Old 07-25-2012, 07:58 AM   #101
ERASER5
ERASER5's Avatar
Re: Project racing $$$. 1968 GMC SWB 5.3/4l60E Build
I like the grill inserts. Sharp. Too bad no one makes a real GMC bumper.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 07-25-2012, 08:33 AM   #102
mcbassin
Still Learning
mcbassin's Avatar
Your paint turned out great! Congrats on getting her home. Enjoy driving
mcbassin is offline   Reply With Quote
Old 07-25-2012, 01:47 PM   #103
True 67
Nice truck...I'm glad that you kept it in the family also.. As always you never get out what you put into a project like this..
True
True 67 is offline   Reply With Quote
Old 07-26-2012, 12:41 AM   #104
Priceman57
Thumbs up Re: Project racing $$$. 1968 GMC SWB 5.3/4l60E Build
We cut costs by doing all the labor ourselves so IF that da ever comes and we go to sell hopefully we will make a profit. It's defininately a one of a kind truck! Money Talks..
Priceman57 is offline   Reply With Quote
Old 07-28-2012, 01:04 AM   #105
BHyatt
What did you do with the rear shocks after the flip kit install? I made my own flip kit and was trying to decide what to do with them.
BHyatt is offline   Reply With Quote
Old 07-28-2012, 05:59 AM   #106
Priceman57
The rear shocks that were on the truck when we bought it were bad, and when we flipped the leaf springs we needed shorter shocks, so we set the truck at ride height took the sensitrack shocks off the front of the truck, and fabricated some new shock mounts that hung down and forward about 2-2.5 inches further than the stock shock mounts. That way they werent leaning back at such a flat angle.
Old 07-28-2012, 06:07 AM   #107
Priceman57
We had fender clearance issues with the front tire and wheel combination, so sadly we had to raise the truck up 1" in the front and 2" in the rear. We ended up running the dropped spindals up front with lowering springs, stock shackles in the rear, flipped the leafs, and ended up taking some leafs out of a longbed camper special. They had more of and arch and are a little stiffer. This was all benificial since Im going to be using it as my daily driver. We emded up with a 3"/5" drop and were still able to run the old school wheels with the fat tires. Down the road I may get some wheels custom made and drop it back down, but until then this will do. Also, we put the truck on the chassis dyno and had the tire sizes/shift points/air fuel mix calibrated and ended up with 260hp/300tq at the rear wheels. Plenty of power and very easy to light em up through 2nd/3rd gear. It looks and runs great!
Old 07-28-2012, 08:38 AM   #108
68Redhead
And if you ever decide to get new wheels... keep me in mind if you sell the ones on there now lol!
68Redhead is offline   Reply With Quote
Old 07-28-2012, 04:26 PM   #109
mad2rass
Beautiful.Nice work.
mad2rass is offline   Reply With Quote
Old 07-30-2012, 03:15 AM   #110
Priceman57
For sure! There's a local guy here in Sacramento that polishes aluminum wheels for cheap. I'm gonna find some center caps and get these bad boys polished up. Then its time for Vintage Air and a bedliner. Should add a final touch to this beast..
Old 10-17-2012, 06:28 PM   #111
Priceman57
LMC makes the bumper you're referring to. However, that bumper wasnt out til 69', therefore mine is correct ;-)
Old 02-21-2014, 06:55 AM   #112
Operatorfailure
Originally Posted by imsuchaman55 View Post
Some new updates with pictures.
Cluster installed and fully functional
View of dash and cluster from passenger side.
I was wondering where you got your headlight switch from? It looks so much better than the factory one!
My 68 Stepper build
Operatorfailure is offline   Reply With Quote
Old 07-20-2014, 04:23 PM   #113
Bagwurxc10
Did your tach work off the data serial wire?
my wiring harness has a white engine speed wire and my 99 z28 cluster has no where for it. Any comments would be appreciated.
Bagwurxc10 is offline   Reply With Quote
Old 07-20-2014, 04:25 PM   #114
Operatorfailure
Yes, it gets the tach signal from serial data.
My 68 Stepper build
Old 07-20-2014, 04:55 PM   #115
Bagwurxc10
Thanks I was stumped on that because I notice my 04 Silverado cluster from the donor truck has a engine speed wire. Did your fuel gage work as well. I got the sending unit off the donor truck and fitted it on my c10 pick up tube...hoping I'm going in the right direction.
Old 07-20-2014, 04:58 PM   #116
Operatorfailure
The fuel gauge should work, you have two wires from the ecm for it to work though. If I remember correctly.
My 68 Stepper build
Old 07-20-2014, 05:24 PM   #117
Bagwurxc10
Ok
Old 09-10-2014, 03:40 PM   #118
mvesr
Hey man, love what you have done to your truck. I especially like the gauges. I would like to do the 5.3 swap in 68 stepside someday put have found junkyard prices all over the place. If you don't mind I would like to find out where you got your engine trans set from.
Thanks-Mika
mvesr is offline   Reply With Quote
Old 09-11-2014, 07:25 AM   #119
Bagwurxc10
I'm a mechanic for a trucking co.we had a truck that was stolen and recovered. My company was gonna scrap the truck, so I bought the entire truck for scrap price ($500). It'll be hard to find a deal like that. On Craigslist, I've seen engines and tyranny for about $1500-$2500. Mine is the 4.8 and you can pick up those pretty cheap. It has plenty of power for me driving it everyday.
Old 09-12-2014, 02:07 AM   #120
woodwright
Enjoying left field
woodwright's Avatar
I didn't think you could buy tyranny on craigslist.
Clint
70 Chevy 4WD "Ultimate Work Truck" SOLD
woodwright is offline   Reply With Quote
