Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > Vendors Marketplace
Old 01-16-2011, 01:07 AM   #101
Mieser3
Mieser3's Avatar
Re: D52 Caliper Rear Disc Brake Brackets
Just ordered a set of brackets for my project. Thanks for all of your help John......looking forward to getting the brackets.
Jay
1956 Chevy 210 Sedan
1970 Camaro Z-28/RS
1970 Chevelle SS 396 (numbers matching L34 car)
1971 Chevy SWB Fleetside with 1967 front clip - in progress
My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=438156
Mieser3 is offline   Reply With Quote
Old 01-20-2011, 01:06 PM   #102
Mieser3
Mieser3's Avatar
Received my brackets today. Can't wait to get them installed on my project. Very impressed with the quality of these brackets.
Thanks John.
Jay
1970 Camaro Z-28/RS
Old 01-21-2011, 01:47 AM   #103
Captainfab
60-66 Nut
Thanks for the purchase Jay. Post some pics when you get them installed
Old 01-30-2011, 10:49 AM   #104
Greywolf200
Greetings Captain,
Is there any problem with redrilling the disc to retain the 6 bolt pattern? I want to keep my truck pattern on my '70.
Thanks,
Jack Byrd
'70 Chev Custom SWB(new to me), 307CID(added Weiand Stealth, headers and Edelbrock Performer carb, up to 17 MPG now), 700R4
'76 Airstream Argosy MH(want a longer one), 454CID, TH400
Greywolf200 is offline   Reply With Quote
Old 01-30-2011, 11:23 AM   #105
Greywolf200
I just ran across an article that said that the rear disc for a 14 bolt diff has the ebrake and the same fit as the Eldorado. Do you know anything about this?
Thanks'
Jack Byrd
Old 01-31-2011, 12:07 AM   #106
Captainfab
60-66 Nut
Redrilling a 5 hole rotor to a 6 hole rotor may be a little tricky. One of the holes for the 6 x 5.5" hole pattern overlaps one of the 5 x5 holes. So at least that one hole will need to be filled.
Just bare with me a few days and I should have something for you later this week on a 6 hole rear disc conversion.
I've not heard this about the rear calipers for the later model 14 bolts. I'll check into that. Do you have a link to this article?
Originally Posted by Greywolf200 View Post
Greetings Captain,
Thanks,
Thanks'
Old 02-01-2011, 10:46 AM   #107
Greywolf200
Rule #1----Don't believe everything you read on the internet!
I checked into the story about the Eldorado caliper on the 14 bolt axle. It seems he needed a caliper on the front of his truck and tried it and it fit(apparently an older truck) and there you go....... He published it on the internet, I guess because Eldorado rear calipers are so easy to find when you need a caliper for your truck.
Sorry for the goose,
Jack Byrd
Old 02-11-2011, 10:44 PM   #108
54Caddy
GM Addicted
54Caddy's Avatar
captinfab, i plan on ordering your brackes soon and will be using the wilwood calipers on all four corners. I am going to be running 15x6 stock steel wheels. Will they clear the calipers with no rubbing issues??
..Mac’s Garage..
73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd
My 73 GMC Truck Build Pic
2010 Silverado 4/6 on 24s
IG:MacsGarage
54Caddy is offline   Reply With Quote
Old 02-12-2011, 05:47 PM   #109
Captainfab
60-66 Nut
The only wheel I have fit up on this rear disc conversion is a 15 x 8 Rally wheel. As long as your wheels are disc brake compatable, I don't see why they wouldn't clear the calipers.
Old 02-12-2011, 06:34 PM   #110
Greywolf200
Hello Captain,
I did a little brousing and it looks like a '96 K1500 6 bolt rotor will work with your set up if you make the spacer 5/8" thinner.
Jack Byrd
Old 02-13-2011, 01:20 AM   #111
Captainfab
60-66 Nut
I replied to your post in the 6 lug rotor thread.
Hello Captain,
Old 03-05-2011, 02:23 PM   #112
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
so is the application on the rotors for the front or rear???
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Old 03-06-2011, 12:15 AM   #113
Captainfab
60-66 Nut
They are the fronts for the AWD Astro/Safari's. They didn't come with 4 wheel discs until 2003-2005. At which time they were a 6x5.5" wheel bolt pattern.
Old 03-12-2011, 01:18 AM   #114
inovermyhead
Got mine in today. Thanks again for taking the time to answer all my questions.
81 GMC C15 RC SWB 5.3L 4L80E project
inovermyhead is offline   Reply With Quote
Old 03-14-2011, 12:52 AM   #115
67chevy1series
67chevy1series's Avatar
Originally Posted by Captainfab View Post
Here are a few pics of the OEM D52 calipers. These are available in two different piston sizes. The JD5/JB5 calipers have a 2 15/16" diameter piston and the JD7/JB7 calipers have a 3 5/32" diameter piston. If you need a E-brake these can be found under the application of rear calipers for the '76-'78 Cadillac Eldorado. The A1 Cardone part numbers for these are 16-4116 and 16-4117. Those are loaded calipers.
that right there is what i want on my truck the 76 78 eddorado calipers with e brake cables so i need these brackets in order to fit the caddilac calipers right? once agian rewally sorry for how man questions i am askin
67chevy1series is offline   Reply With Quote
Old 03-14-2011, 01:00 AM   #116
Captainfab
60-66 Nut
Yes these are the brackets you need to use the '76-'78 Eldorado calipers
Old 04-24-2011, 04:53 PM   #117
Speedy1967
Can you please send a paypal invoice to fanceeeface@ yahoo dot com for the D52 rear brackets? Thanks!
Speedy1967 is offline   Reply With Quote
Old 04-24-2011, 09:47 PM   #118
Captainfab
60-66 Nut
Do you want them in bare steel or powder coated?
Old 04-25-2011, 08:08 AM   #119
Speedy1967
Bare steel will work fine.
Old 04-26-2011, 12:13 AM   #120
Captainfab
60-66 Nut
Invoice sent.....Thanks
Old 04-26-2011, 02:08 AM   #121
Captainfab
60-66 Nut
Wheel stud info posted here......
http://www.67-72chevytrucks.com/vboa...1&postcount=23
Old 05-16-2011, 04:43 PM   #122
truckzilla
truckzilla's Avatar
If the D52 caliper fits early 80's C10s and C20s, any idea of why not the C30s?
truckzilla is offline   Reply With Quote
Old 05-16-2011, 11:21 PM   #123
Captainfab
60-66 Nut
Well I don't have any firsthand experience with the single wheel C30's, but with the dually C30's, they use a totally different caliper than the D52. It is much bigger and mounts differently.
Old 05-17-2011, 08:22 AM   #124
madcow75
madcow75's Avatar
What caliper is used with a C30 disc conversion. Want to keep e-brake type caliper. I will be also using 16" facory steel wheels
madcow75 is offline   Reply With Quote
Old 05-17-2011, 06:01 PM   #125
truckzilla
truckzilla's Avatar
Thanks Capt'n! Any idea of a front brake improvement for the early '80s C30 duallys?
