Old 05-24-2012, 09:32 PM   #101
my4by2
my4by2's Avatar
Re: Daughter's 1st Square
My girl working on her truck again.
my4by2 is offline   Reply With Quote
Old 05-24-2012, 09:38 PM   #102
my4by2
my4by2's Avatar
Here's the rear of the frame all painted up & one side of the spring hangers installed. Will get the other side on tomorrow & hopefully the actual leaf springs on as well.
Old 05-24-2012, 11:41 PM   #103
N2TRUX
Happy to be here
N2TRUX's Avatar
Too cool.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 05-26-2012, 12:11 AM   #104
my4by2
my4by2's Avatar
Got all the spring hangers on the truck & the new shackles loosely bolted on. Awaiting parts for the leaf springs so I can reassemble them & install.
Memorial Day weekend is slowing ALL deliveries which sucks, so not thinking that I'll get the new axle or any parts for the springs until at least Tuesday...
Old 05-26-2012, 05:05 PM   #105
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
Lookin good, those wheels are gonna be sweet!
Tony
1985 GMC K2500 restoration Project: Rust, White & Blue
1989 Chevy R3500 CC Cummins & 4X4 swap some day...
1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress)
1985-GMC is offline   Reply With Quote
Old 05-27-2012, 02:13 AM   #106
JPalmer81
JPalmer81's Avatar
Lookin good man, that is awesome seeing your daughter out there getting her hands dirty, gonna be a very nice truck when ya'll are done.
1988 Chevy Crew Cab 1ton 4x4 SRW LWB
1977 Dodge 1 ton 4x4
My Build Thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=516872
"The price of Freedom is Eternal Vigilance"
JPalmer81 is offline   Reply With Quote
Old 05-27-2012, 05:28 PM   #107
l79m20
what size bolts did you put in? I just bought 7/16 x inch and a half grade 8's. They are all thread no collar. Did you flat washer under head and then use lock washers under nuts? Any other advice?
l79m20 is offline   Reply With Quote
Old 05-27-2012, 10:20 PM   #108
my4by2
my4by2's Avatar
Are you referring to the bolts for the leaf springs to the hangers/shackles? If so, I ordered new ones from LMC Truck. I contacted a company called ATS (Auto Truck & Spring) for the center pin bolts & spring pads - then just Summit for the bushings.
One recommendation when ordering the bushing - MEASURE the springs first!!! Summit's listed parts for her year/make/model weren't correct.... I had to provide the measurements to get the right ones & it sucked!
Old 05-27-2012, 11:04 PM   #109
l79m20
I was talking about the bolts you used to bolt the spring hangers to the frame.
Old 05-27-2012, 11:19 PM   #110
my4by2
my4by2's Avatar
That's part of a frame hardware kit LMC Truck offers - very much worth the money spent!!!
Bell Tech hangers didn't line up well with frame holes, so had to open them slightly. Also the holes for the lead spring bolts were a bit small too...
Old 05-28-2012, 12:22 PM   #111
l79m20
How many sets of those did you buy? Are you going to replace all of the rivets on the frame? How long are the bolts in that kit?
Old 05-28-2012, 12:52 PM   #112
Pyrotechnic
Pyrotechnic's Avatar
Is that a 16 gallon Jaz fuel cell? Are you just going to do a cut out and door in the bed floor above the cell, are do you have something more exotic planned for the filler?
Cool to see her getting her hands dirty.
1977 GMC Sierra Grande
Pyrotechnic is offline   Reply With Quote
Old 05-28-2012, 06:26 PM   #113
my4by2
my4by2's Avatar
It's just the one kit, but it does come with enough fasteners to do all the rivets if desired - We didn't do them all, just the ones for the spring hangers & maybe some elsewhere once we pull the front clip & cab down the road.
Old 05-28-2012, 06:29 PM   #114
my4by2
my4by2's Avatar
It is a 16-gallon, but it's from Summit & it's their brand. Has the foam inside it also.
Yep, gonna install a billet fuel door in the bed floor via a steel mounting ring. Will need to install an extension as well. Copied this idea:
http://www.73-87.com/7387garage/chas...ellinstall.htm
Old 06-01-2012, 04:04 PM   #115
my4by2
my4by2's Avatar
Here's where we ended up at on my Daughter's truck - not as far as I'd had hoped to get, but with the parts order snafu for the leaf spring bushings I simply couldn't get the left rear leaf spring mounted & therefore couldn't get the rear axle mounted...
