Old 03-12-2013, 06:24 AM   #101
48 GMC BURB
48 GMC BURB's Avatar
Re: 1951 Chevy / C4
So that's where those go !!
Very Kool Shannon !
48 GMC Burb
51 Chevy AD 3100/C 4 byShannon
74 Chevy P 10
48 Double Duty
04 SS Burb
01 Springer HD
48 GMC BURB is offline   Reply With Quote
Old 03-12-2013, 09:47 PM   #102
xpickup
xpickup's Avatar
Re: 1951 Chevy / C4
oldman3, 48 GMC BURB, Thank you.
It was a good night. Th coil overs are mounted. First cut my tubes to fit the frame and welded them in. Then fit the tabs and used a piece of box tube as my welding fixture. I only welded the gusset part of the tabs that way I could put the coil over in place to check for clearance. They turned out great. The frame sets 1 1/2 inches higher without weight on it. Next is to make the lower coil over mount that will tie into the factory shock mount so it supports the lower part of the mount. Here are some pictures.
Shannon
xpickup is offline   Reply With Quote
Old 03-12-2013, 11:21 PM   #103
oldman3
oldman3's Avatar
Re: 1951 Chevy / C4
Nice strong looking set up...Jim
oldman3 is offline   Reply With Quote
Old 03-13-2013, 07:26 AM   #104
48 GMC BURB
Re: 1951 Chevy / C4
Shannon
Your design is truly BAD ASS
48 GMC Burb
74 Chevy P 10
48 Double Duty
04 SS Burb
01 Springer HD
Old 03-13-2013, 09:31 AM   #105
99 to Life
99 to Life's Avatar
Re: 1951 Chevy / C4
handlin biz over there. you should quit your day job!!
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 03-13-2013, 11:29 AM   #106
98layinframe
98layinframe's Avatar
Re: 1951 Chevy / C4
Very nice work!
91 s10 - bagged bodydropped 4", 350/700R4, narrowed reared, cantilever rear air bag setup
1951 chevy 3100 - in build/acquiring parts process. Have full C4 Corvette suspension front and rear, tpi 350, 700r4, 18" torque thrust II wheels
98layinframe is offline   Reply With Quote
Old 03-13-2013, 01:05 PM   #107
focusedontheprize
focusedontheprize's Avatar
Re: 1951 Chevy / C4
Beautiful work Shannon.
focusedontheprize is offline   Reply With Quote
Old 03-14-2013, 03:40 PM   #108
xpickup
xpickup's Avatar
Re: 1951 Chevy / C4
oldman3, Thank you. I am very pleased with it.
48 GMC BURB, Thank you. I am glad you like it seeing how it is your sons. Your frame will be the same except I think I can lower the rear bridge section a little with the same size tire all the way around.
99 to Life, Yes, I have been busy with it. Sometime I will turn this into my day job I hope!
98layinframe, Thank you. When are you going to start on yours? You know when you do and you need any info just give me a shout. I will be glad to help.
focusedontheprize, Thank you.
Today I ordered some parts. I set of suicide door hinges and some latches. Also I am going to put a set of 56 car headlight brows on this one too. So I ordered 2 patch panels and the headlight bezels. The engine is coming up the weekend of April 13, so I am going back to some sheet metal after I prime the frame.
Shannon
Old 03-14-2013, 04:31 PM   #109
oldman3
oldman3's Avatar
Re: 1951 Chevy / C4
New parts and list sounds interesting, can't wait for the work and pics to start flowing...Jim
Old 03-14-2013, 10:17 PM   #110
69CST-V
69CST-V's Avatar
Re: 1951 Chevy / C4
Hey X. I have a question. How are you compensating for the deflection your plate may have where the lower coil over mount is? I might be missing something but it looks like it is below the lowest fixed mounting point which means it becomes a lever. So as the suspension compresses the forceon the plate is also in torsion and could bend the bracket. Just what I'm seeing I might have missed something. Nice work I'm a big fan as I look at your threads religiously.
Bryce
'69 SWB Fleet Still Under Construction
Company Trucks
69CST-V is offline   Reply With Quote
Old 03-15-2013, 07:44 AM   #111
xpickup
xpickup's Avatar
Re: 1951 Chevy / C4
oldman3, Yes I love when new parts come. It has been a while since I suicided a set of doors. The brows are a neat subtle change for the head lights.
69CST-V, Thank you. Yes, there is a bracket that I did not make yet that mounts to the factory shock mount. The lower coil over mount is then bolted at 3 places, the 2 four bar mounts and the old shock mount. Then then should not be any deflection. Also I am going to trim about an inch off the bottom of the plate just to clean up the length a little.
Shannon
Old 03-16-2013, 12:10 AM   #112
48 GMC BURB
Re: 1951 Chevy / C4
Shannon
Now I've got to buff the rear & design some kind of gull-wing or lift up bed just to show off your mad skills !!!
48 GMC Burb
74 Chevy P 10
48 Double Duty
04 SS Burb
01 Springer HD
Old 03-16-2013, 05:41 AM   #113
xpickup
xpickup's Avatar
Re: 1951 Chevy / C4
ken, I can hinge the bed floor up no problem. The floor will have to be raised a little anyway.
