Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1967 - 1972 Chevy/GMC Suburbans & Panels Message Board > 1967 - 1972 Chevy/GMC Suburbans and PanelsProjects and Builds
Old 03-07-2012, 10:26 PM   #101
Mulk
Mulk's Avatar
Re: Mulk's 8-Lugger
Alright.... It's been a while since I posted any updates, I have gotten a few things done, but mainly I've just been enjoying driving the beast around again.
However, I was able to get over a serious hurdle that has been racking my brain for a while. If you've been keeping-up, you know I suicided the third door, and moved the handle along with it. Due to the proper placement of the handle so it looked factory and matched the passenger door location, I wasn't able to simply make the push-button work. Not to mention the window and track would interfere anyway. So I just went the easy route and installed a seleniod to pop the door (sometimes).... That was the hurdle
My mind started working and I wasn't going to give-up....
I took the canteleaver part, that used to connect the lock button rods, and made a few modifications. I welded a tab for the push-button to activate (welded the washer on the face of it to help keep the rod on the button centered.) This piece mounts though one of the holes that the factory hinges used to utilize.
You can see here the tab and washer in place.
I then had to get creative with the rod, to get it to reach from the canteleaver, and clear the window track. Just a few, not so simple, bends added to the same rod that used to lock the door (use as many factory parts as possible)
I then drilled some small holes in both ends, so I could run a cotter-pin through, to keep everything in place. This is where the rod connects into the bear-claw actuator, finishing the link. I had to ct a hole to be able to access this mess, but it's covered by the door panel
So now I can open the door from the outside, using the handle, and the seleniod has been added to the "left-over" box. Oh, and yes, the inside handle and lock button function properly too
If I can get a video uploaded I'll post it.
Eric
'68 C20 Suburban, Bagged with Suicide 3rd Door, and Loaded with a 396 - Under Construction
http://67-72chevytrucks.com/vboard/s...d.php?t=403690
Mulk is offline   Reply With Quote
Old 03-07-2012, 10:46 PM   #102
Mulk
Mulk's Avatar
Re: Mulk's 8-Lugger
See if this works.... Click on picture to connect to video link
Eric
Old 03-07-2012, 10:50 PM   #103
67cheby
67cheby
67cheby's Avatar
Re: Mulk's 8-Lugger
Nice work !
67cheby is offline   Reply With Quote
Old 03-10-2012, 11:21 PM   #104
JHT67
JHT67's Avatar
Re: Mulk's 8-Lugger
aahh, inspiration. Just picked up my 67' 8 lugger pick-up, really felt I didn't want to convert to 5 lug, but I'm sure I want it low. Nice to see something in the direction I want to go.
Going through life's daily grind, I can feel the effects of this physical body's fleeting days, But with a young spirit I look toward a brighter day, knowing that in the eyes of eternity, I am but a babe in the arms of my Lord.........
JHT67 is offline   Reply With Quote
Old 03-19-2012, 08:18 PM   #105
Mulk
Mulk's Avatar
Re: Mulk's 8-Lugger
Couple more little projects over the weekend. The front seats were too high and upright for my liking. So I made a few cuts here and there to the frame, and dropped the front an 1 1/4", and the rear about an 1 3/4". Made an HUGE difference in comfort, without any real chage to the overall look. However, it was such a spur of the moment task, that I forgot to snap some shots before I put everything back tobether. Next time I pull the seats, I'll get some photos.
I didn't want to cut into my dash, or have anything hanging from under it either. So I decided I'd put the center console to good use, and put together a quick panel to hold all the gauges, switches, and tunes.
I sill have the stock AM radio hooked-up, and turn it on when people ask about my stereo. Tell them it's all I need. The look on their face is as priceless as when I tell them the truck was built on April 1st, and as a joke, they welded-up the door while it was going down the assembly line.
Eric
Old 03-19-2012, 08:44 PM   #106
kev2809
low n' slo
kev2809's Avatar
Re: Mulk's 8-Lugger
man that console is too cool. are those push buttons for the bags?
