Old 09-12-2010, 06:20 PM   #101
sgtusmc
sgtusmc's Avatar
Re: SGTUSMC '59 build
Originally Posted by Woodbutcher View Post
Nice little trick there, Sarge. the simplest of ideas usually work the best.
ERRR...I'm a bozo! After flipping the perch I noticed my pinion angle was WAY off. I had to flip them back and weld up the holes. So now I'm back to head hunting ants on the black top.
My build, 53 GMC / S10 swap
http://67-72chevytrucks.com/vboard/s...d.php?t=305723
My build, 59 Chevy / 88 fullsize swap
http://67-72chevytrucks.com/vboard/s...hlight=sgtusmc
U.S. Marines - Certified Counselors to the 72 Virgins Dating Club.
sgtusmc is offline   Reply With Quote
Old 09-13-2010, 12:53 AM   #102
OrrieG
OrrieG's Avatar
Couldn't you wedge the perch between the spring and housing? Done on lifted 4wd trucks...
OrrieG is offline   Reply With Quote
Old 09-13-2010, 08:06 AM   #103
britnjc
britnjc's Avatar
yeah just get get a pinion angle corrector. they are made for dropping or lifting applications. They are like a drop block but a wedge. I's sure you have seen them..
britnjc is offline   Reply With Quote
Old 09-13-2010, 10:23 AM   #104
sgtusmc
sgtusmc's Avatar
I have a couple wedges that came with lowering/lift kits that I didn't use and a few angled drop/lift blocks. On the rear I used a flip kit. I just don't like the idea of adding a wedge or block to it. I'm sure it's safe but I had a block shatter on me in the 90's in a Nissan truck. When I pull the rear-end for paint I'll yank out a leaf or two. They also make drop hangers for the rear perches that I could use to get lower. Since my wife will be doing most of the driving I want her to still be able to drive it home if there's a bag failure. I must be getting old if I didn't notice the pinion angle facing the sun. I'm just glad I caught it and not someone else.
Old 09-13-2010, 06:15 PM   #105
OrrieG
OrrieG's Avatar
I ran 4" Rancho lift blocks on my rear with couple of degrees angle built into them from 1985 to 1998 without any problems. Drove it daily and on some pretty knarly off-road stuff, fording streams, etc. Mine are solid cast steel with pin and hole for locate on the spring and housing. Speedo didn't work but I estimate it was about 50 K miles because I went thru 1.5 sets of tires.
Old 09-17-2010, 01:29 AM   #106
sgtusmc
sgtusmc's Avatar
Mocked up the front end today. I'm surprised how it all fell together. There's only one bolt per fender holding it all together. I will have to fab up a rad mount and cut the sheet metal for access to the rad filler (going to use the 88 rad). Doesn't look like I'll have to cut the frame horns. I'll have to join the 88's bumper brackets to fit the 59 bumper. It looks to easy...I think I just jinxed myself!
Old 09-17-2010, 08:34 AM   #107
Kim57
Kim57's Avatar
Looking good.
Kim
Kim57 is offline   Reply With Quote
Old 09-17-2010, 09:31 AM   #108
bjcaldwe
bjcaldwe's Avatar
Coming right along.
My AD Truck Build Thread
52 GMC one day laying on the running boards
2004 Chevy Crewcab. 3/5 and notched
bjcaldwe is offline   Reply With Quote
Old 10-07-2010, 03:35 PM   #109
sgtusmc
sgtusmc's Avatar
I've been giving the wife some welding lessons for about a week now. I tacked the old tailgate to the bed. To keep it somewhat square while mocking up mounts and such. I ordered a new tailgate & hinges. I spent the good part of a day removing the broken tailgate hinge bolts and welding in new cage nuts.
I left the wife out in the garage for a while. When I came out, she said she finish welding the tailgate up for me. She welded both sides, also laid a fat bead on the inside. It took all I had to keep from cry'n. Here's her handy work. Not to bad I guess...hahaha
Old 10-07-2010, 04:14 PM   #110
bobinbc
bobinbc's Avatar
She did a good job! ROFLMAO
But really, a little careful grinding and you'll be good as new....
The best part is at least she's interested in it! Mine doesn't like to go in the garage when I'm welding and grinding because "it smells awful" , sigh
1962 Chevy blue SBFS
1957 Chevy yellow SBSS
1956 GMC red SBSS Nov 2017 ToTM
https://www.facebook.com/groups/Cana...geChevyTrucks/
bobinbc is offline   Reply With Quote
Old 10-07-2010, 05:21 PM   #111
sgtusmc
sgtusmc's Avatar
I guess I bought a new tailgate to mount to my garage wall. Were just gonna have to go tailgate-less now. As much as I wanted to scream and yell...those days are over. (lucky her!)
