Old 06-08-2012, 07:10 PM   #101
NewType72
NewType72's Avatar
Re: 1972 Chevy p/u NewType Build
Originally Posted by Tinkermc View Post
well back in the day that Limco paint was good for a slick and cheap paint job.
The lincoln did very well and I'm glad we put some
Flack to it it really makes the wood strips pop at night oh did I mention I drove her to work today and shell be in the graffiti classic car parade tonight?? Yeah forgot that lmao! I'll put pics up tonight for all you anxious watchers I wanna thank you for being helpful and patient with my excessive postings but I am a stickler for details and what we've done to it
Thanks -Newtype
Project NewType 1972 Chevy C/10 Cheyenne Super ( Daily Driven Showtruck ) http://67-72chevytrucks.com/vboard/s...d.php?t=507903
Project Great Grandpa's Legacy 1973 Chevy C/10 Cheyenne ( Current daily driver collecting big time parts ) http://67-72chevytrucks.com/vboard/s...89#post7084289
- Dylan
(209)-985-7721
NewType72 is offline   Reply With Quote
Old 06-08-2012, 07:17 PM   #102
NewType72
NewType72's Avatar
Limco* and mike yeah my dad says it has no way in hell making it but I think if I could get a motor tune from
A buddy of ours that it would be a lot better to make it down there for the brothers show so I'm really hoping on that
- Dylan
(209)-985-7721
Old 06-09-2012, 03:39 AM   #103
NewType72
NewType72's Avatar
Had an amazing night with my girl and my lil car club at the parade and cruising our parents old stomping grounds pretty good night and very satisfied with my truck. did have a lil bobble on the way home it kinda stuttered electrically and kicked back on guess i have a ground issue and I think my ignition is going out as well some few bugs but not huge ones gonna be up bright and early to shine and show for my sponsors if you're in the area stop for the car show it's an awesome event
and yes my best bud drives a stang how ironic huh?
- Dylan
(209)-985-7721
Old 06-10-2012, 08:39 AM   #104
naphtali5725
naphtali5725's Avatar
very nice truck man
My build thread...
http://67-72chevytrucks.com/vboard/s...d.php?t=515829
Disabled Veteran
82nd Airborne Division
Operations: Desert Shield, Desert Storm, and Uphold Democracy
naphtali5725 is offline   Reply With Quote
Old 06-11-2012, 07:44 PM   #105
NewType72
NewType72's Avatar
Thank you
- Dylan
(209)-985-7721
Old 06-12-2012, 11:41 AM   #106
NewType72
NewType72's Avatar
Hey boys got a question for you all my 12 bolt rear end has been howling like a mad man that can't get his skippy from the top shelf so I need some advice on how to change the fluid in this bad boy and put more in but I'd like to have an idea of what to put in that would be a great long lasting oil. Price doesn't scare me having my rear end explode does tho haha so yeah any help much appreciated
-newtype
- Dylan
(209)-985-7721
Old 06-12-2012, 01:32 PM   #107
67barnfind
67barnfind's Avatar
If your rear is howlin' I'm pretty sure that you're past a simple fluid change... From my past experiences, every time the rear went to making that sound, the lash was off between the ring and pinion gears.I would suggest pulling the cover for a fluid change anyway, but while it's all open, with the tires off the ground, you can check the lash between the gears. (This just happened with a friend's truck, it ended up breaking teeth off) The lash should be less than .012 What brand gears were used? Some brands are just plain noisy. most gears (aftermarket) will run between .006" -.009". The newer OEM gears run tighter (.002 -.004) since they are made with a 2 cut process instead of a 5 cut like the older oem & aftermarket gears use. Just a thought... Good luck!
67barnfind is offline   Reply With Quote
Old 06-12-2012, 02:49 PM   #108
NewType72
NewType72's Avatar
I've never been into the rear end on this truck it's the only thin I truly haven't touched so I have no idea what's inside it. As for checking the lash what exactly is that when you look inside? Or what am I looking for damage wise? I hope it's not that bad but If so it prob means i need to start scrounging money for that ford 9 inch that I have my eyes on at a buddies. The truck has been kinda lurching when coming to a sudden stop and has even decided to spin both wheels last weekend it's acting very odd
- Dylan
(209)-985-7721
Old 06-15-2012, 09:55 PM   #109
72SWBChevy
72SWBChevy's Avatar
Looks great, your progress was awesome!!
1977 Camaro 468 BBC - SOLD -
1972 Chevy SWB....in the works!!
2006 Crew Cab Dmax/Allison Summit White-SOLD-
2009 Toyota Tacoma V6 Pre Runner - daily driver -
my build thread -http://67-72chevytrucks.com/vboard/s...95#post4774595
72SWBChevy is offline   Reply With Quote
Old 06-15-2012, 11:33 PM   #110
NewType72
NewType72's Avatar
thank you man problem now is my rear end is starting to REALLY give out the howling has become worse so i guess it's time i start saving for my buddies ford 9 inch so I'll have a new project to get my hands dirty with here in a month or so
- Dylan
(209)-985-7721
Old 06-19-2012, 10:54 PM   #111
NewType72
NewType72's Avatar
Hello all I know I haven't updated in awhile right now I'm just in recovery mode from all the spending I've done the past two months so now it is time to start saving up for my new investment being a FORD 9 INCH! I know I know a ford part on my cheby buuuuut it'll save me a ton from rebuilding my old faulty 12 bolt soo with this all in mind I'll be needing to gather some info on how exactly and what exactly entails this kind of swap I have my turbo 350 trans in now so will i need a longer or shorter driveline? or can I stay the same? I'll need new saddles for the rear end support on my truck arms and somehow lineup the rear end side to side oh and as well as swapping the axles within to chevy bolt 5x5. gear ratio is important too so I have no clue in this department.
