Old 04-04-2011, 09:22 PM   #101
99 to Life
99 to Life's Avatar
Re: New guy with 52 AD project.
looking good, love the patina.
Liking that tranny fitting right in there with that seat.
pardon me not searching through to see what rear end you got,
you running spacers or a camaro or something?
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 04-04-2011, 09:38 PM   #102
52 Rat
52 Rat's Avatar
Everyone mentions the patina and said I should drive it as is. I know of three different colors that were painted on with a brush. Not to mention the factory paint and another spry on repainta before the brush on paint jobs. Only years and years can produce a patina like this.
The S10 seat worked out great with the shifter location. The rear end is a 10 bolt factory posi out of a 70 Camaro with a 373 gear. Should work well with the six speed.
My build project http://67-72chevytrucks.com/vboard/s...=1#post4158671
52 Rat is offline   Reply With Quote
Old 04-12-2011, 11:31 PM   #103
bustac
bustac's Avatar
Did you decide on steering column and linkage? Are you running a throttle by wire or cable? Have you fired your motor yet? I'm going with 5.3 too.
1947 5 Window bagged S-15 frame
5.3 w/4L80E
1960 Apache LS Swap
5.3 w/4L80E
bustac is offline   Reply With Quote
Old 04-13-2011, 08:19 AM   #104
52 Rat
52 Rat's Avatar
I will be running the original steering column. I cut the steering tube and shaft just past the firewall. My brother will machine a bearing out of phenolic to fit the steering tube ID and steering shaft OD. This bearing will fit where I made the cut. I will use steering joints and a stabilizer bearing to connect to the power rack.
My throttle body is cable actuated, so I am using the original cable from a 2500HD.
Old 06-06-2011, 12:52 PM   #105
52 Rat
52 Rat's Avatar
Making slow progress on the '52. I finished the Wilwood clutch and brake pedal assemblies. I also installed the late model S10 throttle pedal. I fabed a support plate to the firewall for the master cylinders and pedals (not shown in pics). I removed the cab from the frame, sand blasted and wire brushed the frame and ready for POR15. I hope to have the '70 truck arm crossmember along with the NASCAR trailing arms this weekend. More pics. to follow.
Old 06-06-2011, 01:02 PM   #106
Indian113
Indian113's Avatar
Love what your doing,REAL HOTRODS have 3 Pedals!!!
Indian113 is offline   Reply With Quote
Old 06-06-2011, 01:22 PM   #107
Kabwe
Certified Car Nut
Kabwe's Avatar
Is that right.lol You a mean man do say I don't have a real hotrod.lol
Nice work 52 Rat.
Kabwe is offline   Reply With Quote
Old 06-07-2011, 07:55 AM   #108
Indian113
Indian113's Avatar
No,Kabwe you have a truly sweet truck! That is a old street rod saying-I'm lazy I like my auto's
Old 06-07-2011, 09:05 AM   #109
99 to Life
99 to Life's Avatar
looking good, I definitely thought about using an aftermarket clutch on my next truck. How much was that set up you got for the clutch, actually for the brake too? Does it flex the firewall? I know my set up did with s-10 brake pedal and c-10 clutch assembly, I had to reinforce it a bit. Looks like it is coming along.
I know it seems like you might have to modify that header a bit. By the looks of the pic the steering will be a tight squeeze, you gonna be alright there?
Old 06-07-2011, 12:06 PM   #110
Kabwe
Certified Car Nut
Kabwe's Avatar
Indian I hope you know I was joking. I was only pulling your leg man I've heard that saying many times.lol
Old 06-07-2011, 01:01 PM   #111
52 Rat
52 Rat's Avatar
I purchased the Wilwood pedal and master cylinders off of e-bay. I got a very good deal on the pedal assemblies because no one bid on them. I gave $60.00 for the clutch pedal and master cylinder and $80 for the brake masters and pedal. Normally they run around $300 for the complete set. I did make mounting plates for the pedal assemblies (not shown) so the stress would not be on the firewall.
As for the steering shaft. That is a photo of the mock up. The steering shaft and housing will be cut off just past the firewall and a coupling welded on the shaft. I am running a power rack so clearance will not be an issue. I am using a steering joint and support bearing.
Old 07-05-2011, 08:03 AM   #112
52 Rat
52 Rat's Avatar
All of the holes in the frame have been welded, '70 trailing arm cross member in place, rear axle housing is square and the trailing arms are in place.
I still need to box the frame, install the fuel tank, run fuel lines, route the exhaust and hopeful fire the engine in a few weeks.
Old 07-08-2011, 09:33 PM   #113
52 Rat
52 Rat's Avatar
Someone in the past mentioned NASCAR truck trailing arms. The trailing arms I purchased are new NASCAR arm. They are shown in the above pics. If anyone needs info. on the NASCAR arms let me know.
Old 07-09-2011, 11:30 PM   #114
bo21
Looks good keep up good work.
bo21 is offline   Reply With Quote
Old 07-11-2011, 07:30 PM   #115
99 to Life
99 to Life's Avatar
yeah looking good, so you running springs or bags in the rear?
Old 07-11-2011, 07:55 PM   #116
52 Rat
52 Rat's Avatar
Neither, I will be running coil overs. I thought about bags (Shockwaves) but I decided to go with coil overs in the front and rear. I may do a little auto cross and open road racing, so the trailing arms and coil overs will handle good.
Old 08-04-2011, 12:54 AM   #117
slimneverdies
slimneverdies's Avatar
Have you figured out what you're gonna do about the radiator? Which one are you using?
Long live SLIM
At least try to buy American
slimneverdies is offline   Reply With Quote
Old 08-04-2011, 07:55 AM   #118
52 Rat
52 Rat's Avatar
Yes, I purchased a Champion aluminum radiator with 16" electric fan.
Old 12-05-2011, 09:48 AM   #119
52 Rat
52 Rat's Avatar
Well I'm back to working on the 52 project. It has been a few months, so I thought I would update my thread and post a few progress photos.
I managed to cut the plates used to box in the frame. I now have the frame boxed. I brushed on some POR15 but still need to finish up the trailing arm cross member and the rear frame area where the fuel tank will mount. I hope to have the frame completed this weekend. Next will be mounting the fuel tank and running the lines forward to the engine area.
Old 12-05-2011, 11:28 AM   #120
LEEVON
LEEVON's Avatar
Looking good! FYI you might have to massage the trailing arm crossmember a little so it doesn't hit the bottom of the cab. A few minutes with a grinder and a sledge did it for me.
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 12-05-2011, 11:45 AM   #121
52 Rat
52 Rat's Avatar
I was wondering about that. Any pics or measurements you can forward me before I put the cab on. I would like to go ahead and make the modification now before I paint. I have several BFH's.
Old 12-05-2011, 01:57 PM   #122
Kabwe
Certified Car Nut
Kabwe's Avatar
Everything is looking really nice. Keep the pics coming and keep up the good work.
Old 12-08-2011, 10:49 AM   #123
1952ssr
1952ssr's Avatar
Do you anticipate to have it going for the spring PF Rod Run?
1952ssr is offline   Reply With Quote
Old 12-08-2011, 11:19 AM   #124
52 Rat
52 Rat's Avatar
No, that is near impossible but would be nice! I have a long way to go. Only working on it during the weekends. I don't have much time thru the week. The plan is to get the cab finished, back on the frame and I can start driving it while finishing the body panels.
Old 12-08-2011, 11:48 AM   #125
99 to Life
99 to Life's Avatar
It would be cool to see it out by summer. I think you will like that champion radiator. I like mine, but I used a 55' belair repro they make. Any thoughts on rims or tires?
