Old 12-01-2012, 09:51 PM   #101
hilljob26
hilljob26's Avatar
Re: rear disc brake templates and drawings
thank you
21 2500hd duramax
58 apache
HILLJOB GRAPHIX--for all your graphic needs
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=542497
LS ENGINE SWAP INFORMATION THREAD
http://67-72chevytrucks.com/vboard/s...d.php?t=377348
4l60 to an NP205
http://67-72chevytrucks.com/vboard/s...43#post3697343
hilljob26 is offline   Reply With Quote
Old 12-15-2012, 11:13 AM   #102
ihssalky
i was able to use these plans and a pair of 1977 deville rotors to make a 5 lug setup. My axle is a 5x5 pattern with a 3.062 center hub. The 6 lug rotor has a 3.100 center so it is loose and you have to still drill pattern. I spoke to hilljob about this. I guess some axles have a different center hub od. Really the only difference in the setup is that you have to turn down the OD of the axle to 6.190. the only other difference is that the rotor od is .500 smaller so the caliper mounting holes move down aprox .250 on the bracket.
ihssalky is offline   Reply With Quote
Old 12-15-2012, 04:11 PM   #103
Jdubs71
Jdubs71's Avatar
Looks good, did you use a plasma? So what your saying is with the six lug set up there is nothing needed, just bolt the plates and calipers and call it good?
71 K5, AC/Tilt, 4" lift 33" tires
5.3L/4L60E/NP 205 (Under Construction)
05 Dodge 2500 4x4 5.9 Cummins (Daily driver)
"Common sense is not so common"
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=555879
Jdubs71 is offline   Reply With Quote
Old 12-15-2012, 04:40 PM   #104
Bierkan
Bierkan's Avatar
The 5-lug axles are the ones that require drilling if you use the rotors mentioned in the plans. However, this DeVille brake rotor idea may save on drilling. Considering three of the holes look "thin" or intrude on an existing hole, I have found it tough to find a machine shop willing to take on the task. I think the shops around here won't have a problem trimming down the flange on an axle.
James "Bierkan" Vierkant
1950 3100 on a 1972 C10 Chassis
Truck Blog
Motorcycle Blog
Bierkan is offline   Reply With Quote
Old 12-15-2012, 06:42 PM   #105
hilljob26
hilljob26's Avatar
6 lug is basically a bolt on and go..i myself upgraded to 1/2 inch studs , but you dont have to
21 2500hd duramax
58 apache
My build thread
4l60 to an NP205
Old 12-15-2012, 06:45 PM   #106
hilljob26
hilljob26's Avatar
yes, it will help out alot,,although you can also use a grinder and grind around the flange to help out as well...i guess i didnt realize that people would rather a machine shop do all the work rather then just measuring it in there garage and save em some cash, but whatever works i guess
21 2500hd duramax
58 apache
My build thread
4l60 to an NP205
Old 12-15-2012, 10:58 PM   #107
ihssalky
We have a plasma burn table. Just put it into computer and burnt it out. The 6 lug would work perfect on that setup or a 5 lug with 3.100 center hub axle diameter. Both rotors are the same backspace so all spacers and brackets in plans work perfect. All it changes is placemrnt of two upper tapped holes. I was going to use 6 lug and drill to match, but my center hub is the same as caddy rotor at 3.062. I did not want .038 slop in center where it keeps it all centered up. Just all depends on what u have.
Old 12-15-2012, 11:25 PM   #108
ffk
ffk's Avatar
im going to salage yard monday...can u tell me what model & years calipers and rotors ill need..
my build thread -- (http://67-72chevytrucks.com/vboard/s...d.php?t=438604)
ffk is offline   Reply With Quote
Old 12-16-2012, 12:11 AM   #109
70blackfish
Any pictures of the 6 lug kit installed?
69 SWB 780hp Hellcat powered, manual 6 speed, currie 9
70blackfish is offline   Reply With Quote
Old 12-16-2012, 12:29 AM   #110
Dale99
Will these work behind 15" rims, or is up-sizing needed?
Dale99 is offline   Reply With Quote
Old 12-16-2012, 01:13 AM   #111
Bierkan
Bierkan's Avatar
If we're talking about 1/8" or greater, then I'd rather make sure it's even and balanced all the way around. Taking a grinder is fine if you plan on just driving to the local car shows or whatever. I plan on taking this truck on the highway and don't want any additional vibrations.
