar
Ah Grasshopper......
those are 14" and that is a bone stock 12 bolt with zero narrowing. Look in my signature at the "my sorta build thread". You will see how the magic unfolded!!!!
prostreetC-10 is offline   Reply With Quote
Old 04-11-2010, 12:18 PM   #103
Hottrucks
Hottrucks's Avatar
Ahhh Not only did I read your build ( about 5 times) I could have writen it after I copied everything on my build...your budget build must have been shot in the AZZ after buying custom wheels....Keep in mind
Sherwood Racing ( owego ny 607-687-2991) will cut and add backspacing for about $50 a wheel.....told you I'm on a really low budget ..But you still get a gold star for making it work....
do you have 18x 29 or 31?? with the 31's I rub the inner bed sitting on the frame..with the 29'' alls good but like you I'm looking for another cheap set...
funny our build pics and what we are doing is almost Idenical except I'm going with the caddy to bad we don't live closer it would be great to see them side by side.....with a Xmas tree between them!!!
Old 04-13-2010, 08:21 AM   #104
prostreetC-10
My Carbon Footprint
They are 29 x 18.5's
Just one other though. First of all, the back wheels were about $150 each which seems cheap to me for custom built. The problem with adding to the backspace is that you have to go with what ever the front spacing is.....you can't change it. That was critical for me getting everything to fit right. It also seems kinda tricky to get a wheel perfectly straight and true doing it that way. Then again.....I can't believe what they can do now a days. Mines would have rubbed too if I didn't shorten the front spacing away from the fender wells. I also know that "budget" can be a huge determining factor......that's why my truck looks like it does!!! LOL
I'll just leave you with this and this is not to anything specific. Never sacrifice safety for looks! I can't believe the death traps that are on the road. Nice truck though!
Old 04-13-2010, 08:39 AM   #105
Hottrucks
Hottrucks's Avatar
I agree...those guys do tons of race car wheels..I don't know them personaly...but they will do what ever you want to a wheel and there prices seem really fair compaired to new ones I ought all 4 rallies for $50 so I figure I have about half the $$ of a new one whick works well with any budget..I'm sure they could move the center to make up any off set I wanted but I have no idea what it would cost..I'm sure your getting closer to a new one...My big thing was to keep the stock 6 lug rally LOOK and these wheels ( with 16 holes) arn't available in other widths ( that I could find or afford)
As far as safety its always #1..I have done alot of dumb stuff but I always try to build in safety first...I don't bounce like I use to?? or heal??
I think you and I are on the same page on sooo many things..........
Jeff
sorry for the highjack
Old 04-13-2010, 08:44 AM   #106
prostreetC-10
My Carbon Footprint
That's funny.....I thought it was your thread until I went to the first post. Ooops!
......and now back to those pro-street pics!
Old 04-13-2010, 09:10 AM   #107
Hottrucks
Hottrucks's Avatar
ok if you insist....tubs are done and I even painted the tail gate and inside of the bed (I should have used flat instead of satin??)
Old 04-14-2010, 02:27 PM   #108
Hart_Rod
Hart_Rod's Avatar
No clearance issues at all because I did all my cutting and welding first, then just ordered the wheels to fit perfectly. Yes, 15x14's.
How tall are your current tires? How much lower could you go in the back and still have good clearance?
Hart_Rod is offline   Reply With Quote
Old 04-15-2010, 12:12 AM   #109
prostreetC-10
My Carbon Footprint
Rob,
They are 29's. I have a little more room acutally. There is also so room for fab work on that little piece of metal that goes from the outer fender lip (it's tack welded from the factory) to what the fender actually bolts on to. The reason I'm not lower it because of the suspension itself. I don't like the pinion angle and I even have angled shims.
Once I get a few things done on the 67 Fastback, I'm going to cut off all the brackets on the 12 bolt and four link it. Then I can really get down and have good driveline alignment at the same time. One thing always leads to another though. When the drive train alignment changes, so will the header angles which means I will have to have my nice exhaust redone....at least a little. At the same time I will go to spindles and disc brakes up front. This way I can get a good portion of my drop out of the spindles. As you can see, it's a can of worms so I am holding off and just driving the darn thing for now!!!
Old 04-15-2010, 07:36 AM   #110
djracer
djracer's Avatar
Mike Nutt told me if you drop the rear much you need to flip the trailing arm brackets in the front and that helps some. I'm assuming you still have trailing arms I didn't look.
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 04-15-2010, 09:10 AM   #111
prostreetC-10
My Carbon Footprint
You are right. That's why I'm not getting under there again until the bed is off and I'm linking it. Unlike leaf springs, the rear end doesn't go up into the chassis in a straight line with these trailing arms. I have seen so many dumped trucks with the most jacked up geometry under there. If I would have caught it before I had my custom exhaust done I would have fab'd a trans crossmember to get me just a few degrees more and the back end. The cool thing is that I should have just enough drive line yoke left for the change down the road.
