Old 02-09-2012, 10:28 PM   #101
protrash64
Resistance is Futile
protrash64's Avatar
Re: My Build: Home Depot Machine
Wow, that is low.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 02-10-2012, 12:38 AM   #102
baggedbigblock
Thanks! My rear fender is 13" off the ground!
baggedbigblock is offline   Reply With Quote
Old 02-10-2012, 10:01 PM   #103
X24
THIS IS ONE BAD ASS HOME DEPOT MACHINE... even my wife is impressed with all the work. but she says i still cant do the same to mine. sigh.
X24
1964 chevy c10 step side
230ci straight six
Auto power glide
X24 is offline   Reply With Quote
Old 02-10-2012, 10:49 PM   #104
baggedbigblock
Thanks guys! I finished the steering, and no we are working on the floor pans, cab mounts/supports and cab corners. Building my wiring harness at home and plumbing brake line fuel lines and finishing the carburetor linkage. I will have some sick pics on Monday and pray on friday a fire up video.
For now just a few pics
still need to mount the heim joint plate
Old 02-11-2012, 12:09 AM   #105
McMurphy
McMurphy's Avatar
Ok dude, I am right there with you on the floor pans and rockers right now.
Just to clarify, when these guys say to fit your door after you have mocked up your rocker panel, what they really mean is to hang the door up on its hinges, and then open and close it to make sure the door will clear the rocker. Especially the at the corners.
LOL
I didnt test the fit of the door by opening and closing it with the rocker tacked up, and now I have to cut my spot welds and drop the front end of that rocker because my door binds on it.
Otherwise man your build is looking sweet!
Keep us posted eh?
Michael McMurphy
My 66 Stepside
My 64 Tow Truck
My 66 Tempest
Table Of Contents Added to Page1
McMurphy is offline   Reply With Quote
Old 02-11-2012, 02:36 PM   #106
baggedbigblock
Thanks for the heads up!
Old 02-11-2012, 03:08 PM   #107
YBNORML
YBNORML's Avatar
Looking good! Nice work.
Jason.
68’ GMC shortbox
72' 2WD Blazer
67' LongBox C-10
InstaGram ybnorml67
Old 02-13-2012, 10:27 PM   #108
baggedbigblock
Ran fuel lines, wired carb, finished dizzy setup, finishing brake lines and bleding, and doing body work till my arms falls off. Here is my temp steelies that I am running on with 2.5" port-0-wall white walls, hence the overspray/laziness. It has a flake to it that looks great in the sunlight. Once I the billet smooties come in (6-8 weeks) I will mount those. What do you think of the gold?
Dont mind the old fender, just a mock up
The Daily Driver, thought it was a p%$Sy magnet, but apparently it attracts the cawk!! LOL
Old 02-13-2012, 11:57 PM   #109
X24
i dig the gold.
X24
230ci straight six
Auto power glide
Old 02-24-2012, 11:44 PM   #110
baggedbigblock
Whats up guys. I ran the fuel lines, working on brake lines. The cab corners are in and new rockers and almost done with floor pans. I finished up all throttle cable/kickdown cable setup. I am working on the wiring harness now. the panhard bar is set and I am mid 5 lug conversion on the rear. I also got rid of the ugly gold wheels and went with gloss black for now.
Timeline is 2 weeks until completion. Here is my to do list.
Shocks
Driveshaft
Wiring harness
Paint
Some pics for you
Panhard setup
Fuel done!
Brake lines being run!
Flapper thingies on the intake!
Old 02-25-2012, 04:47 PM   #111
McMurphy
McMurphy's Avatar
Hahahahaha
The wife and I were looking at your updates, I scared her by saying I wanted to do my engine like yours !!
She is already telling me to get the guage cluster that I want, which is going to cost more than what I paid for the truck alone!
Then we saw your floor pan and rocker and saw that you didnt do the floor all the way out with the inner rocker before you put the outer rocker on and I told her man that was going to suck getting that inner rocker in now. What are your plans for that gap, are you just going to put in a cap plate to close it up?
I am also assuming you hung your door and it opens/closes good?
I am thinking of fixing mine tomorrow now tha I am caught up on all the other things.
P.S. I liked the gold, but like I told the wife, you would have had to done some more accents to make it look really smart...
Still groovin on your build man, keep feeding us the pics and updates!!
Michael McMurphy
My 66 Stepside
My 64 Tow Truck
My 66 Tempest
Last edited by McMurphy; 02-25-2012 at 04:50 PM. Reason: closer look at pics changed comments made
Old 02-26-2012, 01:05 AM   #112
protrash64
protrash64's Avatar
Lookin' good BBB!!!! You've covered a lot of ground on that thing.
Old 03-02-2012, 10:48 PM   #113
baggedbigblock
Trans tunnel done, Cab floor is painted. Fuse box mounted, and wires starting to be run. Brake lines are finished, shocks are ordered. I smoothed the welds and am working on the body filler. I got a donor truck to rob some parts off of so some new pieces will be going on. Monday I am going to lay down some primer on the cab, and then remount the bed. I hope to have all wiring done Monday
as well. I also got the fuel cell finished and cleaned up with some paint. Awaiting the new axles and then the rearend will be reassembled.
Far shot of new sheet metal
This took up my last week. I bought new wheels for the DD. Then I stripped the clear and hand polihed 400 grit and up the lips, then had the tires stretched 19x11 front and rear with 245 front 255 rear. But that's another thread!