- Dylan
(209)-985-7721
Old 06-20-2012, 10:56 AM   #112
Tinkermc
you ask about oil I use Amsoil, it is pure syn. also seems to last forever and they warrenty for double the manufactures mileage on changes. truck looks real good.
Tinkermc is offline   Reply With Quote
Old 06-20-2012, 11:10 PM   #113
El Campo
El Campo's Avatar
12 bolt is still a great rear end. I had one under my truck and it makes well over 600 HP. Takes some serious coin to put a 9 inch under them because you have to change the axles among other things. I have considered it too but the 12 bolt held up fine even on the track with stock axles. I also have one that I could get fairly easily but have wondered these questions that you have. Maybe someone who knows more than us can clue us in? Nothing looks better than a 9 inch either
72 Chevy blue LWB, 99% original Oklahoma truck, 28,000 miles
72 Chevy SWB: http://67-72chevytrucks.com/vboard/s...d.php?t=486626 (Attempt/Mistake #2)
2003 Harley Davidson Dyna Superglide with 2007 Street Bob front end
2000 Ford F350 Powerstroke 4WD CCLB, 310,000 miles running great (STOLEN St. Patricks Day 2014 AND NEVER RECOVERED)
2002 Ford F250 Powerstroke 4WD CCLB (To replace stolen one)
Hook em Horns!!!
El Campo is offline   Reply With Quote
Old 06-20-2012, 11:30 PM   #114
NewType72
NewType72's Avatar
Thanks Tinker. I may just end up pulling the cover off and filling up with new oil see how she goes before I get too far in
no doubt I've really punished this one but it's the original it's ready to go ad soon. I have about 200$ for the rear end itself disc included just need to hand back some brackets to the guy. I have a friend that will do the saddles and a shop that could mount it all up on a surface plate as well. I wouldnt mind havin it broken into and rebuilt before going on and the axles i could bite the bullet on. I'd love to have disc all around even if this truck stops better than most vehicles i drive already haha
- Dylan
(209)-985-7721
Old 06-24-2012, 06:49 PM   #115
NewType72
NewType72's Avatar
Picked up quite a few pieces to the puzzle thursday night. Went out to the c/10 king's ranch ((Thank you Rene!!)) and he helped me go in the right direction talked for quite awhile on past and present matters and picked up a few items including a front pair of stock springs and a factory green tint rear solid glass which I'll be prettying up and tinting within the week hopefully. I also threw those springs in yesterday amongst other things to work on through the day so here's some pic's of that update
From right to left 2" drop springs didn't work at all (for sale) 1" drop springs also didn't work at all (also for sale) and finally the stock height
dis assembly of the suspension
dropped roughly so I had to fit in two spring helpers to get it off the tire it does better but I'm still looking for a better solution
- Dylan
(209)-985-7721
Old 06-24-2012, 07:33 PM   #116
67cheby
67cheby
67cheby's Avatar
You might look at CPP's modular spindles they narrow the front a little, looks good !
67cheby is offline   Reply With Quote
Old 06-24-2012, 08:41 PM   #117
NewType72
NewType72's Avatar
narrowing would be awesome but with my 15's im maxed with room to move in before i rub my a-arm
- Dylan
(209)-985-7721
Old 06-24-2012, 09:50 PM   #118
Tinkermc
in thatlast picture the wheel looks to be rear of center. Is it? or is it camera angle?
Old 06-24-2012, 11:01 PM   #119
NewType72
NewType72's Avatar
with the width of the tire it makes it look further back than it should be but I just looked now and it might be a tick to the rear but cant tell with the way these bodies are
- Dylan
(209)-985-7721
Old 06-28-2012, 03:18 AM   #120
David67
David67's Avatar
Man I love red/white two tones! Looks awesome. I actually thought about doing a white top and maybe grille? My tailgate letters will be white so that has to count for something lol
1967 C10
Fightin' Texas Aggie Class of 2015
IG: david_r67
David67 is offline   Reply With Quote
Old 06-28-2012, 08:37 AM   #121
mcbassin
Still Learning
mcbassin's Avatar
Very cool project! you have really knocked this build out! Love the red paint.
mcbassin is offline   Reply With Quote
Old 06-28-2012, 11:11 AM   #122
NewType72
NewType72's Avatar
That would look wicked too David and I think my letters will be white as well at least until I put the band across the tailgate to cover those gourgeous embossed letters
Thank you mcbassin but my work is never done I gott fix up the rear end to last me another half year and then get the motor a nice tune then in half a year a full power train replacement yay! More money! Hahahaha
- Dylan
(209)-985-7721
Old 06-28-2012, 03:17 PM   #123
dracula4999
dracula4999's Avatar
Very nice truck! My question would be, why dont you just get some wheels with the right backspacing to keep from screwing up tires??? instead of spending money on different springs, or bags or helper springs...just fix what is causing the problem. Just my .02
71 GMC long bed
70 Chevy short step
71 Chevy K10 long bed
dracula4999 is offline   Reply With Quote
Old 07-03-2012, 01:48 PM   #124
NewType72
NewType72's Avatar
Well I have a solution I desperately want a smoother ride springs just can't cut it for me drop spindles are a lil pricey when mine are a year old so it looks like I'm going to going with BAGS! Yup gonna build up some cash and start getting stuff ready to install front end airbags manual no compressors or Tanks this is purely ride comfort for me
- Dylan
(209)-985-7721
Old 07-03-2012, 01:50 PM   #125
NewType72
NewType72's Avatar
Had quite enough of ten mph turns going to the movies with the dad and my father rubbed the tires the entire way got to give it up for copper cobra tires though they take a hell of a beating
- Dylan
(209)-985-7721
1972 chevy c10, cheyenne super, rebuild, restoration, showtruck