Shannon
Old 03-16-2013, 01:52 PM   #114
98layinframe
Re: 1951 Chevy / C4
Shannon
Hopefully sooner the better... but unfortunately Im forcing myself to finish my bodydropped first gen s10 before I switch over to working on the 1951.
Old 03-17-2013, 08:26 PM   #115
xpickup
xpickup's Avatar
Re: 1951 Chevy / C4
98layinframe, Thats cool. At least you can collect parts while you are not working on it.
Today I made the lower coil over brackets support that mounts to the factory shock mount. Took a piece of 2" box tube and cut it to size and then welded a 5/8 nut to it. Then tacked it in place. I will make caps for the ends also. I will finish welding it when I pull everything apart to prime it. Next was to saw and drill the fuel and brake line mounts, they a 1"diameter slugs with a 1/4-28 hole for a button head bolt to hold the rubber covered clamps. Then I boxed out the frame mounted 4 bar brackets and ground them all up. It gave them more of a finished look. Then I coped some tubing for the lower part of the tranmission cross member and I had seen that the upper one that goes across the frame was going to hit the drive shaft. So I bent up a curved one. So now I can cut out that one now. I am going the order SST braided brake hoses so I can mount the tabs and spray primer on it soon.
Shannon
Old 03-17-2013, 08:27 PM   #116
xpickup
xpickup's Avatar
Re: 1951 Chevy / C4
some more
Shannon
Old 03-17-2013, 10:17 PM   #117
Chevette
Chevette's Avatar
Re: 1951 Chevy / C4
Looks real good, Shannon.
56 Chevy PU
http://67-72chevytrucks.com/vboard/s...d.php?t=531955
Question: Know how to sell your truck for $50,000?
Answer: Spend $100,000 building it.
Chevette is offline   Reply With Quote
Old 03-18-2013, 06:18 AM   #118
48 GMC BURB
Re: 1951 Chevy / C4
Shannon
the frame looks so Bad Ass ...
It is so much fun watching your process...
Being a Construction Project Manager to eat, I usually point things out constantly !!
but with watching you I just sit back in awe
If I see something , I just wait a week and you address it. It's so kool !!
I can't whate to get my hands on it !!
Pointless to say but keep it up !
Ken
48 GMC Burb
74 Chevy P 10
48 Double Duty
04 SS Burb
01 Springer HD
Old 03-18-2013, 08:22 AM   #119
48 GMC BURB
Re: 1951 Chevy / C4
Shannon
PM sent
48 GMC Burb
74 Chevy P 10
48 Double Duty
04 SS Burb
01 Springer HD
Old 03-24-2013, 07:11 PM   #120
xpickup
xpickup's Avatar
Re: 1951 Chevy / C4
Chevette, Thank you. I am still waiting to see your build thread back on here again. I am going through withdrawal!
48 GMC BURB, Thank you. I am glad you like it. I too sometimes do things one way and then add to it because I think it would be better another way. Yes I can not wait to have your son and you come set the motor in it.
It was one of those weeks. Two of my kids had small surguries and the gas drier died. But the brown truck came for a visit. The 56 eye brows and headlight rims came and a bunch of brake things came. The rocky hinges and latches are on there way. So I have been running the brake lines. I ordered a new blue piont(snap on) flare kit so it should be here early in the week. I bent up everything that I could, and only have to flare 5 ends. The back still needs the t put in and attach it to the long line. The front is all bent up and both ends need flared to go into the propotioning valve. They need trimmed back a little so they look nice. The frame is all tore apart so I can finish welding and grind the under side. I have to weld a 3/4 inch flat bar around the bat wing mount to strenghten it up a little. It would be alright but I like to over due things. It is back on the saw horses. Thursday I took off work so I will sling the epoxy on then. Then put it back together and start on the headlight brows and the doors till the motor comes.
Shannon
Old 03-24-2013, 07:13 PM   #121
xpickup
xpickup's Avatar
Re: 1951 Chevy / C4
some more
Shannon
Old 03-24-2013, 07:43 PM   #122
oldman3
oldman3's Avatar
Re: 1951 Chevy / C4
Lines are looking great, along with everything else...Jim
Old 03-24-2013, 07:53 PM   #123
swizzlestick
Re: 1951 Chevy / C4
xpickup- are those the same eye brows you put on the other pickup you built? you said they were off a 56 is that for a car or truck? where did you get them from? thanks
swizzlestick is offline   Reply With Quote
Old 03-24-2013, 08:18 PM   #124
xpickup
xpickup's Avatar
Re: 1951 Chevy / C4
oldman3, Thank you. I can not wait to get them flared, then that is off the list.
swizzlestick, Yep that is the same ones. They are 56 car headlight brow repair panels. You use your factory headlight buckets and you also need the chrome trim ring for the 56 car. You can check out that build for how I did it or if you need any pointers I will be glad to help. The cheapest I found was from Danchuk. Thank you Kabwe for the 56 car vender info.
Shannon
Old 03-24-2013, 09:32 PM   #125
swizzlestick
Re: 1951 Chevy / C4
thanks for the info! I've watched and been impressed with all the builds in your signature. how did you get the brows pointed straight? did you just let the original headlight opening guide you?