Old 03-02-2012, 10:52 PM   #114
baggedbigblock
Thanks guys, Yeah the cost of the floor pan rear section was too much money (triple the rocker price!) so just some basic sheetmetal was used since it will be under carpet. The rear inner was in just tacked from underneath.
McMurphy, I thought the gold was going to look good against the black but it just looked cheap to me. The gloss black is a safer bet but looks good for now. Again these wheels will just get me buy for a few months.
Old 03-14-2012, 10:46 AM   #115
baggedbigblock
Paint is getting laid. I am not. The Mrs. is getting annoyed of all the $$ and time this beast takes. Good news ill be done real soon! Axless are back! Working on wiring, waiting on little connectors, bulb sockets etc etc the piddly stuff that takes 5 days to get in from CA.
Made my own gauge cluster out of metal and will wrap it with the thin copper once done. I will post more pics later today when done.
Etching primer
high build 2k
**** the speaker holes, but they will be covered up by the bench seat! and will at least play so musica!
BTW I turn 31 this week and my awesome ass fiance got me this!!!!
I have a nice distressed brown ammo pouch leather strap to put on it immediately
Old 03-15-2012, 09:04 AM   #116
baggedbigblock
The body is not fun, it takes forever and is exhausting. The fun stuff is building the motor, bagging the truck. Oh well the end is near. I promise I wont disappoint. The truck is going to a proper updraft booth w high end guns and equipment for the final primer, wetsand, paint. Too much trash in the air at this shop but it works for the etch and prime coats. The final outcome will be sick!
Just a mock up of the gauge layout, starting cutting but the bits where dull. Need to buy more.
Etching and 2k on the bed, no body work done yet filler wise
Here is a fun/boring vid of some of the rides we have here at the shop, and me playing with a Caddy on Hydros.
Old 03-15-2012, 11:09 PM   #117
baggedbigblock
So I finished my gauge cluster out of copper today!
steel frame
instant charisma
But wait....did this fool make a symmetrical matching glove box copper panel? Why yes he did.
So what does a logical person do after all this work with the copper and such? Make it shiny? Hell no, age that thing instantly......viola Patina gauge cluster with matching glove box cover soon.
Old 03-15-2012, 11:39 PM   #118
coulter
coulter's Avatar
awsome!!!! love what you did with the gauge panel
bagged 66 longbed build
http://67-72chevytrucks.com/vboard/s...d.php?t=449548
my favorite colors.. black, rust, and shiny!!!! instagram: @coulter918
coulter is offline   Reply With Quote
Old 03-16-2012, 11:00 AM   #119
chevyrestoguy
chevyrestoguy's Avatar
That aged copper looks cool! If it were me, I would do alot more of that stuff on the interior. I would definitely do the radio bezel and the middle of the door panels. When I first saw the bare copper, I was not really sold on it. After you aged it, it made all the difference in the world.
Nice job!
Check out my latest endeavor:
https://roundsixpod.com
My build threads:
'55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512
'64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527
chevyrestoguy is offline   Reply With Quote
Old 03-16-2012, 11:08 AM   #120
VA72C10
VA72C10
VA72C10's Avatar
That's awesome. Would be great on e door panels.
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 03-16-2012, 01:27 PM   #121
creep
Registered Loser
creep's Avatar
That dash is completely bad@$$! The motor is looking good too. I have the same scoop and similar valve covers but haven't put the covers on yet. Getting inspired to though. Nice work.
'63 GMC lwb, 383, th350, lays frame, genuine patina.
The Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=374267
'88 Astro cargo bagged, shaved, phantom grille. *SOLD*
'50 Chevy 2 door sedan awaiting attention.
2014 Silverado Ext cab, 5.3, daily driver.
creep is offline   Reply With Quote
Old 03-16-2012, 01:40 PM   #122
McMurphy
McMurphy's Avatar
Did you use vinegar to age your copper?
Are you going to laquer the copper or clear coat it to arrest further oxidization?
And I have to agree with chevyresto, if I started in with the copper panels, it would be hard to stop; shifter arm, door panels, like he said... ect...
I dig your build man, keep it up!
One question though, I have seen a few builds with the dash mounted bottle opener. What is that all about?
Michael McMurphy
My 66 Stepside
My 64 Tow Truck
My 66 Tempest
Old 03-16-2012, 05:21 PM   #123
baggedbigblock
thanks guys for the compliments. I haven't thought about clearing it. I have a left over piece and some matte clear, I will test it out to see how the sheen is.
McMurphy, There was a hole where the A/C or heater knob used to be, I didn't want to leave a blank piece there, so the dash board mounted bottle opener seemed to fit the bill. It's kind of cool you can open a beer from the dash. I got the idea off a rat rod I saw. I guess its kind of hot rod/ rebel thing to do.
Old 03-16-2012, 06:12 PM   #124
protrash64
protrash64's Avatar
Good work BBB!!! Always fun checking in and seeing whats up.
Old 03-21-2012, 10:48 PM   #125
baggedbigblock
Well, I matte cleared the copper, I am not sure if I like it, it took alot of the color away. I may just sand it down and leave it raw. Let me know what you think of the clear coated copper. I have also been getting pretty good at heat shrink, crimping, and all the fun that comes with wiring.
carb linkage all done
Hockey stick wrap tape instead of plastic loom FTW!!
patina copper
more wiring
