12-14-2013, 09:48 PM | #101 |
Re: 1974 SWB "Clifford" goes to Oklahoma
Made some progress today. Got the frame repair done on both sides and got the notches installed on the drivers side.
If you live in Oklahoma click this link |
12-18-2013, 10:33 PM | #102 |
Made a little more headway. I think I may have to jack the cab up 4" or so to get the front crossmember on. I wrestled with it for a good hour tonight by myself and couldn't get it to go. Just need a little more room to install it.
12-19-2013, 08:59 AM | #103 |
lookin good.
2014 LTZ Z71 Silverado 82 C15 LQ4/4L80E Conversion 78 Suburban build (SOLD) 83 4x4 Suburban(SOLD) 82 C15 (my first truck) |
12-21-2013, 04:14 PM | #104 |
Laid Back
Looking good..
72 chevy swb Direct dealers for.. Vintage Air, Porterbuilt, Billet Specialties,Budnik wheels ,eddie motorsports, raceline wheels, intro wheels, Dakota Digital, precision, unisteer, Trimparts, and many many more... Laid Back Recreations.. Full restoration shop and full paint and body.. Kyle http://67-72chevytrucks.com/vboard/s...d.php?t=574629 |
12-21-2013, 04:19 PM | #105 |
I/We like progress....
BTW.... I call Shotgun!
12-27-2013, 08:39 PM | #106 |
Got a little further today. Finally won the battle with the front crossmember. Had to unbolt the cab and jack it up in the back to get clearance. Got the axle set in and centered up where it goes. In my haste I forgot to cut off the old axle saddles and shock mounts. Hopefully I will be able to get that done without moving the axle too much. I will be able to mock the rest of it up next week maybe. This is the back pretty well as low as it will go. Only about 1/4" off the bump stops.
This is the front aired all the way out, sitting on the crossmember. It won't be able to sit this low however. I want to run stock inner fenders and my vintage air lines get into the tire anyway. Besides, the rear won't go that low anyway...
01-01-2014, 07:49 PM | #107 |
01-01-2014, 08:09 PM | #108 |
Making some good progress! I really like this kit for the square bodies.
01-26-2014, 05:03 PM | #109 |
GM Addicted
updates?? so with this kit the new saddles need to be welded in??
..Mac’s Garage.. 73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd My 73 GMC Truck Build Pic 2010 Silverado 4/6 on 24s IG:MacsGarage |
01-26-2014, 06:54 PM | #110 |
Yes, you have to weld new saddles onto the axle. Unless you pick up an earlier axle I suppose.
I actually went over to weld them on today but couldn't get comfortable enough on where the pinion angle needed to be set to weld them. I read too many conflicting opinions. I am going to call Porterbuilt for some advice tomorrow. I figure they do it all the time. With my truck at ride height the trans output shaft is at 4 deg down, I was thinking my rear pinion needed to be 2 deg up but just not sure enough to strike an arch.
01-26-2014, 07:13 PM | #111 |
67-72 parts collector,…
I've always thought if the trans was 4 degrees down,... the pinion needed to be 4 degrees up.
01-26-2014, 07:25 PM | #112 |
That was actually my first thought, but someone told me I should set it at 2 deg up so when you accelerate it will roll up the extra 1-2 deg. IDK, which is why I didn't pull the trigger.
01-26-2014, 07:44 PM | #113 |
I thought the rearend's pinion "rolling up" was more of a leaf spring thing.
I'll be following along to see what Porterbuilt suggests.
01-26-2014, 07:48 PM | #114 | |
I'll be using a 72 axle with mine so hopefully it will be correct as is...
Paul '78 GMC Serria 15 Heavy Half. 361/NV3500/3.73. Former LWB NV3500 swap Trailing arm swap '98 ECSB Z71 daily driver -traded '03 burb. Family cruiser http://upstategmtrucks.com/ |
01-26-2014, 09:25 PM | #115 |
Correct. 4-bar & truck arm set-ups don't move around nearly as much. Even stock power doesn't move it much on leafs.... it's the big HP/TQ drivetrains that can move things.
01-27-2014, 12:19 AM | #116 |
GM Addicted
interesting some an early 6 lug trailing arm rear end with some 5 lug conversion axles and you have a narrower rear end then the stock width wonder how much difference on each side it is compare to the 73 on up rear end
01-27-2014, 12:50 AM | #117 | |
71-87 = 63.5" 88-98 = 65" All lengths approximate. Also... truck arm pads are the same distance apart regardless of housing width.
01-27-2014, 12:57 AM | #118 |
GM Addicted
not bad gain a little clearance then, guess I wont be selling off the old rear end I have sitting around then ahaha.
01-27-2014, 04:26 PM | #119 |
OK, talked to Nathan a little bit ago and he lined me out. If my trans is pointing down @ 4 deg, I need to point my pinion up at 3 deg. He said you dont want it to be perfectly straight or the needle bearings in the u joints will no properly lubricate and wiil cause premature failure or the u joints. He said the 1 deg difference will accomplish that.
01-27-2014, 05:36 PM | #120 | |
02-25-2014, 11:27 AM | #121 | ||
I'm just glad to be here!
How is your truck coming along? Do you have it on the road yet?
Karl 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
03-09-2014, 08:04 PM | #122 |
Haven't got much done on the truck. I did get the axle saddles welded on. I only like drilling the holes to mount the front crossmember. Finally did get a shop of my own put up. Still have quite a bit to do. Electric, walls, and framing up the restroom but it is getting there.
03-10-2014, 07:42 AM | #123 |
nice shop!
1977 SWB C10 - "Woodson": 5.3 Vortec LS Swap, 4L60e Trans, 4.5/5 drop |
03-10-2014, 08:39 AM | #124 |
Nice... What size?
03-10-2014, 12:54 PM | #125 |
Great, like the truck envy wasn't enough. Nice place!
Boppa's Old Yeller Truck Build, Old Yeller's New Heart! Project Buzz Bomb Flyin' Low! |
