Old 03-29-2011, 09:08 PM   #101
bigblock73
yeller
bigblock73's Avatar
Re: 77 yellow gmc swb
Originally Posted by 73gmc454 View Post
Thanks guys , I made a aluminum rear bumper filler panel today and painted it semigloss then mounted it up, also got the bumper mounted on for good I hope !
You stole my flippin idea! Damn. Looks GREAT though!
bigblock73 is offline   Reply With Quote
Old 03-29-2011, 11:37 PM   #102
73gmc454
73gmc454's Avatar
the bumper filler was easy too! You'll have to do a lil notch or bend for the licence plate light , thats the only issue I had ,
my build 77 gmc shortbed big block, http://67-72chevytrucks.com/vboard/s...d.php?t=438237
73gmc454 is offline   Reply With Quote
Old 03-29-2011, 11:44 PM   #103
watahyahknow
watahyahknow's Avatar
you might need to drill a little hole in it to prevent any rainwater from puddling in there
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 03-29-2011, 11:49 PM   #104
bigblock73
yeller
bigblock73's Avatar
Mine has been designed for a while, just need to get it cut and formed. I notched mine for the light. Does yours lay flat from bracket to bracket...or should I say, are the tops of your bumper brackets all lined up acoss? Looks great again man.
Old 03-30-2011, 12:29 AM   #105
pig rig
pig rig's Avatar
I made a filler out of 3"x16ga flat bar and had a 1/2 lip bent in it on the front side to stiffen it up drilled holes to bolt it to the outer brakets like the stock one does painted it black looks better then stock. but I'm thinking I'll get it chrome plated or make a new one out of stainless and polish it
my sports car rolls on six wheels only because I'm to fat to get in and out of new corvette
http://hubgarage.s3.amazonaws.com/ph...ped_detail.JPG
pig rig is offline   Reply With Quote
Old 03-30-2011, 07:29 AM   #106
73gmc454
73gmc454's Avatar
Yep somehow the mounts were all laying flay and it bolted down better than expected , I was gonna make it outta stainless also but really didnt want to bring any attention to it ,
Old 03-30-2011, 09:13 AM   #107
bigblock73
yeller
bigblock73's Avatar
I wonder how it would look painted body color?
Old 03-30-2011, 12:33 PM   #108
watahyahknow
i was thinking about that too theres a piece missing underneat the lid painting that part in the bodycolour could opticly fill it
Old 03-30-2011, 06:55 PM   #109
73gmc454
73gmc454's Avatar
I think it would look good painted the body color but on mine the rear panel behind the bottom of the gate was painted black so I did the filler in black , the body guy painted it black to blend in with the rino/line-x that I'll have sprayed in once I can drive it there, hopefully soon !
Old 04-03-2011, 08:20 PM   #110
73gmc454
73gmc454's Avatar
I was able to get out there and get the overflow mounted up today,
Old 04-03-2011, 08:22 PM   #111
my4by2
my4by2's Avatar
Looks sweet man & love the clear tubing!!!
1977 Chevrolet K30 LWB Crew Cab
497HP Mast Motorsports 6.0L LY6 HO engine
GM NV4500 5-speed, Centerforce clutch + NP205
D60 + 14-bolt FF w/ Eaton posi + disc brakes
Skyjacker 2.5" full spring lift w/ Nitro shocks
Custom paint + interior
http://67-72chevytrucks.com/vboard/s...d.php?t=435722
my4by2 is offline   Reply With Quote
Old 04-04-2011, 12:19 AM   #112
Gordonr1973
Home Built '87
Gordonr1973's Avatar
x2 very cool ideas here!!!!
Gordon
1998 White Chev ext cab 2WD (Summer Project) http://67-72chevytrucks.com/vboard/s...d.php?t=408424
1987 Chev Silverado SWB (Winter Project Rebuild) http://67-72chevytrucks.com/vboard/s...d.php?t=424833
Truck Club http://67-72chevytrucks.com/vboard/s...d.php?t=466969
Gordonr1973 is offline   Reply With Quote
Old 04-04-2011, 09:35 PM   #113
73gmc454
73gmc454's Avatar
glad ya like, Well I got it filled up tonight and it dont leak! I also got the front hood adjusters on and adjusted , those are a lil tricky , I also took the rest of the grill trim / bezels off . I'm gonna paint the area behind and above the lower grill trim black to bled it in more ,
Old 04-07-2011, 08:34 PM   #114
73gmc454
73gmc454's Avatar
Was able to get out there today and get the top of the bumper filler painted black, got the grill brackets all lined up with everything ,and everything put back together , even got the the new amber turns in there for Jeffs approval !
Old 04-07-2011, 08:53 PM   #115
bigblock73
yeller
bigblock73's Avatar
...even got the the new amber turns in there for Jeffs approval !
Looks much better...if I do say so. Love the truck man. Get the new parts cleaned up yet and put in?
Old 04-07-2011, 09:04 PM   #116
73gmc454
73gmc454's Avatar
Thanks I knew you would be proud ! I havent got them cleaned up just yet , did you sand the woodgrain down on your dash trim ? I did get primer on the key rack, everybody at the shop really liked it , thanks again,
Old 04-07-2011, 09:42 PM   #117
bigblock73
yeller
bigblock73's Avatar
steel wool will remove the woodgrain easily...that is how I did mine.
Old 04-07-2011, 10:05 PM   #118
73gmc454
73gmc454's Avatar
Cool, I'll get on it !
Old 04-08-2011, 08:40 PM   #119
73gmc454
73gmc454's Avatar
got my wiper motor ready to mount up, gotta love the rebuild in a can !
Old 04-08-2011, 11:44 PM   #120
bigblock73
yeller
bigblock73's Avatar
I call it an aerosol overhaul
Old 04-09-2011, 01:41 AM   #121
73gmc454
73gmc454's Avatar
next up on the list is gonna be the big fab job of makin the gauge panel, I have gotten lots of ideas from the group on this , I built this one below a long time ago I sectioned it back to try and see if I could get the gauges pointed up a bit , but I think I'm gonna make the same type panel out of smooth aluminum and flat, I'll roll some rings up to fit the inside of the gauges and just angle them up , kind of like Jeffs and others I've seen but with a custom panel that I'll have painted or powdercoated ,
Old 04-11-2011, 12:39 PM   #122
73gmc454
73gmc454's Avatar
Got lots done yesterday , front bumper on upper and lower grill trim I think I got the front end is done , also got the shifter linkage tuned up trans vacuum line hooked up, the wheel well moldings , wiper motor , cowl vent and the seal mounted up , got the right height set too , I worked on the drip rail molding but just couldnt get them on there, any ideas ? other than that it was a good day ,
Old 04-27-2011, 07:42 AM   #123
73gmc454
73gmc454's Avatar
not much real progress , but I was able to make a rough draft of my gauge panel outta plastic, I went the easy route without taking the gauges apart and just mount them flush , its an easy part to change later if I wanna make another one , I wanna round the top inner corners and maybe angle in the sides ? just dont totally care for it all squared off ,
Old 04-27-2011, 07:53 AM   #124
watahyahknow
ive seen aftermarket parts for these made out of fiberglasss . not sure though
Old 04-27-2011, 08:37 AM   #125
baclay9
100mph @ 800rpm? You should get really good mileage.
Dash panel is going to look great man!
baclay9 is offline   Reply With Quote