Old 04-15-2010, 09:15 AM   #112
prostreetC-10
My Carbon Footprint
BTW Mr. Kevin....every now and then I have to go back and watch your PT video. I remember the first time I saw that. Me crapped me pants. That dude left hard. What's that thing weigh....3,800??
Old 04-15-2010, 10:12 AM   #113
djracer
djracer's Avatar
It was 3200 with me in it but it should be lighter when it goes back together.
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 04-15-2010, 10:28 AM   #114
prostreetC-10
My Carbon Footprint
With you? Hmmmm....there has been some metal leaving that truck somewhere. That's pretty light! Is there a ton of glass panels on it??
Old 04-15-2010, 11:43 AM   #115
djracer
djracer's Avatar
Race Weight, glass nose, glass doors, fatman mustang II frontend, Bed Skin only. Tom had the truck down to 3275 with him in it with only a glass hood when it was a blue stepside.
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 04-15-2010, 12:29 PM   #116
Yukon Jack
Post Whore
Yukon Jack's Avatar
Lots of sweet trucks!
Here are a couple pics of my buddy's 65 C10
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 04-15-2010, 05:40 PM   #117
Hottrucks
Hottrucks's Avatar
you guys bring up some valid points ..when you switch to cup car arms you can shim them also (there 2 piece) they also have a P bar mount on the DS TA you guys have seen it in my pics ( but 12" wheel is all you can have) I madwe my new P bar 42" long and mounts on the outside of my frame on te PS..my side travel is very small and tucks the wheels dead center on the frame......as far as the inner bed you could make a cut just under the bolt holes for the wheel tub and push it in and make a small filler panel..this would cure my issues even with the 31's
is anyone still running a 2 piece DS??? I plan to swap to 1 piece when I add the caddy trans ( 13" tailshaft) that will eat up some of the pinion angle too
and PS10 when io get home from Fla I plan to open that exact can of worms...motor,exhaust,ds angle, Drop spindles with disc...I hope it will be my last can of worms..they're getting expncive???
Jeff
Old 04-15-2010, 09:08 PM   #118
regan wilson
regan wilson's Avatar
Lightweight..........Im just jealous (spell check)
NHRA Super Street 469C
It only runs 10.90 at 156 mph
regan wilson is offline   Reply With Quote
Old 04-15-2010, 09:13 PM   #119
regan wilson
PSC-10 I really like your truck I bet its lots of fun with the 4 speed . When I had a 4 speed I was running a small block . I would be getting alot of tickets with your ride .
Old 04-17-2010, 08:39 AM   #120
prostreetC-10
My Carbon Footprint
Oh.....it's more than fun! I could NEVER see this particular truck with an auto. I am a downshift freak. I love pulling up to the cruise and going 4th......3rd....2nd.....and so on. It's also fun because 4 speed rigs "bump" through the parking lot just a little different than an auto car, especially if you have a little stall.
Main reason I bucked-up for the M-22 is so I could cross out the 42 yrs old on my driver's license and pencil in 19, not worrying about breaking anything. I just love banging 2nd and getter 'er all sideways when I have a passenger. Greatest thing about being the driver is that only you know what all hell is about to "break loose".
Thanks for the thumbs up!!
Old 04-17-2010, 10:22 AM   #121
Hottrucks
Hottrucks's Avatar
^^^^Dont ever think about doing that with me in the truck
unless you know where 3rd is because after your done warming them from hitting 2nd your going to find my foot on top of yours and the R's are going to climb fast!!!
just give me time to X out the 45 on my drivers lience
Old 04-17-2010, 12:39 PM   #122
prostreetC-10
My Carbon Footprint
Careful or we'll be high jacking this again! lol
Old 04-17-2010, 12:58 PM   #123
Super73
Super73's Avatar
Regan,
I'm a little jealous as well, but 3,600 with me in it all steel aint bad.. I'll get it near Kevin's one day. i know there is 200lbs with a tailgate swap and a powerglide.
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 04-17-2010, 06:34 PM   #124
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Thumbs up Re: Pro Street Trucks/Cars pics!!! im in love with the fatty tires!!
Guys.....................
I know this isn't a Chevy Truck but.......................
I don't think any of you fellas mind seeing some Fat Hides stuffed away in an old 1956 Nash Metropolatan with a monster engine in it!!!!!!!!!!!
1956 Metropolatan "Metronator" w/ blown 502 Chevy.
[CENTER]
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
Old 04-18-2010, 10:04 AM   #125
prostreetC-10
My Carbon Footprint
Sometimes I just ask myself "why?". Was this the only thing he had lying around? What is that a 45" wheelbase?? LOL
