Old 10-13-2011, 12:18 PM   #101
67cheby
67cheby
67cheby's Avatar
Re: 1971 c10 stepside
SWEET ..i like em
67cheby is offline   Reply With Quote
Old 10-13-2011, 12:30 PM   #102
big_al_71
big_al_71's Avatar
They look really good ..... I will come check them in person later.
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 10-13-2011, 02:14 PM   #103
CC69Rat
CC69Rat's Avatar
285/35/22 on a stepper? I don't know man.. You leaving the stock fender wells, and/or mini tubs in the rear?
Hoping I'm wrong. Do you have the early rear end? 22x9 - 5"BS?
What are the height / width specs on the rear tires? You're probably going to need to loose the support braces at least and/ or trim the fender lip a bit.
Again, not meaning it negatively at all. I know a 265/40/22 - 5" BS with the early rear end requires trimming to fit. Assuming you're bagging the truck (?)
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
Old 10-13-2011, 02:56 PM   #104
raull
raull's Avatar
thanks for the info i can use all the help i can as i've never done an old chevy truck , i know for a fact i will have to modify or even delete the brace for the drop , as far as the lip , we measured and got the right back spacing it's 5. so i'll post how it turns out when they are on
check out my build thread
71 c/10 step side 5.3 twin turbo
http://67-72chevytrucks.com/vboard/s...d.php?t=485320
raul
raull is offline   Reply With Quote
Old 10-13-2011, 07:24 PM   #105
CC69Rat
CC69Rat's Avatar
Ok, cool. Best of luck to you on the build! It's already looking awesome. Nice choice on the wheels too.
Chad
Old 10-14-2011, 09:03 AM   #106
raull
raull's Avatar
thanks, not my first choice for wheels but the had the matte look i was looking for since i already have billet intros on my other ride, i wanted something different , as for the tire size i did some research and the 285 are 700 thousands wider than the 265 so that makes it a 350 thousands split between inner outter wall which its about 11/32 of an inch so if i have to trim it will be minimal , im hoping , thanks again
raul
Old 10-14-2011, 01:19 PM   #107
VA72C10
VA72C10
VA72C10's Avatar
cool! love the way coys look on our trucks and the new finish will set it off!
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 10-16-2011, 03:46 PM   #108
raull
raull's Avatar
well i got the suspension on friday but work and family activities has kept me away from the truck , so this morning i snuck in the garage for 2 hours before wife and kids woke up and took apart the front end , cleaned and sprayed with some more bedliner spray and made the cuts for rear c notch , oh and yes 2 more fregging rivets showed up on me , : hate them ,now off to friends house for red zone football ,
raul
Old 10-16-2011, 04:26 PM   #109
big_al_71
big_al_71's Avatar
Great job brother!!!!!
Old 10-16-2011, 04:53 PM   #110
67cheby
67cheby
67cheby's Avatar
Nice !!
Old 10-16-2011, 05:37 PM   #111
jmedero
jmedero's Avatar
Nice. Engine and trans are out brother. Tomorrow I'll pull the harness and tank. She's moving right along.
68 BB burb build thread Scott's super slam front/rear
http://67-72chevytrucks.com/vboard/s...d.php?t=378084
jmedero is offline   Reply With Quote
Old 10-16-2011, 09:46 PM   #112
raull
raull's Avatar
very good , thanks 4 d update
raul
Old 10-19-2011, 09:33 AM   #113
raull
raull's Avatar
hello boyz , its been none stop raining for the past 4 days here in south florida , but that wont stop me , found shelter to do some painting in a parts shed , and put toghether most of suspension but i ran into a few misshaps ,
also started to strip rear end for disc brake set up and a stubborn gear shaft woul not give , so i snaped a spring of the possie unit so thats when i called it quits as it was midnite already , here r some pix !!!!!!!!!!!!!
raul
Old 10-19-2011, 09:34 AM   #114
raull
raull's Avatar
pix
raul
Old 10-19-2011, 09:39 AM   #115
67cheby
67cheby
67cheby's Avatar
looks good !! like the silver contrast
Old 10-19-2011, 09:41 AM   #116
raull
raull's Avatar
pix
raul
Old 10-19-2011, 09:44 AM   #117
raull
raull's Avatar
sorry for some reason today i can only uoload 1 pix at a time !!!!
raul
Old 10-19-2011, 09:49 AM   #118
big_al_71
big_al_71's Avatar
Great progress bro....you are flying thru this,,, I know that you are in heaven enjoying the built....
Old 10-19-2011, 12:31 PM   #119
VA72C10
VA72C10
VA72C10's Avatar
Looking good!!!
Old 10-19-2011, 05:49 PM   #120
lolife99
67-72 parts collector,…
lolife99's Avatar
Great progress.
I do have a concern.
I think you have your upper a-arms on the wrong side.
This appears to be the "passenger side" upper a-arm mounted on the "drivers side".
Keith
Convert to disc brakes.
Old 10-19-2011, 06:16 PM   #121
raull
raull's Avatar
WoW buddy , good job , late last nite i presented that side to take a picture and i notice it was stamp wrong , ( both sides ) so i swap them , gave ride tech a call today to let them know but i did not post it in here as i dont like to put nobody down , thanks for looking out though ,
raul
Old 10-20-2011, 09:37 AM   #122
raull
raull's Avatar
last nite i ran air lines to the rear and put back together the rear end gears so as for now im waiting on u bolts for front lower arms arriving tomorow as well as shock studs that were missing from the order and disc brakes kits that should arrive today , next task is to modify panhard bar bracket to work with the aluminum rear end cover
raul
Old 10-20-2011, 09:39 AM   #123
raull
raull's Avatar
pix
raul
Old 10-20-2011, 09:48 AM   #124
69CST-V
69CST-V's Avatar
I might be the picture hiding it, but on the lower control arm. There should be a bracket to the front in the middle of the tube for the sway bar link. I didn't see it in the picture so I was just wanting to make sure.
Great progress by the way.
Bryce
'69 SWB Fleet Still Under Construction
Company Trucks
69CST-V is offline   Reply With Quote
Old 10-20-2011, 10:41 AM   #125
raull
raull's Avatar
you are right, they sent some extra brackets in case i want to install in the future , they only welded the ones to the rear for the shocks ,
raul
