Old 12-26-2012, 12:50 AM   #101
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Re: Leadfoots build thread
Originally Posted by Leadfoot Lambert View Post
This is the hydraulic clutch setup I got from Captain fab. and the stock GM slave cylinder, Capt supplied a Wilwood Master cylinder for me also. With this setup the clutch feel is as light as a new car, Great for me as I have lower back problems. I still have to make a bracket for the hose.
I'm getting real close to settling on the NV3500.
A couple things I did notice; correct me if I'm wrong, but the NV3500 will fit under the low hump, correct?
But you decided to go with the high hump.
May I ask why?
66 C20 Service Truck:
Old 12-26-2012, 07:42 PM   #102
Leadfoot Lambert
Leadfoot Lambert's Avatar
It does fit under the low hump, but not by much, I had to tap down the seam where the firewall and toe board meet a bit but this may have been because my truck has a whole front frame clip from a 73-87 truck not just the cross member. I think the engine may sit a little higher than stock, The shift tower on the tranny stuck up thru the floor a couple inches also making the shifter look a little weird, Yours may fit no mods required. Then again maybe not. The reason I went with the high hump is because the floor in my truck was destroyed by the previous owner with an air hammer, the hump was split down the sides and beat down so a different seat would fit. hope this helps, I do have several pics of this thing installed if you need them.
65 Chevy short fleet 350 5 speed, soon to be LSX powered
65 F100 short fleet
91 Heritage softail
94 Fatboy
11 Softail Deluxe [wife's bike]
13 Streetglide
http://www.youtube.com/watch?v=yMFMw...eature=mh_lolz
Leadfoot Lambert is offline   Reply With Quote
Old 09-20-2016, 03:09 PM   #103
burlapen
burlapen's Avatar
I know this is an older build, but I really liked where it was going. I love the wheel and tire size on this setup. Are they the same size front and rear? Also do you know the backspacing? I only saw 18X9.5 or 18X8 listed on their sight. No 18X9's. Thanks.
63 Chevy C-10
My build thread
burlapen is offline   Reply With Quote
Old 09-21-2016, 08:56 PM   #104
Leadfoot Lambert
I think I went with the 18x8s all around, been about 5 years since I bought them.
65 F100 short fleet
91 Heritage softail
94 Fatboy
13 Streetglide
Old 09-21-2016, 09:06 PM   #105
Leadfoot Lambert
Going out to clean the garage Saturday, gonna make room to work and get back after this truck, it's been long enough!
65 F100 short fleet
91 Heritage softail
94 Fatboy
13 Streetglide
Old 09-26-2016, 08:12 PM   #106
burlapen
burlapen's Avatar
Good for you! I've been getting after it after a couple year hiatus too. Feels good to work on it again. Thanks for the info.
63 Chevy C-10
My build thread