Truck Blog
Motorcycle Blog
Old 12-16-2012, 01:47 AM   #112
69RDMo
thats what i was wondering also
69RDMo is offline   Reply With Quote
Old 12-16-2012, 02:19 AM   #113
hilljob26
hilljob26's Avatar
the very first post has 6 lug pics
21 2500hd duramax
58 apache
My build thread
4l60 to an NP205
Old 12-16-2012, 02:20 AM   #114
hilljob26
hilljob26's Avatar
yes, i had 15x10's on my last 72 and they were just fine
21 2500hd duramax
58 apache
My build thread
4l60 to an NP205
Old 12-16-2012, 02:22 AM   #115
hilljob26
hilljob26's Avatar
i totally agree with you,, i was just getting at when i came up with this it was to have a rear disc set up for way cheaper then you could buy a complete kit for.however if its very minor, i would grind it personally, but that is just my personal opinion
21 2500hd duramax
58 apache
My build thread
4l60 to an NP205
Old 12-16-2012, 02:24 AM   #116
hilljob26
hilljob26's Avatar
all of that information is in the plans..should be in the upper right corner
21 2500hd duramax
58 apache
My build thread
4l60 to an NP205
Old 12-16-2012, 10:42 AM   #117
McKenna
I'd take a set of 6 bolts if available, let me know
McKenna is offline   Reply With Quote
Old 12-16-2012, 03:16 PM   #118
hilljob26
hilljob26's Avatar
pm sent
21 2500hd duramax
58 apache
My build thread
4l60 to an NP205
Old 12-21-2012, 10:41 PM   #119
Dale99
Got mine in today. Great drafting work coming from a draftsman
Old 12-22-2012, 01:08 AM   #120
hilljob26
hilljob26's Avatar
why thank you
21 2500hd duramax
58 apache
My build thread
4l60 to an NP205
Old 02-26-2013, 11:24 AM   #121
orange72blazer
orange72blazer's Avatar
Are these still available? I'll take a 6 lug set of templates if you still have some.
1972 Chevy Blazer
1997 GMC Sierra
2009 Chevy Tahoe
orange72blazer is offline   Reply With Quote
Old 02-26-2013, 01:20 PM   #122
ChevyCruizer
17's too small
ChevyCruizer's Avatar
I dont fully understand why the parts required are such a big secret in this thread. I understand and support the money for the plans, but I feel the parts list should be posted. As examples CaptFab has at least three dirrerent rear disc setups available. He lists everything and that helps people decide what do go with. As an example one of his sets use F body LT1 calipers and another one uses this thread style calipers. One of his use caprice rotors and I think another is a 4x4 front rotor. This information helps people decide what to go with because maybe they have some of the parts on hand.
Here are some specs on the 5 lug rotor that is pictured above link in post #102.
It is the rear brake rotor for:
Buick Estate Wagon 1977 - 1979
Buick Lesabre 1977 - 1979
Buick Riviera 1977 - 1978
Cadillac Coupe DeVille 1978 - 1979
Cadillac Deville 1977 - 1977
Cadillac Fleetwood 1977 - 1979
Cadillac Sedan DeVille 1978 - 1979
Cadillac Seville 1977 - 1979
Which if you want a parking brake then the rear caliper for this application should also work, but be careful most rebuilt calipers will not have the brackets needed to secure the parking brake cable nor the arm that actually moves the piton in and out.
68 C10 SWB SS 5 lug power disc brake conversion 2.5 inch drop spindles van tilt column Air Ride Technologies Cool Ride air bag kits Performance Online tubular upper control arms and shock relocator kits ECE super track panhard bar 1 piece side windows
ChevyCruizer is offline   Reply With Quote
Old 02-26-2013, 02:28 PM   #123
hilljob26
hilljob26's Avatar
they are not a secret, for those that have asked what parts they will need, i have told them..i hope this helps
21 2500hd duramax
58 apache
My build thread
4l60 to an NP205
Old 02-26-2013, 02:36 PM   #124
Dano69c10
Dano69c10's Avatar
Are these still available? Put me down for a six-lug set. I was wondering if you would also the include the five lug info free? Just in case I decide to go five-lug in the future
Dano
'69 Fleet
It ain't yours, if you didn't build it!
Dano69c10 is offline   Reply With Quote
Old 02-26-2013, 02:39 PM   #125
hilljob26
hilljob26's Avatar
yes, both 5 lug and 6 lug are included,,pm sent
21 2500hd duramax
58 apache
My build thread
4l60 to an NP205
