01-22-2013, 08:04 PM | #101 |
Re: 64 1ton (delivery day)
well i got the column fitted with the extension shaft, so now i get to pull it again and drill the holes thru the shaft and use some grade 8 bolts to complete that part, once that is done i can start on the M/C install, i just need to go find a 7/16 20 hex coupler so i can extend the push rod for the brakes. i will also button up sway bar install, i have a lead on the brackets for the power steering pump, then plumb everything and then i get to start moving fluid again and again, the i will start on the trans swap, boy am i having fun. i have found the trans x-member, i'm back and on a roll LOL like on the ground sucks trying to get up !
1964 1 Ton flatbed service truck (sold) 1964 C-10 panel (project complete frame up build) 1957 210 post pearl orange |
01-23-2013, 06:45 PM | #102 |
ok so i have a about 10 pictures to post, so i got the steering column done, and the master cyl installed, using capt. braket worked like a charm, i did have to extend the shaft but not a big deal, some of the pictures are of the sway bar, etc. ( hey no comments on how dirty it is ! still a work truck lol)
01-23-2013, 06:59 PM | #103 |
more of the column, and if you look close you can see how i extended the rod for the brake pedal,
01-23-2013, 07:05 PM | #104 |
and more.
01-23-2013, 09:07 PM | #105 |
Rollin' Old Skool
looks good....gotta get one of those booster brackets myself once my dad is ready to do the brakes
_____________________________________________ Phillip My Build threads: 1966 Chevy C-10 "Black Betty" shortbed, fleetside, BBW, 327 V8/ Powerglide (under construction) http://67-72chevytrucks.com/vboard/s...ighlight=betty 1997 Chevy Tahoe, 2dr/2wd, mild custom (Daily driver) http://67-72chevytrucks.com/vboard/s...d.php?t=601142 Pics: '66 C-10 https://flic.kr/s/aHsjHWD4h9 '97 Tahoe https://flic.kr/s/aHsjGZ7wKP '93 C-1500 https://flic.kr/s/aHskxdpdnQ '88 S-10 Blazer https://flic.kr/s/aHsjYGx4Md Previous Rides: 1993 Chevy S-10 ext. cab, 4.3L, 4/5 drop (Sold) 1993 Chevy C-1500 short/step Retro-Rod (Sold) 1988 S-10 Blazer 2dr/2wd mild custom (Sold) |
01-24-2013, 09:47 PM | #106 |
did not get much done today, i had to use another M/C , and i also mounted the prop. valve down off the frame i will try to run some more lines tomorrow.
01-25-2013, 02:45 AM | #107 |
60-66 Nut
What was the issue with the first master cylinder? That new one looks to have a fairly large bore.
01-25-2013, 08:17 AM | #108 |
the only real issue is the brake line for the front port, is a 9/16 - 18 thread and i can't find one in town i have been to NAPA and all the other auto parts chain, so i had one from a 03 silverado that had the lines and they are both 1/2 thread, oh i know i could find the correct ones off another S-10 that is parting out but i had this one. (i may still look and atleast that way i have a back up)
01-26-2013, 01:20 AM | #109 |
60-66 Nut
Aaaahhhh I see
01-26-2013, 10:58 AM | #110 |
i need a shop !! it's raining today , i cant do anything
02-01-2013, 07:37 PM | #111 |
well just an update, i now have power steering, power disk brakes, and an updated front end, all i need to do is bleed the brakes, and i can take it for a drive, but i can turn the wheel with one finger rather then a grunt.
02-02-2013, 12:55 AM | #112 |
60-66 Nut
That's awesome Henry
That nice drive makes all the work worth it, doesn't it?
02-02-2013, 11:29 AM | #113 |
it sure does, i love this hobby of ours ! I love to turn wrenches and hate to sit inside ! i bet most of us are like that i need to put some time in my 57 chevy i have another eng. for it and would like to get it swaped out before it gets hot around here i'm pulling the 283 and installing a 350 with the gear i have i just need some more grunt !
02-09-2013, 12:18 PM | #114 |
i was able to use the S-10 M/C after all, (FYI the brake lines of a 80 C-10 bolted to that M/C ) i'm now working on on the trans swap.
03-01-2013, 08:40 AM | #115 |
well the trans is in, the bowtie OD TV made easy worked like a charm, i still need to get the drive shaft cut, i also installed the A/C , i hope to have some spare money to finish up the little things so i can take it for another drive soon.
03-01-2013, 11:35 AM | #116 |
Rollin' Old Skool
Great to hear. You'll be driving that thing soon! Planning to get a 700R4 for my pickup once everything else is buttoned up. Like you, I'm also adding power steering & power disc brakes. I might not even want to drive my "modern" vehicle once the '66 is back on the road!
03-03-2013, 10:15 AM | #117 |
i am hoping that it drives great when it is complete, i would sure like to make this my daily driver.
03-03-2013, 05:04 PM | #118 |
A couple of Re 66 shields on the doors, and that will make that nice truck complete
03-03-2013, 05:22 PM | #119 |
Are you kidding only 2k no way. That is super cheap, good for you, very nice truck.
03-27-2013, 07:26 PM | #120 |
well after a few weeks off i have the drive shaft in and got the fluid in, and no leaks , so i just have to finish bleeding the brakes and i can again take this for a short drive, NEXT !! to change out the gears.
06-14-2013, 10:15 AM | #121 |
been busy , seems like i have not posted for awile, so here are some pictures.
06-14-2013, 10:53 AM | #122 |
more, i did get the 700 r4 in and then i started working on the A/C install, the next set will have the interior changes.
06-14-2013, 11:25 AM | #123 |
more of the inside.i did not mention that i also wired up a late model mirror with autodim, temp & compass there will be more of those pictures coming.
06-14-2013, 11:54 AM | #124 |
and yes some of my new dome light, etc. sorry for the bouncing around
06-14-2013, 12:05 PM | #125 |
more of the mirror and inside
