04-02-2020, 09:58 AM | #101 |
Re: Static Dropped 67-72 Post your pics!
Since I moved, how about an updated picture....4.5 / 6 drop
1970 C10 Short Stepper with 71/72 front clip. Last edited by BugzC10; 04-02-2020 at 12:54 PM. |
04-02-2020, 12:52 PM | #102 |
6/8 ish
ANDREW 1972 Chevy SWB Cheyenne Super JANE http://67-72chevytrucks.com/vboard/s...d.php?t=462072 1972 GMC Jimmy PENNY http://67-72chevytrucks.com/vboard/s...d.php?t=735827 1968 GMC patina swb PEARL http://67-72chevytrucks.com/vboard/s...d.php?t=731315 1972 Chevy K20 BRUCE http://67-72chevytrucks.com/vboard/s...d.php?t=805788 1972 Chevy SWB Highlander OLIVE Build thread coming |
04-02-2020, 03:20 PM | #103 |
Our C20
04-02-2020, 06:16 PM | #104 |
Junior Member
Cut coils, drop spindles, notch, 2" drop blocks, rear air bags mounted directly to frame.
"I was patina when patina wasn't cool." 1973 Cheyenne SWB Gold White Fleetsides/Saddle |
04-02-2020, 06:17 PM | #105 |
Junior Member
Doing that to this one next. Currently coils cut way too far and 6" drop springs in back.
04-02-2020, 10:04 PM | #106 |
hope this works, 4 year project with/for my son. we drove it today.
pepper tree has been a big help with his posting |
08-07-2020, 11:32 AM | #107 |
What are you guys using for a 4/6 drop on your coil spring trucks these days? I'm asking because the ECE 4/6 drop was so popular and is no longer available?
08-07-2020, 01:00 PM | #108 |
laying low
2 1/2” spindles with 1 round cut off stock front springs for 4 1/2” total front. 4” rear springs. 255/70/15 tires and 15x8” rallys all around.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
08-07-2020, 01:12 PM | #109 |
This is how mine sits on 15's. I have a 6 inch drop spring in the rear with a 3 inch up front and a 2.5 inch drop spindle. I sit at around 28.5 in the front and 29 in the rear from the ground to the highest section of the arch of the wheel well.
08-07-2020, 01:44 PM | #110 |
Not much a picture but it's all I got. 4" drop leaf springs, 2.5" drop spindles with stock height front coils. The body is level. I don't care to know the size tire, because they'll be replaced. What tires I'm not sure yet, recommendations welcome. The wheels are 8/15".
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
08-07-2020, 02:38 PM | #111 |
I'm curious about that too. Seems like the consensus before they closed was that ECE was the best and all the rest are just meh.
DAVE Edmonton, Alberta 1959 Apache 1967 K20 1968 C20 1970 C10 1972 GMC 2500 1981 C10 |
08-07-2020, 03:11 PM | #112 |
I used CPP for my 2.5” Spindles, 2” Springs and 4” rear Drop Springs back in 2015. They have fine ever since.
1970 C10 Short Stepper with 71/72 front clip. |
08-07-2020, 04:45 PM | #113 |
08-07-2020, 09:47 PM | #114 |
The body is rougher than a night in jail right now but I fabricated a rear flip kit, used square body u-bolts, and made the leaf spring plate out of some 1/4" steel plate i had laying around. The front is square body suburban desiel springs with 2 coils cut off. Wheels are factory 8" rally's with 275/60/15 on the rear and 255/70/15 on the front. It's a work in process and started from the frame up on it.
08-09-2020, 02:08 PM | #115 |
1971 C10 green body with yellow cab 5.5/7 drop.
edit: pics loading sideways. working on it. Last edited by bozly; 08-09-2020 at 02:18 PM. |
08-09-2020, 07:19 PM | #116 |
Those are looking great, love the pic of the C10 between the late model Chevy's, looks like a sports car!
Jim |
08-15-2020, 08:59 PM | #117 |
Not sure what a "static drop" is, so maybe mine has no "static".
08-16-2020, 02:31 AM | #118 |
I think static is just lowering with springs and such, not on air bags.
08-16-2020, 02:56 PM | #119 |
Mines a 5/6 drop, but has a BBC and 18 gallon fuel cell in the rear
Posted via Mobile Device |
08-16-2020, 07:11 PM | #120 |
3/5 drop
08-17-2020, 11:02 AM | #121 |
Finally moving under its own power after being shredded for 3 years. 4.5”/5” drop on my 69.
08-18-2020, 06:46 PM | #122 |
4.5” front 4” rear drop 275/60/15 front tires 29/15/15 rear. The rear needs to be a bit Lower, but I am waiting to get new springs and shocks until I go short box next spring.
72 C10, Was a 350,M20, Brodix heads,Comp cam, Edelbrock intake&carb, Hedman hedders LWB. Project is now a 5.3(L33) w/PRC stage 2.5 CNC ported 243heads, BTR RedHot cam,Holley Terminator X, T56 magnum. SWB, Boyd tank. 4.5/4 Drop http://67-72chevytrucks.com/vboard/s...My72c10project |
08-18-2020, 09:01 PM | #123 |
So mine is "kind" of a 4.5" /6" drop. I'm running 2.5" drop spindles with 2" drop springs in the front. But due to the LS1 it's more like 4" drop. Rear is 4" drop springs and 2" blocks. Running 20" wheels all around. Speedway springs. Bell Tech shocks.
08-19-2020, 10:14 AM | #124 |
BEAUTIFUL
08-19-2020, 06:45 PM | #125 |
3.5/5 ECE kit. 255/55/18 & 275/55/18.
1971 Chevrolet K10 - SWB, 5.3LS, 4L60e 1970 Chevrolet K5 Blazer - Project 1969 Chevrolet C10 - SWB, 350 Holley Sniper, 700r4 1969 GMC Suburban - 5.3 LS, 4L60e |
