Old 08-22-2010, 04:17 PM   #101
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Re: 1963 C10 SWB Big Window Build
Build is looking great.
Man I sure wish you were futher down near SoCal. I would SOOO love to get that rear suspension parts from you, since the PO had converted mine to leaf springs and I want to go back to the coil setup.
Keep up the good work!
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 08-22-2010, 04:25 PM   #102
polysci
Man that truck is gonna be SICK...the front IFS and rear c-notch kit is beautiful, like metal-fab artwork...the fellas at Porter Built have some serious skillz!...can't wait to see it finished.
polysci is offline   Reply With Quote
Old 08-22-2010, 10:07 PM   #103
DRTYRAT30
Jesse
DRTYRAT30's Avatar
I was born and raised down in SD, wish i was still down there. I was going to give all the metal to a guy at work who scraps steel.
Thanks man
DRTYRAT30 is offline   Reply With Quote
Old 08-22-2010, 10:11 PM   #104
DRTYRAT30
Jesse
DRTYRAT30's Avatar
Well it's back on the ground today and it looks great, let me know what you guys think so far...
Old 08-22-2010, 10:13 PM   #105
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
I like it!!
Alan's Classic is offline   Reply With Quote
Old 08-22-2010, 11:32 PM   #106
jasonhall
jasonhall's Avatar
Man that looks good.. I have the same kit but its slowly geting on the pick up..
jasonhall is offline   Reply With Quote
Old 08-23-2010, 01:44 AM   #107
polysci
Super Clean!
Old 08-23-2010, 01:24 PM   #108
GVizzle
GVizzle's Avatar
Are you gonna keep those wheels/offset?
Can 't wait to see with the sheet metal on it.
GVizzle is offline   Reply With Quote
Old 08-23-2010, 06:36 PM   #109
DRTYRAT30
Jesse
DRTYRAT30's Avatar
I think i want to go with a 15x7 smoothie with W/W and bullet caps, but i can't decide.
Old 08-23-2010, 06:40 PM   #110
DRTYRAT30
Jesse
DRTYRAT30's Avatar
Thanks guys, I need to get started on the brake lines ect...
Old 08-23-2010, 07:04 PM   #111
GVizzle
GVizzle's Avatar
That thing looks great.
I cant wait till mine gets done.
Old 08-23-2010, 09:38 PM   #112
Stacked78
Stacked78's Avatar
just stumbled on this today after workin on my 63, man that thing is sharp keep up the progess and keep those pics comin! they are motivating me!
1963 C10 Shortbed: project, shaved, slammed
1965 C10 Longbed: 355, 4pd new process, Daily Driver
1991 F150: 300 inline, 3in lift 33s, Stacks. RIP
1992 Dodge 250: 98.5 12valve, 500hp POD injectors, rolls coal...
1986 Chevy 4x4 Shortbed: 4in lift, 33s, daily
1995 2500: 6.5 TD, straight piped, the tow mule
Stacked78 is offline   Reply With Quote
Old 08-23-2010, 11:06 PM   #113
narx66gmc
man, that looks great! The PB stuff is freaking awesome!!
narx66gmc is offline   Reply With Quote
Old 08-24-2010, 10:06 AM   #114
Seven9er
Seven9er's Avatar
I like the pink beach cruiser.... Truck is slick as well haha.
USMC Former SGT 2002-2006
Oshkosh Truck Corporation- FSR, The worlds largest manufacturer of Severe Duty Trucks.
The Money Pit. http://67-72chevytrucks.com/vboard/s...d.php?t=406891
2009 2500HD R.I.P. http://67-72chevytrucks.com/vboard/s...12#post4025612
Seven9er is offline   Reply With Quote
Old 08-24-2010, 10:23 AM   #115
chevy_mike
chevy_mike's Avatar
Looking great.
BTW, sent you a PM.
Old 08-24-2010, 01:50 PM   #116
REDNOSE65
REDNOSE65's Avatar
It looks awsome man...looks like you're doing it right the first time.
RED NOSE '65
LOS HITTERS C.C
DALLAS, TEXAS
The making of a Red Nose...
http://www.67-72chevytrucks.com/vboa...d.php?t=396518
REDNOSE65 is offline   Reply With Quote
Old 08-24-2010, 07:54 PM   #117
chev-obsession
chev-obsession's Avatar
that truck is pretty radical! keep up the good work!
1965 c/10 swb
1969 c/10 lwb
chev-obsession is offline   Reply With Quote
Old 08-24-2010, 11:22 PM   #118
CSoliz
Torn between 66 and 78
CSoliz's Avatar
So your the dude that owns the 54'. It is one of my favorites I have found on the web. Everything about that car is sick!!!
CSoliz is offline   Reply With Quote
Old 08-25-2010, 01:08 AM   #119
Mad Rods
Chevy Only Tx
Mad Rods's Avatar
Looking damn good!
Chevy Only Tx.........
Mad Rods is offline   Reply With Quote
Old 08-25-2010, 11:59 PM   #120
Dan in Pasadena
Dan in Pasadena's Avatar
I used a Rustoleum pro gray primer and a flat black enamel after hours of cleaning and wire brushing also a wire wheel on my grinder then cleaned it with wax & grease remover.
Hey Drtyrat, I just found this thread and want to ask a couple questions about your painting. You said,
"Spent some time getting the frame stripped clean of years of grime and oil leaks. Used engine brite, super clean, wire brush, putty knife and finished it with a wire brush wheel on my 4 1/2" grinder. I'm going to wipe it down with acetone and prime and paint it today."
I assume you followed the same process/same paint - Rustoleum Pro in a silver color?
But if the parts were new from PB did you have to remove some kind of oil or preservative from them? Did they have light surface rust? If so, how much did you worry about that - did you get it ALL off, or just most of it then proceed with the paint prep process you describe?
Dan in Pasadena is online now   Reply With Quote
Old 08-26-2010, 01:19 AM   #121
DRTYRAT30
Jesse
DRTYRAT30's Avatar
The PB parts came clean & bare from Porterbuilt, and all i did is scuff them up with some 320 grit sand paper and a red scotch brite pad. Then clean, prime & paint.
Rustoleum Pro in aluminum color
Old 08-26-2010, 11:12 PM   #122
Dan in Pasadena
I wish Porter Built sold a setup for my '46. Maybe one they have already would be adaptable?
Old 08-30-2010, 12:54 PM   #123
64shortc10
64shortc10's Avatar
AWSOME WORK!
Tony from Norcal
64shortc10 is offline   Reply With Quote
Old 09-02-2010, 06:49 PM   #124
GVizzle
GVizzle's Avatar
Any updates?
You got the arms on yet?
Old 09-02-2010, 07:45 PM   #125
DRTYRAT30
Jesse
DRTYRAT30's Avatar
Arm's?
Not much here, bought a high hump floor section off a board member so i can start to clean up the firewall and paint it. Then on to the Booster/MC, brakes.
Still trying to decide if i want to order a GM crate engine from Jegs or not. Having a new motor dropped off at your door sounds nice.
