Old 05-09-2013, 01:59 AM   #101
hopped up
hopped up's Avatar
Re: Late 60's Vintage Modified Race Car
Just saw your progress today on the hamb and had to come look here too. Soo awesome you got somethat old picture of the car!! great job so far youve come a long way already. Almost there
hopped up is offline   Reply With Quote
Old 05-12-2013, 09:59 PM   #102
Shaun1162
Shaun1162's Avatar
Thanks! It's coming along.... Just wish things could go a little faster on it!
- 2010 Silverado
- 1984 Chevy M1028 (K-30)
- 1969 Chevy C-30
- 1933 Ford Stock Car
Shaun1162 is offline   Reply With Quote
Old 05-20-2013, 09:50 PM   #103
Shaun1162
Shaun1162's Avatar
Just a small peek
- 2010 Silverado
- 1969 Chevy C-30
Old 05-20-2013, 11:00 PM   #104
mechanixman
mechanixman's Avatar
Phew!!
That sure is looking slick!
Forgive me if you've mentioned this already, but are you aiming for street legal?
-Nick
Projects:
1952 Chevy 1 ton = The Build page
mechanixman is offline   Reply With Quote
Old 05-21-2013, 10:38 AM   #105
rambler
MOVE OVER
rambler's Avatar
just amazing considering what it started out as !
No matter where you are..... There you are...
Buckaroo Banzi
rambler is offline   Reply With Quote
Old 05-21-2013, 05:50 PM   #106
Shaun1162
Shaun1162's Avatar
Originally Posted by mechanixman View Post
Phew!!
Thanks guys! And yes, I do plan to make it street legal... Just had it certified as a street rod not too long ago- the original serial number was still on the frame in the back of the car, so that worked out good!
- 2010 Silverado
- 1969 Chevy C-30
Old 05-27-2013, 10:56 PM   #107
Shaun1162
Shaun1162's Avatar
Well, from the pictures it won't look like I really accomplished much this weekend, but in reality a lot got accomplished... I think Saturday was about a 10 hour day, yesterday was about 12 hours and today was only about 8- but I managed to put new rings and bearings (rod and mains) in the flathead. It probably sounds ridiculous to take that much time to some, but it was the first time I've ever done it, and did so without help.
I did a compression test a few weeks ago and found 80 PSI on all cylinders except for number 4, where I got about 15. So I pulled the heads, and dropped the pan. To say the least, the piston was UGLY... The top compression ring had broken and came through the top of the piston, before smashing into the head and became imbedded in the piston itself- amazingly leaving the valves intact. The rod bearing was also pretty worn, so I pulled the number 1 piston had found a similar story, except the top ring didn't come up through piston (although it probably would have soon).
Last week I pulled the remaining pistons and found every piston had a broken top ring. Fortunately the bores had remained pretty intact (except some scoring on number 4), so I used a deglazer to put some cross-hatching back in it. It was still standard bore, but all the ring lands in the pistons were worn for the top ring, so I switched them with a set I have from a different flathead I got recently. Also went with cast iron rings to help seat them easier since this motor probably doesn't have the straightest bores
Anyways, after a quick hone, new rings, and putting new bearings in (boy was the top rear main bearing a pain to change!) I put it back together and fired it up this afternoon. I was worried at first because it seemed REAL tight when I tried cranking it, but after I let the jumper pack fully charge, it started right up. Still getting a bit of blue smoke, probably just from all the oil I put on the rings and getting them seated, but no blow-by through the breather at all. Also, managed to relocate the dipstick from the drivers side (where I had a lot of interference from exhaust and the steering box) to the passengers side, which made things a lot better.
- 2010 Silverado
- 1969 Chevy C-30
Old 05-27-2013, 11:38 PM   #108
ol'blazer
ol'blazer's Avatar
still one of the coolest builds ive seen on here! are these flatheads nown for having a weak top ring?
Tyler
1980 2wd blazer
1985 k10 diesel truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=652276
1987 wrangler 4x4 build-http://67-72chevytrucks.com/vboard/s...d.php?t=663784
ol'blazer is offline   Reply With Quote
Old 05-28-2013, 12:06 AM   #109
67ChevyRedneck
67ChevyRedneck's Avatar
Sucks about the motor, but it looks cool as hell! At least it's running again!
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 05-28-2013, 07:59 AM   #110
Shaun1162
Shaun1162's Avatar
Thanks! I did have to throw a couple pictures of my C-30 in there though Not real sure about flathead having a weak top ring (first time really working on them), but I think the motor might have been stuck at some point, and someone decided to try to start it without checking inside first. It was hard to believe it ran so good though with broken rings! The only way I really knew there was as issue was with it smoking pretty good out of the passenger side...
