Old 11-24-2015, 02:18 PM   #101
focusedontheprize
focusedontheprize's Avatar
Re: 1949 Chevy 3100 - the journey begins
Installed 4 tie downs in the bed. I decided while I was installing those, I would add a trunk for some extra storage space.
focusedontheprize is offline   Reply With Quote
Old 03-08-2017, 09:29 PM   #102
MIKESAD50
Have you been driving this since the end of 2015 with out changes? You say you made a nice trip to TX. how did the truck perform? Advice to improve it?
1950 3100 5 window
MIKESAD50 is offline   Reply With Quote
Old 03-08-2017, 10:52 PM   #103
focusedontheprize
I have - the truck is my daily driver and I love it.
Yeah, I just made the trip from California to Texas in it. I was hauling a 350 in the back with the engine stand. The truck rides on a dropped solid axle with TCI drop springs out back. It drove and handled fine on the trip. I was doing 75 and turning just around 2300 RPMs. It is a great cruiser.
With that being said, I am looking to do a lot more of the long distance trips and thus the reason I am putting a 4 link out back right now and a IFS out front in the future. Just looking to make it as comfortable as possible and setting it up for the future heart transplant (eventually a LS swap).
I think your build is spot on. You are doing everything right (in my mind and experience) on setting up the best daily driver with power. I also like you are keeping the patina, the truck will be a badass sleeper.
Old 03-08-2017, 11:47 PM   #104
54 LS-3100
54 LS-3100's Avatar
I can't decide between the tci leaf kit or a parallel 4 link out back. Most of the guys I talk to about the tci kit say it's the way to go, but don't have the miles on the kit like you do.
Thoughts? It will be on a cruiser with mustang II out front, a Ford 8.8 out back, and powered by a 5.3/ 4l60e. Not building a high HP track monster
54 LS-3100 is offline   Reply With Quote
Old 03-08-2017, 11:56 PM   #105
focusedontheprize
It will be a good setup and I think you'll be very happy with it. I am running a 8.8 out back also. 31 splines, 3.73 gears, disc brakes, and a posi unit - all for $125 out the door - it was a no brainer for me.
Old 03-09-2017, 11:03 AM   #106
Desert1957
Desert1957's Avatar
OMG, $125.00 tell me where? I could use one.
Desert
Desert1957 is offline   Reply With Quote
Old 03-09-2017, 11:07 AM   #107
Desert1957
Desert1957's Avatar
Originally Posted by TNACUSTOM View Post
It is weird how on the east coast you can't fine these trucks. I can drive around in a afternoon and at least five sitting in driveways or yards.
PM me , I will give a finder's fee if I can locate something decent.
Desert
Old 03-09-2017, 02:54 PM   #108
focusedontheprize
A local pick-n-pull. I specifically looked at Ford Explorers that were 1995 and up. I believe it was the first year they included disc brakes.
Old 03-09-2017, 04:15 PM   #109
wolffcub
wolffcub's Avatar
To catch this up...I had the chance to drive the truck 3 weeks ago when I was home. I had swapped in the transmission and put in the adjustable T/O bearing from Novak at the time. It was a life saver.
The truck drives great...I can tell it has a difficult breathing through that single barrel carb and that intake so that will be the first thing to be swapped out..but other than that it drives great.
My wheels caps finally arrived from Wheels Vintiques....
what are your tire size specs?
52 Chev 1300,55 235 40 over, 848 head, dual Edelbrock intake, Fenton headers, CW 32/32 carbs, 251 cam, HEI, T5 Trans, 3.23 rear, 235/75/r15 rubber.
If it aint broke I still try to fix it!
wolffcub is offline   Reply With Quote
Old 03-09-2017, 11:25 PM   #110
MIKESAD50
Read thru the build and very nice. Thanks for the tips and look forward to updates.
1950 3100 5 window
Old 03-10-2017, 10:47 AM   #111
99 to Life
99 to Life's Avatar
looks great
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 03-11-2017, 12:02 AM   #112
focusedontheprize
Fronts: 15x6 on 215/75/15 with 2 5/8" whitewall
Rears: 15x8 on 235/75/15 with a 3" whitewall
Old 03-11-2017, 12:19 AM   #113
focusedontheprize
As MIKEAD50 mentioned, I decided to change a few items on the truck.
It all started with the drive from California to Texas.
Friday night, the truck was packed up and loaded. I have a 350 4 bolt main in the back with the engine stand.
A little side note - since I have lived in California it maybe has rained a hand full of times. So when I brought the truck out I had intended to install a wiper motor and wipers - well lets just say I never got to it. So during the few days we tried to put something together that would work. I was close however the wipers end up not working. RainX it was...
