Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 01-16-2012, 08:51 PM   #101
1970ChevyC-10
Re: 1967 C-10 LS POWERED Build
may i ask how much your paint and clear was? and also what type of dupont paint it that?
1970ChevyC-10 is offline   Reply With Quote
Old 01-16-2012, 08:59 PM   #102
LSPWRD67CHEVY
LSPWRD67CHEVY's Avatar
Well its electron blue. I don't have the paint code with me, but I can supply that later. 1 gallon is around 350 dollars i think and 1 gallon of clear was over 100 dollars. Plus the activator and all the other goodies.
1967 C-10 (project)
1964 Pontiac Lemans (Treasure lol)
2009 GMC Denali Truck (DD)
LSPWRD67CHEVY is offline   Reply With Quote
Old 01-16-2012, 09:47 PM   #103
1970ChevyC-10
Thats not that bad of a price but if you don't mind could I get the paint code because that blue looks awsome
Old 01-16-2012, 09:50 PM   #104
LSPWRD67CHEVY
I'll get it to you as soon as i can.
1967 C-10 (project)
Old 01-16-2012, 09:53 PM   #105
1970ChevyC-10
Okay thanks man!
Old 01-26-2012, 06:36 PM   #106
LSPWRD67CHEVY
sorry it took so long here is whats on the label of the Can > Electron Blue, Code 21, P1953K, Value Shade #6.
1967 C-10 (project)
Old 01-26-2012, 06:44 PM   #107
LSPWRD67CHEVY
Haven't updated in awhile, but heres what I got. After fitting the headers we took them back off and pulled the transmission. I'm going to be overhauling it with a high performance kit from summit and I've already got an upgraded Sprag for it. Still havent decided what Converter to go with? I'm thinking around a 4,000 stall would be about right for my setup. I also went with a Holley Ultra HP 750 Carb and Holley fuel pump. Heres a couple of pics..
1967 C-10 (project)
Old 01-26-2012, 09:00 PM   #108
noonzor
Very Sick Dude!! looks great, i like that carb!
69 c10 Shortbox Build
http://67-72chevytrucks.com/vboard/s...d.php?t=360622
noonzor is offline   Reply With Quote
Old 01-26-2012, 10:30 PM   #109
Super73
Super73's Avatar
If you can wait until I get back from Oregon, I can put your combo in my Performance Trends engine analyzer program. It will give you a very good idea of what this combo will put out and where it will peak. If you are trying to get everything you can out of it in the 1/4, you will want a converter that is at peak TQ. Since you reminded me about commenting on your set up before, I relooked at it and would guess you are going to make peak torque upwards of 5k rpm. In other words, if you are trying to get the best 60' out of it, a 4k stall might be too small.
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 01-26-2012, 10:41 PM   #110
LSPWRD67CHEVY
That's fine with me man. I appreciate it. My only thing is since its a stock bottom end I didn't really want to take it over 6500-7000 for now. Its kinda of a budget build in a since, and by that i mean i just cant go all out in every area right now, so i just thought if i was shifting around 6500-7000 i shouldn't go to big on a stall if that makes any sense lol.
1967 C-10 (project)
Old 01-26-2012, 10:54 PM   #111
Super73
Super73's Avatar
Ok, I had a minute and modeled it. I used 10-1cr as I am not sure what gasket etc you are using. Stock L92 heads, singlplain with a 750 non vacum carb, 1 7/8 headers/30" long and the am is set on a 108 intake centerline.
Peak TQ is way up here at 5,700rpm = 438ftlbs
HP Peaks at 6,800 and carries it to about 7,100 = 519hp
Old 01-26-2012, 11:03 PM   #112
LSPWRD67CHEVY
Cool deal! The compression ratio is 9.67:1 according to GM service information. The cams center line is 110 and as far as the head gaskets. I just used GM factory gaskets and head bolts.
1967 C-10 (project)
Old 01-27-2012, 12:41 PM   #113
noonzor
seems high rpm for peak tq, but a good number nonetheless! not bad for a budget build eh! Super73 can i throw you my numbers and have something figured out? lol.
Old 01-27-2012, 03:17 PM   #114
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
yeah...me too!
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 01-27-2012, 07:06 PM   #115
Super73
Super73's Avatar
Yes.. But please find my original motor thread so we are not hijacking this thread. I will try to get to them next week when home.
Old 02-05-2012, 12:19 AM   #116
1BADLS1tuner
Great looking build!
1BADLS1tuner is offline   Reply With Quote
Old 02-08-2012, 07:54 PM   #117
Gobbles
Gobbles's Avatar
Awesome build and gorgeous truck, I look forward to more updates!
Trevor
"You already said spite"
Gobbles is offline   Reply With Quote
Old 02-16-2012, 11:11 PM   #118
nomrlz
nomrlz's Avatar
very nice build
nomrlz is offline   Reply With Quote
Old 02-18-2012, 10:03 PM   #119
rmvlt1100
rmvlt1100's Avatar
Very nice project you have there. I like that color very deep looking. I was wondering about the headers that you used. Did you have the do any grinding or cutting to the frmae to get them to fit? I a have a 1965 C-10 and I think that the frame is close to the same dimensions as yours. I seen other people have used Dynatech headers as well just not form that year range. Well thanks for any info that you could pass on to me. Have a good night.
rmvlt1100 is offline   Reply With Quote
Old 02-19-2012, 11:11 AM   #120
LSPWRD67CHEVY
Well for starters, the motor mounts that I have are home made. So i went with these headers for a couple reasons they aren't as high as dougs thorleys, and they look better in my opinion. all i had to do to my frame was take little slivers out of the top C Channel where the tubes come off the cylinder heads. Everything else is as you see in the pic. All you can do is order them and try it out honestly.
1967 C-10 (project)
Old 03-06-2012, 11:26 AM   #121
LSPWRD67CHEVY
Well I haven't got much done here lately. I finally got my transmission built a few weeks ago. Called Dave over at Yank and got my converter ordered. Hopefully it'll be here by the end of this week and I will post up some pics of it and the transmission before the install. This last weekend we got the back glass put in and some little stuff like door handles and such.. here's a few pics..
1967 C-10 (project)
Old 03-06-2012, 12:40 PM   #122
ripdog28
ripdog28's Avatar
great looking build. I love the blue with the rims, they set eachother off. Just something i have learned from my build, Get your rear suspension set up before getting it finished. Seriously, that power and stock springs/ shocks will not work. even if your just thinking about it in the future, get coil overs on there now. they will ride just fine and you can hook at the track when needed. Usually can find some for $150-300 each and do not take much work to put on. I wish i would have done it earlier in the build.
69 c-10 BBC
462ci, forged crank, H-beam rods, 10.5-1 KB forged pistons, Dart Iron Eagle 308cc, Straub Cam, Comp Cams chrome moly full rollers, Weiand Team G, Prosystems 950, TH400/3500 Dalenzie stall, Currie 9+ Detroit Locker w/31spline axles.3.5/6in drop. My Build.
ripdog28 is offline   Reply With Quote
Old 03-06-2012, 12:59 PM   #123
LSPWRD67CHEVY
I hear ya man. I've been looking at a universal qa1 coil over setup for the rear. It'll definitely get done before I finish it. For me it's just a matter of money. One side job at a time lol!
1967 C-10 (project)
Old 03-06-2012, 01:04 PM   #124
noonzor
slick man! looking great!
Old 03-23-2012, 07:00 PM   #125
LSPWRD67CHEVY
Well this thing is coming slowly, but surely. I finally got my converter about a week ago and I also bought a SFI flywheel from yank. I got everything bolted in a couple nights ago. Been playing around with the exhaust. I hung some 3 inch straight pipes and some elbows just to see how it would look. We had the stuff laying around so its cost effective lol! Well here's a few pics of the stuff..
1967 C-10 (project)