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
Old 03-19-2012, 09:03 PM   #107
Mulk
Mulk's Avatar
Re: Mulk's 8-Lugger
Thanks Kev.... Yes they are push-buttons. The gauge on the left is my fronts, middle is tank, and right is the rears. Top buttons are "UP" and lower buttons "DOWN". I had toggles, but they were junk, and worked when the wanted. This set-up took a little more wiring, but I can pull buttons individually if they go bad.
I wanted the billet buttons, until I saw how much they wanted for them. I found these, in packs of 10 on eBay, for next to nothing. Quality is OK, but the price is GREAT!
Eric
Old 03-20-2012, 11:23 PM   #108
dr69burb
dr69burb's Avatar
Re: Mulk's 8-Lugger
cool suburban man. i like the stuff you have done
dr69burb is offline   Reply With Quote
Old 10-07-2012, 03:20 PM   #109
exoticmetalworx
exoticmetalworx's Avatar
Re: Mulk's 8-Lugger
nice build
exoticmetalworx is offline   Reply With Quote
Old 10-07-2012, 04:57 PM   #110
jbclassix
Junk Yartist
jbclassix's Avatar
Re: Mulk's 8-Lugger
After reading your thread again, I am 90 percent sure that I am changing door latches to bear-claw on mine and my brothers trucks. Just as much fab, but the added room for 1-pc windows. I have hung my pants on both styles, so we will see which way we go.
-Jeremy
YOU ONLY FAIL IF YOU STOP TRYING
70 Crew Cab Build Link
70 GMC Suburban 4X4 build thread
95 Yukon Daily Driver
Rebuilding an NP205
jbclassix is offline   Reply With Quote
Old 04-22-2013, 10:55 AM   #111
ratty65
Re: Mulk's 8-Lugger
Hate to bug you but any chance of seeing pics of your rear bag placement/ setup as well as the front? I have the rears in and like how it sits but think I may do a C-Notch as well. I am piecing the fronts together but curious as to what kit or type of bag you went with and also the size on the line? Did you have to remove the inner fenders or was this doen for installation only?
ratty65 is offline   Reply With Quote
Old 05-23-2014, 10:01 AM   #112
JRANGER
JRANGER's Avatar
Re: Mulk's 8-Lugger
man i like those wheels and this project....
JRANGER is offline   Reply With Quote
Old 06-04-2014, 12:20 AM   #113
Mulk
Mulk's Avatar
Re: Mulk's 8-Lugger
Thanks... I've been laying low for a while due to work, funds, and family. But using the old 8-Lugger regularly.
However, over the last couple weeks I finally put the Burb on the side of the house to put in a step-notch and work on the new bag placement.
I'll get the photos up soon!
Anybody have any suggestions or part numbers for the shocks they are using for the extra travel? I'm looking at approx 11 inches of total travel.
Eric
Old 06-07-2014, 12:27 PM   #114
Average Joe
Average Joe's Avatar
Re: Mulk's 8-Lugger
[QUOTE=Mulk;6705873]Thanks... I've been laying low for a while due to work, funds, and family. But using the old 8-Lugger regularly.
Glad to hear you are still on here. This is one of my favorite builds.
1967 C10 Suburban 454/TH400/3.07's
An Average Joe and His 'Burb:
http://67-72chevytrucks.com/vboard/s...d.php?t=775843
Average Joe is offline   Reply With Quote
Old 06-09-2014, 08:13 PM   #115
Mulk
Mulk's Avatar
Re: Mulk's 8-Lugger
Ok so lets get some photos up entailing what I've been up to over the last few weeks since I started working on this beast...
Actually I'll go back a few months on these two shots of my boy helping me pull the drive-shaft so we could replace the bearing. Had a blast with him helping, but this was about three months after I had my left shoulder rebuilt, so I was hurting.