Ya probably could have done without that hassle, but hey at least I got to learn a lot of new things! Nice to be able to start it up again though
- 2010 Silverado
- 1969 Chevy C-30
Old 05-28-2013, 10:21 AM   #111
plainred65
plainred65's Avatar
Looking real good! Bet it sound nice too!
plainred65 is offline   Reply With Quote
Old 05-29-2013, 10:32 PM   #112
Shaun1162
Shaun1162's Avatar
Thanks, and yes it does Got that flathead sound for sure... Not too loud at idle, but when it wound up, people will notice it
- 2010 Silverado
- 1969 Chevy C-30
Old 05-29-2013, 11:29 PM   #113
ol'blazer
ol'blazer's Avatar
it would be awesome to see a video of this in action!
Tyler
1980 2wd blazer
Old 06-02-2013, 05:18 PM   #114
quadzero
quadzero's Avatar
What an amazing project and what a great piece of history you found. Congrats on your new street car and wanting to save this awesome car.
quadzero is offline   Reply With Quote
Old 06-02-2013, 10:36 PM   #115
Shaun1162
Shaun1162's Avatar
Don't think I have any video cameras, but maybe one of my friends does... Did the brake lines and started bleeding them this weekend, so a first real "test drive" should be in order soon!
Thanks!
- 2010 Silverado
- 1969 Chevy C-30
Old 06-06-2013, 11:33 PM   #116
Shaun1162
Shaun1162's Avatar
Just a quick update...
Here's the new master cylinder in place:
Originally it had a GM single pot master (with a screw top- believe they were only made in '63) but when I ran the casting number on it, it came back as a single or a dual. Figured to be on the safe side I might as well go with a dual. I forget what material the brake lines are made out of, but they have sort of a copper tone to them- sort of reminds me how most of the brake and fuel lines used to be copper on these old cars! Had a kit for 1/4" line and was able to use correct fittings to go right into the master cylinder without crude looking adapters- definitely helped with the space restrictions there too...
Also drilled and pop-riveted the driver's side door "flap" (no more green tape holding it down!):
And for the heck of it I went and installed my mirror:
- 2010 Silverado
- 1969 Chevy C-30
Old 06-07-2013, 01:42 AM   #117
XJAbuzer
Looks great. I cannot wait to see it with the numbers.
XJAbuzer is offline   Reply With Quote
Old 06-08-2013, 10:45 AM   #118
Thealien
Thealien's Avatar
Wow, great job/project.
Old 06-09-2013, 10:52 PM   #119
Shaun1162
Shaun1162's Avatar
Thanks!
Hopefully soon!
- 2010 Silverado
- 1969 Chevy C-30
Old 06-25-2013, 11:17 PM   #120
Shaun1162
Shaun1162's Avatar
Got the wiring about 90% done- just need to do the speedometer, windshield wiper (waiting on the windshield itself), and then I have to re-do the front turn signals (for some reason changing the old sealed beams to new ones made it so the amber light couldn't be seen from the front?!).
Anybody from NH happen to know if parking lights are required?
Yesterday I managed to take it for it's first real test drive (sshhhh don't tell the cops!)... Wasn't too far, just a 1/2 mile or so up a dirt road- BUT it was still nice to get out of 1st gear for a change! Overall went pretty good, needed to adjust the clutch (think I've got that figured out now), and do some more brake work. I've got most of the brakes figured out now (finished my parking brake tonight), but the master cylinder is still kind of bugging me.
The brakes don't seem to do much until the pedal is about 1/2 way, and I if I really push, I can push it right to the end- doesn't really seem to pump up either.... But it'll still lock up the brakes when I push in far enough- does that sound right??
(Still have to tidy up the wires!)
- 2010 Silverado
- 1969 Chevy C-30
Old 06-28-2013, 09:04 PM   #121
JHT67
JHT67's Avatar
Man this ride is so dang awesome.
Going through life's daily grind, I can feel the effects of this physical body's fleeting days, But with a young spirit I look toward a brighter day, knowing that in the eyes of eternity, I am but a babe in the arms of my Lord.........
JHT67 is offline   Reply With Quote
Old 07-01-2013, 11:24 PM   #122
Shaun1162
Shaun1162's Avatar
Go easy on me guys, this was my first time numbering a car:
- 2010 Silverado
- 1969 Chevy C-30
Old 07-01-2013, 11:32 PM   #123
Shaun1162
Shaun1162's Avatar
Thanks!
- 2010 Silverado
- 1969 Chevy C-30
Old 07-01-2013, 11:46 PM   #124
hopped up
hopped up's Avatar
great job man!!
Old 07-02-2013, 12:04 AM   #125
mechanixman
I love it.
It really looks tip top.
I know you were following the original numbering, but I would have painted the 210 sloping down instead of up on the passenger side.
But nonetheless still great
-Nick
Projects:
