Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Suspension > Suspension Marketplace
Old 12-01-2012, 04:14 PM   #101
aggie91
I'm just glad to be here!
aggie91's Avatar
Re: 63-87 rack and pinion
Rob
I got your rack and started the install. I have an issue with one of the adapters for the rod ends. One will only thread on about a 1/4 inch onto the rack end. The jam nut goes all the way on fine. I think the internal threads on the adapter are messed up. What is the thread type so I can get a tap and chase the threads?
aggie91 is offline   Reply With Quote
Old 12-02-2012, 12:15 AM   #102
aggie91
aggie91's Avatar
Originally Posted by robnolimit View Post
Aggie, I'll have some picts up in a bit. With the raised crossmember, you will need a different type bearing support. I can help you with that.
Rob, did you ever get the pictures of the support bearing for the 73-87 frame set ujp? I will send you a PM also. So far the install went well and looks good. There are some pictures in Korbin's build thread in my sig below. I just need the above issue solved and the support bearing and we can move onto getting the rest of the truck together.
Thanks for a great product. I am looking forward driving this set up with PB Forward Arms.
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
Old 12-05-2012, 04:31 PM   #103
aggie91
aggie91's Avatar
Thought I would post up some pic's of my install on Korbin's '82 C-10. We raised the crossmember up into the frame 1.5" and also used Porterbuilt's new Forward Arms (Lowers only at this point). Here are some pictures from this past weekend:
I still need to do the support bearing, but I am waiting on Rob to post up some pictures of the correct set up for a '73-'87 frame rail. I have a PS pump, hoses, and cooler from a 2000 GMC that we are going to use in the final installation. Enjoy!
Karl
The LST Challenge:
Old 12-05-2012, 05:45 PM   #104
robnolimit
robnolimit's Avatar
With a raised crossmember, you need to raise the idler bearing also. I would set the cab on, install the column, and then lay out the steering shaft.
GoodGuys 2012 Pro-Truck Champion
2012 Truckin' Throwdown Champion
GoodGuys 2011 National Champion
2011 Truckin' Throwdown Champion
GoodGuys 2010 National Champion
Proud to put our products up against all others!
robnolimit is offline   Reply With Quote
Old 12-07-2012, 10:42 AM   #105
aggie91
aggie91's Avatar
Thanks, Rob. I got the adapter yesterday. Tried in on the Passenger side this morning and it fits fine. I need to check the Driver side since that is the side we had issues with. I will do that this afternoon on the way home from work.
I have a bearing like you showed above, once the cab floor is done and under side is painted, we will put it on and set up the rest of the steering system.
Thanks again!
Karl
The LST Challenge:
Old 12-11-2012, 12:55 PM   #106
aggie91
aggie91's Avatar
I finally got the time in the shop to put the new adapter on and get that steering bolted together, just need to mount the cab to finish it off...
With the rod ends and adapters all together and both threaded all the way in, I have a bunch of toe out. What should I do to be able to adjust this down for a range between toe out and toe in? Should I cut a little off the rack ends? How much?
Karl
The LST Challenge:
Old 12-17-2012, 10:26 PM   #107
Custom 68
Custom 68's Avatar
Karl, did you ever get this resolved?
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 12-17-2012, 10:47 PM   #108
aggie91
aggie91's Avatar
I got all the parts together and fit to the chassis. I have not heard from Rob on what I should do to fit the extreme toe out issue. I say extreme since it is about 1/4"-3/8" toed out with the adjustments all the way in...
Karl
The LST Challenge:
Old 12-25-2012, 07:37 PM   #109
mooseknuckles
mooseknuckles's Avatar
I've heard that there is some clearance issues with the tie rod ends and the posi links when using a Ride Tech Musclebar?.....looks like there is lots of room for the steering shaft with the LS with headers?...thats good news...
mooseknuckles is offline   Reply With Quote
Old 12-27-2012, 01:26 AM   #110
robnolimit
robnolimit's Avatar
Karl, I will check on an OD rack measurement for you on thursday.
Old 12-31-2012, 04:23 PM   #111
aggie91
aggie91's Avatar
Rob
Did you happen to get the measurement of the overall rack width? I appreciate all your help with this project.
Happy New Year!
Karl
The LST Challenge:
Old 02-07-2013, 05:44 PM   #112
Custom 68
Custom 68's Avatar
good luck. I still want one of these but I hope you get all yours worked out.
Dave
Old 03-15-2013, 10:44 AM   #113
aggie91
aggie91's Avatar
Rob
here are some pictures of my install I am trying to do. It looks like I can get a single shaft from the column to the Ujoint on the rack without needing the third joint and support bearing. I do not mind cutting the frame rail and I might even weld back in a strip on the engine side of the flange to "capture the shaft in the frame rail flange. Also, should I cut off about 1" of the column shaft to get the Ujoint further away to help with the angles?
I am going to try to call you later today. I might have to wait to talk to you if your at GG's in TX this weekend. Anyway here are some pictures:
Karl
The LST Challenge:
Old 03-22-2013, 02:40 PM   #114
aggie91
aggie91's Avatar
Got my steering shaft hooked up. For what ever reason, I did not get the correct U-Joint for the column to shaft. I have to get the correct one for the final assebly, but this one worked out real well for moch up. Ended up going with a straight shaft from the column to the U-Joint on the rack.
Karl
The LST Challenge:
Old 03-22-2013, 05:20 PM   #115
Custom 68
Custom 68's Avatar
Great Karl. glad to see it hooked up.
Dave
Old 05-13-2013, 12:33 PM   #116
theastronaut
theastronaut's Avatar
Working a deal with Nate to package the P/S rack and a set of his "Forward Lower" A-arms. This combo will add caster, center the wheel and deliver great steering. Check out the suspension marketplace.
Yes, both Nate and No Limit have this package available now.
Rob,
I really appreciate the work you're doing with C10's to get them to handle better! The "Make it handle" thread, along with a trip to see the Goodguys autoX has completely change the build direction of my '66 C10.
I had planned to build my own A-arms but noticed this package deal and figured I'd see what the price was before I went out and bought everything to build my own arm- might not be worth the time and effort if I can just buy them already built like I want (1" forward, added castor, bag plates). I will be going with your R&P kit either way. I searched the suspension marketplace but didn't see the rack/arm combo listed anywhere.
Thank you for your time and commitment to the forum!
theastronaut is offline   Reply With Quote
Old 05-24-2013, 10:46 AM   #117
moregrip
moregrip's Avatar
thats looks perfect! do you need a support bearing? Maybe with the close tolerances to the frame it's best for deflection (if there is any/no idea)
1983 Chevy C10 250/3spd (current project truck)
1976 Chevy C10 350/350 Heavy Half (future project truck)
moregrip is offline   Reply With Quote
Old 05-30-2013, 05:28 PM   #118
aggie91
aggie91's Avatar
Typically the support bearing is only needed when you add a thrid u-joint in the shaft linkage. I wanted to avoid the 3rd joint, so I took some measurements and figured out that a single shaft with a joint on each end would work.
I hope to have the truck running and driving by end of next month so I can give a bit of feed back on the steering and linkage.
Karl
The LST Challenge:
Old 06-15-2013, 05:50 PM   #119
theastronaut
Is it the end of the next month yet I know you're not ready to drive it yet but I'd love to hear your comments on how the steering works/feels.
Old 06-15-2013, 05:53 PM   #120
mooseknuckles
x2!
Old 06-17-2013, 09:46 AM   #121
Custom 68
Custom 68's Avatar
Yes I too am wanting to hear some real world thoughts and experiences, that and for Rob to run a sale special again.
Dave
Old 06-18-2013, 09:06 AM   #122
aggie91
aggie91's Avatar
We are getting closer. I am a bit behind the schedule we planned, but I don't want to cut corners. I hope to have some better updates in about 3 weeks.
Karl
The LST Challenge:
Old 06-18-2013, 09:31 AM   #123
Custom 68
Custom 68's Avatar
Yes sir don't rush it this close to the end. It will be a great build.
Dave
Old 06-19-2013, 07:43 AM   #124
wraprail
wraprail's Avatar
woops, wrong thread.
sorry
Thanks.
wraprail is offline   Reply With Quote
Old 07-01-2013, 09:13 PM   #125
Mondo
Mondo's Avatar
I just installed this. I have CPP tubular arms, sway bar and 3in drop springs and dropped spindles and installed this R&P as part of my 5.3 conversion. I'm having a conflict with the sway bar when turning the wheels. It looks like guys with bags don't use a sway bar... I got to think my truck would sway pretty bad without anything.
Any suggestions on modifying/bending such a large sway bar?
Mondo is offline   Reply With Quote
