03-06-2011, 01:04 PM | #101 |
Re: Parting BBC 1969 GMC c2500 Super Custom!
My grille is good just the upper grille trim was dented and bezels rusted out. R they in route?
Posted via Mobile Device |
03-06-2011, 01:06 PM | #102 |
Vintage 4x4s
Plan to ship monday. Just removed grille yesterday and will now remove rivets holding upper grill trim to grille.
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades) 67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore ) 86 CHV K30 502 th400, apple red NEW 71 CHV K20 350 SM465, ochre (saved work truck) 71 CHV K20 292 SM465, white, tach, PTO, (future project) 72 CHV K20 350 350th, medium blue (project stocker) 01 CHV K2500hd crew, indigo blue ^3 dont run and the others don't see winter either '86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649 '71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642 '72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6 |
03-06-2011, 01:07 PM | #103 |
Active Member
I'll take the hood letters & cc door embs, pass on the eyebrows. thanks lmk total & pp.
03-06-2011, 02:10 PM | #104 |
93446
03-06-2011, 03:02 PM | #105 |
Vintage 4x4s
I'm having trouble getting the driver side set off. Instead of speed nuts there are little crimped things on there. Is there a trick to getting these off?
03-06-2011, 03:19 PM | #106 |
Carpe manana
Any luck getting the defrost vents out?
03-06-2011, 03:33 PM | #107 |
Vintage 4x4s
Hopefully sometime today, they're still trapped by that darn hard to remove dash pad.
03-06-2011, 03:35 PM | #108 |
Carpe manana
Thanks. Good luck!
03-06-2011, 05:04 PM | #109 |
Active Member
On the door cc emblems if the 3/8'' speed nuts are gone, try a pair of needle nose pliers and slowly turn whatever is holding them on to the studs. On the defrost vents, don't forget there are 2 tabs that need to be squeezed together to make removal easier.
03-06-2011, 05:38 PM | #110 |
Roadtrip!
Sounds like barrel nuts. If that is the case, they will just pry off from the outside. Get something real thin and flat and slowly work it off. Good luck...
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
03-07-2011, 12:07 AM | #111 |
[QUOTE=Vintage Windmills;4533492]Are you talking about the vent that is down below the dash? I would have to take the fender off to get at this piece, correct?
No, just reach inside where the push pull handle is (inside the cab) and squeeze the clip at the pivot point and lower the stud that it is holding up. The push pull part is held by (2) 5/16 screws near the handle. Matt
72 chevy k-10, swb, auto, 35's, rally's, posi, 4" lift, 2.5" old style 40 series flows with headers and crossover pipe and some other stuff!! |
03-07-2011, 02:26 AM | #112 |
Vintage 4x4s
If you want everything in the pic below (which includes all mounts) it will be $95 shipped. $70 shipped for just the column and everything on it but not near it in the pic. $84 shipped for the column and the steering box shaft. Let me know. Do you want the horn switch too? I'll throw it in no charge if you will use it. 6t7t72, emblems pics below. Just one broken stud on one of the script Camper ones. $40 shipped for all.
03-07-2011, 02:31 AM | #113 |
Vintage 4x4s
Thanks Eric, a gasket scraper did the trick. I actually ended up fighting the speed nut more on the other one. The one stud that I broke was during a fight with this speed nut that wouldn't unscrew. it just sat there spinning
03-07-2011, 03:48 AM | #114 |
Looks good how do you prefer payment ?
03-07-2011, 09:47 AM | #115 |
Vintage 4x4s
03-07-2011, 02:36 PM | #116 |
Do you still have the passenger vent window? Does the chrome look like it will clean up good? Need it shipped to 22701.
03-07-2011, 02:46 PM | #117 | |
Vintage 4x4s
Do you want it with the long bar that goes down in the door or just the window. Same price either way except shipping will vary. Chrome is good, I can shoot a pic or two tonight if you'd like. On a separate note: <<AC SYSTEM NOW BEING PARTED OUT>>
03-07-2011, 02:50 PM | #118 |
Shoot me a couple close ups of the chrome. Let me know the price either way, but I'm definetly interested in the window assembly, itself. How is it attached to the window channel rail? (I should know this)
03-08-2011, 01:10 AM | #119 |
Vintage 4x4s
Got the bumper brackets and most of interior out today.
Pics of Dash pad showing largest flaws. One defrost vent has no damage. Headliner trim would only be good if you want to paint it. Why isn't there more interest in the AC stuff?? I guess I'll start a separate thread for that to attract buyers. Lots of parts here.
03-08-2011, 01:14 AM | #120 |
Vintage 4x4s
More pics
03-08-2011, 08:10 AM | #121 |
Carpe manana
Bummer - its the oval, passenger side (broken) defrost vent that I really need. Thanks for the effort. I'll have to pass.
03-08-2011, 09:49 AM | #122 |
sent you a p.m.
Tim |
03-08-2011, 10:02 AM | #123 |
Vintage 4x4s
03-08-2011, 03:10 PM | #124 |
Vintage 4x4s
Tim, PM sent about power brake, let me know. I think this is the heavy duty system with dual diaphragms, which allows for a smaller size with same or greater braking power, In other words- a good system.
Shipped the bumper brackets, PS system, T400 linkage, inside mirror and hood latch setup today. Thanks guys. I think the AC stuff will sell much better in July or August lol.
03-08-2011, 03:22 PM | #125 |
Carpe manana
Next week I'm looking at a 72 K20 Cheyenne w factory AC that may benefit from your AC stuff. I may be in touch if I get the truck.
