04-11-2013, 01:21 AM | #101 |
I'M TRUCK CRAZY!
Re: pics of lowered trucks with stock steel wheels and caps.
I like this thread. Mine. Not lowered. It was lowered in the front, but with heated springs. I had a set of stock springs to put on so the truck wouldn't lean. One day it will be low again. The fronts are 5 lug 15x7 and rears are 6 lug 15x8. Wish I had 2 5 lug 15x6 off a van. I have 2 5 lug 15x8 in my garage. I need another 71,72 rear axle so I can run all 5 luggers. I broke something in the old axle. Now the axle just sits in the backyard.
Posted via Mobile Device Posted via Mobile Device |
04-11-2013, 06:19 AM | #102 |
You know you can just swap the actual axles and the brakes drums and boom=5 lug! Just make sure you measure both when they are out. That's what I did.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
04-11-2013, 11:58 PM | #103 | |
I'M TRUCK CRAZY!
04-12-2013, 12:01 AM | #104 |
Are you going to put the rest of the Molding ?
1971 GMC Sierra 1959 GMC 100 |
04-12-2013, 08:27 AM | #105 |
I'M TRUCK CRAZY!
04-12-2013, 10:54 AM | #106 |
Oh alright, Had did it get Dented ?
04-12-2013, 01:34 PM | #107 |
Quick phone pic to add to this thread
66 GMC Suburban Custom 66 Chevy K10 Suburban |
04-12-2013, 03:37 PM | #108 |
Here is a 71 with 8 inch steel wheels that I had on for quite a few years and then I upgraded to the 18s.
04-13-2013, 05:44 PM | #109 |
what rim/tire size are you running southcity? looks good!
04-15-2013, 08:30 AM | #110 |
Blackline61 "what rim/tire size are you running southcity? looks good!"
I have 18x8 on the front with 255/55/18 Kumho I have 18x9.5 on the rear of the 275/55/18 Kumho They are Coys natural finish wheels |
04-15-2013, 12:46 PM | #111 |
Thanks Blackline61, here are the specs:
Front: stock steelies (15x6.5) 225/75/15 Rear: Wheel Vintiques (15X8) 255/70/15
05-04-2013, 12:20 AM | #112 |
What size are your rallyes?
Zach 1970 Chevrolet Custom Camper K20 1971 GMC Super K2500, 12V/NV4500 swap in progress 1971 Chevrolet Custom C10 1972 Chevrolet Custom Deluxe C20, 5.3/4L60E 1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi 2004 GMC Sierra 2500HD, LB7/Allison, CCSB 2005 GMC Sierra 1500, 5.3/4L60E, CCSB |
05-04-2013, 08:54 AM | #113 |
I had 15x8 rallys all the way around.
05-04-2013, 12:09 PM | #114 |
I'm thinking about running 255/70R15's on 15"x8" rallyes all the way around, but not sure if they'll fit with a 3 inch drop on the front
05-04-2013, 05:30 PM | #115 |
15/8 with 255/60 4/6 drop
05-04-2013, 06:41 PM | #116 |
Thanks Your truck looks very nice
05-05-2013, 11:32 AM | #117 |
I have toyed with the idea of lowering my truck. Haven't pulled the trigger yet. I really only want to even out the truck. The coil springs are all original with rear heavy duty springs. How many inches would I need in the rear to even it out? 2"or 3" ?
Stovebolt-It is painted |
05-05-2013, 04:11 PM | #118 |
EDIT: Just bought Rear 2" drop coils for my truck off craigslist for CHEAP with lowering shocks. Hopefully it evens it out. DOES it matter what end of the coils goes top to bottom? I see that they have numbers on one end of each coil spring. Also will my stock shocks be okay with the 2" drop?
Stovebolt-It is painted Last edited by 50bomb; 05-05-2013 at 04:19 PM. |
05-05-2013, 05:31 PM | #119 |
Thanks especially like my LS under the hood.
05-16-2013, 03:14 PM | #120 |
The chevy Tahoe's we work on here have 20", black, 8 oval steel wheels that run a chrome center hub cap. Unfortunately they are 6 lug and my 71 C10 has 5 lug. I really wanna see what this would look like on my truck.
05-16-2013, 03:44 PM | #121 |
05-20-2013, 10:48 PM | #122 |
Here is a pic of my 72. It had 20 inch Coy's on it till recently. Went back to 15 inch rallys. Looks better now
05-20-2013, 11:11 PM | #123 |
What's the drop and wheel & tire specs or there? Looking good.
05-20-2013, 11:25 PM | #124 |
Here is mine on steels. Think I am getting close to pulling the trigger on some Coys but really torn on the two looks.
05-20-2013, 11:28 PM | #125 |
not sure on the drop. front springs are heated and lowered, rear is a flip kit on leaf spring suspension. tires are 255 70 15 Vanderbilt Turbo Techs. Wheels are Wheel Vintique 15x8 with Chevy bow tie baby moons