Saturday morning I decided to put another coat or 4 of RainX on before we left
The first of many stops for fuel:
Few random shots:
Old 03-11-2017, 12:37 AM   #114
99 to Life
99 to Life's Avatar
congrats on the journey. why you bringing the engine? wipers are a must. I'v used mine so many times.
Old 03-11-2017, 12:52 AM   #115
focusedontheprize
Now that we are in Texas I really needed a truly dependable daily driver especially with these summers. I decided to upgrade the truck in segments - so I started out back first.
The truck was in Texas for 25 hours - long enough to get into trouble with it.
Removing the exhaust was the first priority. The exhaust was always something I was disappointed in about the truck. At the time I was on a very tight time schedule and decided to have a shop build the exhaust. It was one of my biggest regrets - so out it comes.
Couple hours later:
This weekend I am going to start filling the holes in the frame in preparation to box it.
Old 03-14-2017, 11:15 PM   #116
focusedontheprize
Not much for photos today. More dirty work than anything. I started to wire wheel the frame and started to fill the holes in the rear frame rails behind the last running board mount. Hopefully have both sides finished and smoothed before the end of the weekend.
Picking up the 4 link from Scott's this weekend in Fort Worth.
Old 03-15-2017, 12:33 PM   #117
OutlawDrifter
Very cool daily driver, looking forward to the 4-link setup.
1991 Z/28, 6.0L/T56
Instagram @aceshighspeedshop
Old 03-16-2017, 10:20 PM   #118
focusedontheprize
Thanks Outlaw. I am hoping to have it back on the road by July for the next show.
I started to disassemble the complete truck. Pulled the running boards, hood, front bumper, and clip this afternoon. Tomorrow I am going to pull the cab and the drivetrain. Next steps are to cut the rivets out and start filling holes/boxing the frame.
I have been searching the Internet for the best static setup and came across KC's 1953 Chevy that I fell in love with. This is the goal
Old 04-18-2017, 10:44 PM   #119
focusedontheprize
It has been quite a busy month and a half. I was in Florida for a week and then California another 3 weeks so truck time has bee limited.
Before I left I headed to Fort Worth and picked up Scott's 4 link rear suspension. Like everyone has said, the quality of the work is unbelievable. I am very happy with everything. While I was in California I placed the order an order with Scotts for the IFS and picked it up while they were in Austin at the Lone Star show. Just a few pictures from the show..
_AJ_'s bada$$ Duramax
Old 04-18-2017, 10:50 PM   #120
focusedontheprize
Went home and unloaded the Jeep. It was like Christmas - except the presents weren't wrapped and it was April.
Took inventory of the new parts and finished up the cab dolly that night.
Old 04-18-2017, 10:53 PM   #121
99 to Life
99 to Life's Avatar
nice pics and parts, damn your gonna be busy now.
Old 04-18-2017, 11:06 PM   #122
focusedontheprize
This weekend I was able to sneak away to the garage on Sunday. The garage is getting smaller and smaller by the day so I needed to organize everything and get some things off the floor. Once that was done I pulled the cab. Thanks to everyone who has posted tips and tricks on making the cab hoist - it really makes life so much easier when you are by yourself.
The garage is getting a little tight....
Tonight the girl was out with her friends so I pulled the motor and transmission. I am hoping to get to a bare frame by Sunday so I can start remove the shackles and the crossmember.
Old 04-19-2017, 08:54 AM   #123
Desert1957
Desert1957's Avatar
Just curious about $$$$$ for this conversion. Looks like roughly between $4500. to $5500. for all the "Scott's Hot Rod" parts based off his web site. with no labor.
At what point should someone consider just purchasing a completely finished chassis? or even an S10 conversion? I ask these questions based on trying to form a budget for my OWN future project.
I get the whole do it yourself thing, I know many people love the whole tear down and reassemble process. Just trying to understand every build thread I read.
Desert
Old 04-19-2017, 10:00 AM   #124
focusedontheprize
Absolutely and it is a great question. There is definitely a point where you start considering if it is worth looking for a full chassis compared vs. piecing together the front and rear clips.
My recommendation is try to really consider all your factors - money, time, your labor capabilities, and use for the truck. In my case, I had saved up a certain budget for "Suspension upgrades" so I had a fixed budget. I had priced out AME, RideTech, TCI, and other companies and no one could come close on price from me going this route. I also gave myself quite a window of time to get the suspension done so I didn't need something immediate which a full chassis helps you.
Also me personally - I did not want to do a S10 swap. So that was pulled from the cards immediately.
Old 04-19-2017, 10:01 AM   #125
MIKESAD50
John,
It was nice to talk with you.
Looking good on the truck progress. The shop/Garage space gets small quick when the truck is not much more than a frame.
1950 3100 5 window