Old 10-07-2010, 07:57 PM   #112
Panelman55
Panelman55's Avatar
Now its time to teach her how to grind a weld off. I have trouble getting my wife even close to my truck. There is no way she'd ever consider working on it.
In God We trust!!!
Panelman55 is offline   Reply With Quote
Old 10-08-2010, 12:31 AM   #113
Kim57
Kim57's Avatar
I honestly like the tailgates welded up. I built a custom bed for mine and eliminated it.
Kim
Old 10-08-2010, 12:18 PM   #114
sgtusmc
sgtusmc's Avatar
Kim
Yeah, I like em to. It's not like I was going to have a deep bed to work with and use it as a real truck. I just wish we could have used the new gate. The old one is in pretty bad shape. I gave her the ol "that looks great honey" the last thing I want to do is make her feel bad out in the garage...haha
I did some sanding & grinding between the bed and gate that needs attention (paint). I have no clue how to get paint in there now.
I did mention to her that the new front bedside will not see any welds. I have to remember not to tack the doors. Last thing I want is to "Dukes of Hazzard" my way in every time.
Old 10-08-2010, 03:54 PM   #115
CAL 58 GMC
CAL 58 GMC's Avatar
Hey Sarge, It's been some time since I was on your build thread and I got to say your truck is really coming along nicely! I like the flip hangers and your wife's welding! Keep up the good work man, I can see it's paying off so far.
CAL 58 GMC is offline   Reply With Quote
Old 10-08-2010, 04:24 PM   #116
bobinbc
bobinbc's Avatar
By the way, cool pics. I sure wouldn't want to be a 18-20 yr old on the receiving end of that....
Old 10-10-2010, 10:40 PM   #117
sgtusmc
sgtusmc's Avatar
Added a floor today.
Old 10-10-2010, 10:58 PM   #118
nickp51chevy
Registered Chevy Owner
nickp51chevy's Avatar
I'd swear that you're a pro builder with the thing that you're doing on this build.
Love is fleeting, but Chevy trucks are forever!!!!
1970 Chevy CST C10 long box 350/400
2008 Chevy Silverado short box 4x4
Had;
1951 Chevy short box 307/T5
1988 Chevy shot box 4x4 350/350
1971 Chevy C10 long box 4x4 350/350
1971 Chevy C20 long box 350/350
1971 Chevy C10 long box 350/350
nickp51chevy is offline   Reply With Quote
Old 10-10-2010, 11:56 PM   #119
sgtusmc
sgtusmc's Avatar
Naw Nick, not even close my man!
Old 10-11-2010, 12:46 AM   #120
OrrieG
OrrieG's Avatar
What is the donor for the bed floor? I've always wondered if a later model metal bed floor would work. You are making great progress.
Old 10-11-2010, 01:03 AM   #121
sgtusmc
sgtusmc's Avatar
It's the bed from the donor truck (88 Silverado long bed). The inner width is almost perfect. The bed has floor cross braces welded in. If my frame rails weren't so high I could have used the whole thing. On a stock 59 bed I'm sure it would fit nice. Let me know Patrick if you'd like some measurements and pic of the 88 bed.
Old 10-11-2010, 01:22 AM   #122
Woodbutcher
Woodbutcher's Avatar
A 58 parts tgruck that BobinBC and I parted out had a welded in box floor out of a later model. Looked pretty good. To the uneducated it would look stock. Not a bad idea if you are allergic to wood.
If the women don't find you handsome, they should at least find you handy... Red Green
Keep your stick on the ice, Woodbutcher
Woodbutcher is offline   Reply With Quote
Old 10-29-2010, 10:12 PM   #123
sgtusmc
sgtusmc's Avatar
I finally got my white walls buffed and mounted to my rims. Tires are BFG 155/80/15 on 15x5 rim and BFG 205/60/15 on 15x7. Hope to get them mounted sometime tomorrow. They came out pretty nice. Now I need to find some beauty rings and some sort of caps.
Old 10-29-2010, 10:35 PM   #124
nickp51chevy
I'm thinking about getting some of these for my truck, and I'm sure they would look just as good on that one
Had;
Old 10-29-2010, 10:47 PM   #125
LEEVON
LEEVON's Avatar
pass on the spider caps, they are overpriced and fit like crap. bullet lugs and shannon cones look about the same and are easy as pie.
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
