Old 10-09-2015, 01:47 AM   #101
geardrvn
Re: 49/54 LS driver
Looking good! Is the thermostat you are using for an older sbc? Or ls specific? I noticed that the look very similar but the cost is like x5 for an ls one.. Thanks!
"50 GMC 5.3l Vortec/bagged"
http://67-72chevytrucks.com/vboard/s...d.php?t=683537
geardrvn is offline   Reply With Quote
Old 10-09-2015, 07:26 AM   #102
chev3600
chev3600's Avatar
Re: 49/54 LS driver
The thermostat housing is an older sbc swivel type. Bolt spacing is different, so I had to slot the holes a little.
1949/1954 with LS swap-yeah!
http://s260.photobucket.com/albums/i...0/AD%20trucks/jumbled mess of unorganized photos
chev3600 is offline   Reply With Quote
Old 10-09-2015, 07:28 AM   #103
chev3600
chev3600's Avatar
Re: 49/54 LS driver
Tlorber- is the seat question for iwanna49? You may want to check out his build thread. http://67-72chevytrucks.com/vboard/s...d.php?t=641511
Old 10-09-2015, 12:06 PM   #104
tlorber
tlorber's Avatar
Re: 49/54 LS driver
Thanks for the link. I am subscribed to his thread but I guess he has not yet mounted the seats. I saw how you had done it. I'd like to come up with a way to make the seats adjustable-even better would be to have the driver's side move independent from the passenger's side. That would allow my wife to drive it.
tlorber is offline   Reply With Quote
Old 10-13-2015, 12:37 AM   #105
Hawkerdriver
Hawkerdriver's Avatar
Re: 49/54 LS driver
Following...... Looks great
Hawkerdriver is offline   Reply With Quote
Old 09-16-2016, 10:21 PM   #106
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Re: 49/54 LS driver
How about some updates Matt?
--Josh
Old 09-17-2016, 07:26 AM   #107
chev3600
chev3600's Avatar
Re: 49/54 LS driver
Wow. Haven't updated at all in 2016. Well, I pulled the 5.3 to reseal it and decided that would be a good time to build a 6.0 instead. And while its out paint the front subframe, and fix/paint the firewall. Replacing the vintage air with a newer version. The engine build took way longer than expected and still isn't done. Machine shop woes and a broken block will slow you down. Here's a couple pics for a minute anyway.
Old 09-17-2016, 07:29 AM   #108
chev3600
chev3600's Avatar
Re: 49/54 LS driver
Josh- I'm sure your new old truck will be rolling long before mine, so drive it on down and show it off.
Old 09-17-2016, 03:43 PM   #109
STOCKISH
STOCKISH's Avatar
Re: 49/54 LS driver
Great work man, looks killer. New old truck should be here tonight or tomorrow morning. Feel free to come check it out.
--Josh
Old 09-19-2016, 01:00 PM   #110
tlorber
tlorber's Avatar
Re: 49/54 LS driver
Matt,
I saw that you plan on replacing the vintage air with something else. Do you know what you will use yet?
Old 09-19-2016, 01:17 PM   #111
chev3600
chev3600's Avatar
Re: 49/54 LS driver
I'm using a newer version vintage air. The one that I installed originally was canibalized from a 69 c-10. It was cable and vacuum operated and never seemed right. I don't have the funds for a fully digital setup, so I got the gen 2 with servo motors and electric slide controls.
Old 09-19-2016, 01:47 PM   #112
tlorber
tlorber's Avatar
Re: 49/54 LS driver
Great. Thanks.
Old 09-19-2016, 09:25 PM   #113
lower50's
lower50's's Avatar
Re: 49/54 LS driver
Wow nice looking motor.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 10-16-2016, 11:17 PM   #114
Robert Andrew
Re: 49/54 LS driver
Originally Posted by chev3600 View Post
This build was as much for my enjoyment as my two boys. The wife doesn't seem interested, but puts up with us. With the kids in mind, safety was key. I added three point seat belts from a 99 dakota and a second row seat from a durango. Very comfy and nice fit.
As long as we're inside the truck, I put autometer quad gauges into the factory gauge buckets and installed a new wiring harness.
Ive found the majority of a vintage air A/c and heater and am trying to get that assembled here soon. I attempted power windows but the motors were junk and couldnt lift the glass. So the manual stuff is fine for me. I did install a set of bear claw latches and AVS shaved handle kit. I am leaving the outer door handles because I like the look, but they are currently non functional.
Ive almost finished the windshield wiper setup using a surplus boat wiper motor found online (Thanks mknittle)
The seat looks good. I bought one today, after seeing yours. How did you mount the Durango seats, and did you install adjusters.
Robert Andrew is offline   Reply With Quote
Old 10-16-2016, 11:19 PM   #115
Robert Andrew
Re: 49/54 LS driver
How did you mount the seat? Did you use adjusters If so, what adjusters did you use?
Thanks,
Old 10-17-2016, 07:24 AM   #116
chev3600
chev3600's Avatar
Re: 49/54 LS driver
I made a frame for it to sit on. It may work the same with the factory floor frame if you include some more cross supports and center seat supports. I'm tall and the cabs on these trucks are pretty small so I didn't see any need for adjustment. It's mounted as far back as I could get it.
Old 11-18-2016, 08:07 AM   #117
BC Toy chest
BC Toy chest's Avatar
Re: 49/54 LS driver
Nice build, keep the photos coming.
I'm not tail-gating, I'm drafting.
http://67-72chevytrucks.com/vboard/s...d.php?t=432758
BC Toy chest is offline   Reply With Quote
Old 11-18-2016, 10:18 AM   #118
Robert Andrew
Re: 49/54 LS driver
Thanks for the pics, Chevy3600. I'm tall too, which is why I sold my 41 Ford pickup. My wife and grand kids will probably want to drive my pickup from time to time, so I'll figure out a way to add some adjustment. Your truck is coming along very nicely. I hope to have mine running Thanksgiving weekend.
Old 11-18-2016, 01:16 PM   #119
chev3600
chev3600's Avatar
Re: 49/54 LS driver
Hope you get yours going. I just got mine running again (running correctly . It's a real motivator to move forward.
Old 11-18-2016, 02:57 PM   #120
STOCKISH
STOCKISH's Avatar
Re: 49/54 LS driver
I need to get out there and check out your progress Matt. Looks great.
--Josh
Old 12-05-2019, 10:21 AM   #121
STOCKISH
STOCKISH's Avatar
Re: 49/54 LS driver
Hey Matt, how's this thing going brother!?!?!
--Josh
Old 12-09-2020, 12:38 AM   #122
shiny
shiny's Avatar
Re: 49/54 LS driver
What a great informative thread! Thanks Matt!
Lots of great info and ideas!
What S10 driveshaft did you use?
I may use a 90s Blazer diff, factory posi and disc brakes, just cuz we have one. Ford 8.8s are good too eh.
Did you go with 2nd Gen Camaro / LS engine mounts?
And what headers did you go with?
Did anyone figure out an adjustable setup for the Durango 2nd row seat?
Cheers!
-Shiny
Bags are for groceries....
shiny is offline   Reply With Quote