[IMG][/IMG]
[IMG][/IMG]
I just wanted to give him a shout-out for his help. He doesn't make it into many photos unless my wife sneaks out and takes them
Eric
Old 06-09-2014, 08:31 PM   #116
Mulk
Mulk's Avatar
Re: Mulk's 8-Lugger
Now onto the cutting and welding!!
I knew I was going to be raising the entire floor, so I just cut out all the old plywood in section, and kept them for templates.
I've always got my helper around. Here he's guarding the 45 gal tank in case someone decides to run off with it.
I was careful when removing the inner fenders, and kept them as intact as possible. Took a little extra time, but should pay-off in the end.
Ah the joys of working on a 46 year old project, and then sneaking into the clean shower before the wife gets ahold of me.
Eric
Old 06-09-2014, 08:46 PM   #117
Mulk
Mulk's Avatar
Re: Mulk's 8-Lugger
I had ordered a step notch, and some brackets to mount the bags over the axle a while back (prob while hopped-up on shoulder meds), and just never got around to getting them in place. So i figured why not wait until it's 100+ degrees here in vegas to get started
After measuring, scratching my head, and measuring some more, I took the plunge and put these beauties in place.
Here's the sweet Dana 60 8-Lugger tucked into her new home
Eric
Old 06-09-2014, 09:25 PM   #118
Mulk
Mulk's Avatar
Re: Mulk's 8-Lugger
For whatever reason (actually came down to room), I decided to scrap the idea of putting the bags right over the axles. Therefore, I was left with a set of brackets I wasn't going to use, the old brackets I had laying around, and a section of 3x3 tubing I had for the cross brace between the notches.
So I cut apart and cleaned the pieces I thought I might use, and whittled-away on the tubing. Here's what I ended up with...
Upper...
I ended up cutting most of the wedged portion off after changing my mounting location, and rounded the back section of the plate so it wouldn't rub the bag when down.
Lowers...
Then I made some extensions to wrap around the top of the tube.
Everything in place. I mounted the bags with a ride height of 6.5 inches +/-, and then added an inch so the bags wouldn't be completely compressed when laid-out. I Hope this works hahaha
Eric
Old 06-11-2014, 01:05 PM   #119
ratty65
Re: Mulk's 8-Lugger
Who did you get the step notch from ?
Old 06-12-2014, 12:28 AM   #120
Mulk
Mulk's Avatar
Re: Mulk's 8-Lugger
Grant Kustoms
Eric
Old 08-10-2014, 02:33 AM   #121
Average Joe
Re: Mulk's 8-Lugger
Nice work!
Old 09-29-2014, 01:39 PM   #122
4shongo
Re: Mulk's 8-Lugger
Any updates?
4shongo is offline   Reply With Quote
Old 02-18-2015, 03:18 AM   #123
twistedchevy
Re: Mulk's 8-Lugger
Bump
Mine: 72 c20 Chevy suburban, 02 5.3 w/4l60e , factory ac and 50gal tank.
70 k10 Chevy burb, 04 5.3 w/4l60e np241, with dual 30gal saddle tanks and rear 30 gal tank
Dads: 67 c10 step side(project)
72 c10 GMC burb 350/400, with 67 Chevy front clip(grocery getter)
Ours: 67 c30 tow truck
70 c10 long bed 383stroker w/digital gauges(work truck)
twistedchevy is offline   Reply With Quote
Old 02-19-2015, 01:20 AM   #124
Mulk
Mulk's Avatar
Re: Mulk's 8-Lugger
Thanks I actually needed that.
Been busy with changes at work, and my sons senior year.
But that's enough for the excuses. I just need to get my lazy ass back into the shop.
Eric
Old 02-19-2015, 11:20 AM   #125
LockDoc
The Older Generation
LockDoc's Avatar
Re: Mulk's 8-Lugger
Hallelujah! I said the same thing just the other day. (about me).... Now get to work.
LockDoc
Leon
