Old 03-19-2014, 05:45 PM   #101
PurdueSD
PurdueSD's Avatar
Re: Lost and Forgotten 51
Shop time for me tonight, first time in a while!
something is missing...
My Lost and Forgotten build thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=442712
PurdueSD is offline   Reply With Quote
Old 03-19-2014, 05:59 PM   #102
focusedontheprize
focusedontheprize's Avatar
I have been waiting for updates!
Looking forward to some pictures after tonight.
focusedontheprize is offline   Reply With Quote
Old 03-19-2014, 09:45 PM   #103
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Sweet, whats in store for tonight?
--Josh
Old 03-19-2014, 10:29 PM   #104
skymangs
skymangs's Avatar
I know it's a little late, but on my last project I painted the firewall semi black, all the way up to the rubber strips (rear of the hood), then went Patina behind that. It turned out pretty nice and made for a good transition point.
skymangs is offline   Reply With Quote
Old 03-19-2014, 10:31 PM   #105
PurdueSD
PurdueSD's Avatar
Ewwww! Fiberglass over rust...brilliant!
Spent some time wire wheeling tar and dirt...still more to go.
Looking better!
Bad pic, but Got the welds completely dressed and ready for a bit of filler.
Old 03-19-2014, 11:37 PM   #106
Baldeagle SR
fiberglass over rust used to be a quick fix to sell a car. They might still do it today.
nice work.
Rich
my build
http://67-72chevytrucks.com/vboard/s...83#post6577983
Baldeagle SR is offline   Reply With Quote
Old 03-20-2014, 02:03 PM   #107
mikec4193
mikec4193's Avatar
Hey PurdueSD
I love that build...do the new cab corners come with notches or holes so as to be able to drain the water out of them??? I am going to have to do some of that same stuff to mine....I am just trying to think of a way not to have them rust out again...
Your cab reworking looks great from here.
MikeC
mikec4193 is offline   Reply With Quote
Old 03-20-2014, 03:51 PM   #108
PurdueSD
PurdueSD's Avatar
Thanks guys!
Originally Posted by mikec4193 View Post
Hey PurdueSD
MikeC
No the cab corners don't have any drain holes. I just plug welded the bottom of them to the inner cab corner, so there is a place for water to get out. He's got a garage spot, i doubt i'm around for the next time they rot out.
I got these from classic parts, they are actually quite a but differently shaped that the original. They aren't as round where they roll under. They fit pretty decent though.
Old 03-20-2014, 09:41 PM   #109
*Kenny
coming along great, repairs look good
*Kenny is offline   Reply With Quote
Old 03-20-2014, 11:10 PM   #110
skymangs
skymangs's Avatar
I got mine from Classic Parts as well. I had to do quite a bit of massaging to get the lower door gap right, but I had to use a lot more of the panel than you did. Looks great BTW
Old 03-20-2014, 11:20 PM   #111
PurdueSD
PurdueSD's Avatar
Yes, I noticed the same issue...the gap widens at the bottom where it rolls under. You can see it if you look closely at my in progress tack welding pics.
"For this truck". It wasn't worth fixing it to me. I would have had to slice the patch a couple times and spread it... A lot of extra work on a place that you can't really see after the truck is assembled.
Thank for the compliments!
Old 03-21-2014, 07:43 AM   #112
skymangs
skymangs's Avatar
You bet, I'm really digging your build!
Old 06-26-2014, 10:55 PM   #113
PurdueSD
PurdueSD's Avatar
Finally made some progress this week! Spent some time with a torch and scrapper getting rid of roofing tar undercoating, wire wheeling and finally priming and painting the bottom of the cab. Then got the cab back and bolted on the frame for good!
Old 06-26-2014, 11:00 PM   #114
99 to Life
99 to Life's Avatar
sweet, glad to see you back on it.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 06-26-2014, 11:00 PM   #115
PurdueSD
PurdueSD's Avatar
Next up was pulling the engine one final time. This gave me access to weld up a couple unused holes in the firewall and wire wheel before prime and paint. Turned out pretty decent...really starting to come together!
Old 06-26-2014, 11:08 PM   #116
PurdueSD
PurdueSD's Avatar
Did the same inside... Forgot to take a pic after the inner firewall, toe board and kick panels got paint, but here it is in primer. Have the dash completely stripped and in primer also.
Filled the gas neck hole and did my first round of paint blending. Worked on blending the new cab corners back in also. Not completely happy with it yet, but it'll get there. A big improvement over what was there though!
Old 06-27-2014, 07:14 AM   #117
FarmerSid
FarmerSid's Avatar
Nice work man!
1952 Canadian Chevy 1300
C4 IFS & D44 IRS
5.3 HO L33
My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=632938
FarmerSid is offline   Reply With Quote
Old 06-27-2014, 05:25 PM   #118
PurdueSD
PurdueSD's Avatar
Thanks! Me too, It's getting fun!
Originally Posted by FarmerSid View Post
Nice work man!
Thank you!
Old 06-30-2014, 08:14 PM   #119
PurdueSD
PurdueSD's Avatar
Couple more from today... Not perfect but, it'll do.
Old 06-30-2014, 08:39 PM   #120
FarmerSid
FarmerSid's Avatar
Looks good man! What paint did you use?
C4 IFS & D44 IRS
5.3 HO L33
Old 06-30-2014, 11:33 PM   #121
PurdueSD
PurdueSD's Avatar
Good ol' semigloss black rustoleum. Going for the electrical tape look.
This truck would need completely stripped anyways if I ever wanted to put it in nice paint, so not much to loose.
Old 07-13-2014, 07:45 PM   #122
49Fireman
Love this build. Have you planned out your TBI system beyond the tank and fuel pump? I have the same donor and I'm wrestling with whether to convert my engine to carb or leave the TBI. Not sure how to wire up the wire harness and the computer. Also do you have to plumb an O2 sensor into the exhaust? I had decided on switching to a carb but now I'm hearing I may have to change the cam and distributor.
49Fireman is offline   Reply With Quote
Old 07-13-2014, 08:14 PM   #123
PurdueSD
PurdueSD's Avatar
I've planned it out, just starting to put the pieces together. I found a place on ebay selling trimmed down/refurbed oe engine harnesses. I just received mine last week. It looks nice and was very reasonable. haven't spent any time with it yet though...
http://warrperformance.com/?product=...ontrol-and-vss
For the 200 bucks it was worth a shot to me. I've got a 700r4 from the donor, so I went with the optional tranny control. If this all works out like it should, I will have sever hundred less in a more reliable setup. Intake , carb, distributor, trans control all add up pretty quick. I'm a little out of my element, so we will just have to see how it all works out.
Old 10-30-2014, 09:19 AM   #124
67ChevNut
Active Member
Smile Re: Lost and Forgotten 51
Love you build, doing the same with my cab soon. What kind of welder you used to weld that cab corner?
I am particularly interested in finding out how did it go with the TBI wire harness you bought in ebay. Have you conected it? If so, did you have any problems with it, what kind of O2 sensor did you use?
Planning to buy the same wire harness in a week or two. I am also want to get my 350 TBI engine started. Great build!
67ChevNut is offline   Reply With Quote
Old 10-30-2014, 10:20 PM   #125
PurdueSD
PurdueSD's Avatar
I'm using a a miller 212. I use c25 and .o23 wire for sheet metal.
Honestly haven't had much time to put towards the truck as of late. Winter time is usually my productive period. I did have to purchase a inline vss generator, got that from jagsthatrun. Harness looks good just need to speed some time getting this thing hooked up and running. I mounted my ecu directly above the glove box liner. I'm gunna use the O2 from my donor suburban.