We did manage to get the fuel cell mounted up in place & that turned out pretty nice. I do still need to modify the bed floor for that opening & also clearance the support rib underneath for the new Belltech spring shackles.
Was so proud of my little girl & how much work she really did put into this project so far - not only that, but maintained excitement & interest all the way through!!!
Was truly some of the best times I can remember with her!!!!!!
Old 06-01-2012, 04:43 PM   #116
Cole Trickle
C-10 Club Member
Cole Trickle's Avatar
Awesome thread....
Good job Daddy/Daughter
1969 Short Fleet 350/SM465 4.5/6.5 ECE drop 20" Raceline Wheels
1998 2dr Tahoe 5/7 drop 20"/22" Coys-sold
Build thread...http://67-72chevytrucks.com/vboard/s...d.php?t=401910
Cole Trickle is offline   Reply With Quote
Old 06-03-2012, 10:34 PM   #117
jbclassix
Junk Yartist
jbclassix's Avatar
Cant wait till my kids are old enough to work on their own trucks!
-Jeremy
YOU ONLY FAIL IF YOU STOP TRYING
70 Crew Cab Build Link
70 GMC Suburban 4X4 build thread
95 Yukon Daily Driver
Rebuilding an NP205
jbclassix is offline   Reply With Quote
Old 06-04-2012, 12:58 PM   #118
77BBGMC
77BBGMC's Avatar
Good to see the daughter involved, that will make for some good memories!
77BBGMC is offline   Reply With Quote
Old 06-05-2012, 12:10 AM   #119
my4by2
my4by2's Avatar
Another shot of my Daughter & I working on the truck together! Got this from my Wife's Facebook photos - didn't even know she took it...
Old 06-05-2012, 12:32 AM   #120
my4by2
my4by2's Avatar
Didn't get a shot of her rear axle after it got to the house, but here it is all finished up at WFO prior to shipping. Wish I could'a got it installed, but it'll just have to be on the next trip I guess...
Old 06-05-2012, 08:29 AM   #121
BigMike608
BigMike608's Avatar
Wow, I wish my daughter was into trucks like this. You're a very lucky guy to have the opportunity to share this type of experience with your daughter. Congrats and keep up the good work!
1977 SWB C10 - "Woodson": 5.3 Vortec LS Swap, 4L60e Trans, 4.5/5 drop
BigMike608 is offline   Reply With Quote
Old 06-05-2012, 08:49 AM   #122
GCncsuHD
Charlie Daniels w/ a Tq Wrench
GCncsuHD's Avatar
Subscribing to this one. Great pics, I've been following your other build, it's great that your daughter is that interested in the hobby, I can only hope one day my children will be as well.
ΜΟΛΩΝ ΛΑΒΕ
67 C10 Shortbed "Great Grandpa's Truck" I6 3 on the Tree 71k original miles 5.3 swap in the works
69 K5 Blazer-Family Beach Cruiser Project
78 K30 Dually Semi-Retired Fire Truck 350/SM465 35"s
SOLD01 2500HD ECSB 6.0 4x4 5.13's 8" lift 38"s
GCncsuHD is offline   Reply With Quote
Old 06-06-2012, 12:03 AM   #123
mcbassin
Still Learning
mcbassin's Avatar
Too cool your daughter is interested in the square bodys. My little girl (15) wants a truck too, 2003-2004 model 4x4 go figure. I guess I could find a fixer upper and do what you're doing. I did a 86 with my son a few years ago. He got some sweat equity invested in it.
mcbassin is offline   Reply With Quote
Old 06-06-2012, 12:09 AM   #124
my4by2
my4by2's Avatar
She'd probably appreciate it & care for it better doing it that way - at least that's my hope from all of this! Not looking for her to become a mechanic like me, but want her to know what things her are & some idea of what's going on in case it ever breaks down or has issues. Besides, with today's vehicles & society it's becoming a forgotten art anyhow!!!
Old 08-21-2012, 11:01 PM   #125
MrBeast
high-Tech Red Neck
MrBeast's Avatar
That is going to be a pretty sweet truck.
As a bonus for you as a dad, I think once she starts rolling around in it the boys are just going to be too intimidated to talk to her, you won't even have to wave the gun around! lol
"He used to be a pretty nice feller, now he's a welder!"
MrBeast is offline   Reply With Quote
