Old 07-01-2014, 02:07 PM   #101
BigMike
BigMike's Avatar
Re: Taking the leap to build
I like the wheels, who makes them?
BigMike is offline   Reply With Quote
Old 07-01-2014, 05:01 PM   #102
jlaird
jlaird's Avatar
Originally Posted by TazmanB View Post
Look what came in. It looks awesome. Getting several parts in to start building the frame and make sure everything fits right.
What are your plans for the fuel filler?
jlaird is offline   Reply With Quote
Old 07-01-2014, 09:17 PM   #103
TazmanB
TazmanB's Avatar
Thanks BigMike, they are Detroit Steel Wheels (Mobsteel).
Josh I am going to make a fuel fill door in the bed floor.
If you ask the question. Make sure you are ready for the answer.
69 C-10 Longbed (In Progress) Build thread http://67-72chevytrucks.com/vboard/s...d.php?t=568171
TazmanB is offline   Reply With Quote
Old 08-10-2014, 11:09 PM   #104
TazmanB
TazmanB's Avatar
Well had a productive day. The frame was cut and welded up and got the front and rear cross members in. Started lining up the cab to get it squared up so the cab mounts and core support mounts can be made and welded on. Was a long day but happy with the progress that was made today.
Old 08-10-2014, 11:11 PM   #105
TazmanB
TazmanB's Avatar
Couple more pics.
Old 08-11-2014, 06:52 AM   #106
BigDaddyV
BigDaddyV's Avatar
Very nice Progress! Keep up the Great work!
J. Vess, 6'6", Gearhead, Welder, Fabricator, Nutcase
1955 Chevy Stepside "Dudley"
My daily http://www.67-72chevytrucks.com/vboa...d.php?t=760288
1972 Chevy C10, Project "Chevro~Layed out" Nether Storm
Build Thread http://67-72chevytrucks.com/vboard/s...23#post6007523
BigDaddyV is offline   Reply With Quote
Old 08-11-2014, 11:48 AM   #107
TazmanB
TazmanB's Avatar
Thanks. Yours is looking good too. Trying to have the frame finished so it can be taken to Slamily this weekend.
Old 08-11-2014, 12:55 PM   #108
BigDaddyV
BigDaddyV's Avatar
I wish I could join y'all there! Praying that next year I can
Old 08-17-2014, 04:37 PM   #109
TazmanB
TazmanB's Avatar
Well I wasn't able to make the Slamily Reunion so I decided I go ahead and do some work on the truck. Got the cab squared up on the new frame and put the wheels/tires on so I could get my measurements to narrow the rear end. Got all the rod ends made up for the 4 link, then moved to the front end. The core support mounts fabed up and welded on. I think its looking good.
Now the front sheet metal will come off so the control arms can be made, fitted and welded on. Going to try to have the front suspension completed in the next week. I decided to go with the Dominator 2600 bags all the way around. Still trying to decide how to do the rear.
Old 08-20-2014, 06:48 PM   #110
mooseknuckles
mooseknuckles's Avatar
wow that's a lot of rubber!
mooseknuckles is offline   Reply With Quote
Old 08-20-2014, 09:36 PM   #111
TazmanB
TazmanB's Avatar
Hahaha Yes it is. Now to tuck it all inside the wheel wells. Im starting to get excited and cant wait to finish it.
Old 11-02-2014, 12:35 AM   #112
TazmanB
TazmanB's Avatar
Well It has been a while since I got some real work done on the truck. I still haven't figured out what to name her yet. Anyway I blew the bed apart Tuesday and started measuring everything to raise the bed floor and section the inner bedsides. Then shortened the rearend to tuck all that rubber up under the truck.
Old 11-02-2014, 12:43 AM   #113
TazmanB
TazmanB's Avatar
Wednesday the inner bedsides were tacked together and the floor was cut to widen the wheel tubs. The bed was put back together and put on the frame to check the fitment. I think it came out pretty good just some minor adjustments but nothing major.
Old 11-02-2014, 01:02 AM   #114
TazmanB
TazmanB's Avatar
Thursday all the sheetmetal was put back on the frame to start making all the body mounts. this was an all day ordeal because between me and my buddy Art we could decide what would look best as to how to set the body. The suspension is going to be set so that the rear of the frame will be 1 1/2 inch off the ground when air out and the front will be 3/4 of an inch off the ground. Since the front fender cup actually sits above the bottom of the frame we decided to wedge the body on the frame. The core support was lowered 1 inch to put the front fender cup lower to the ground and raised the rear of the bed 1 inch. We will also put in some adjustable bumpstops so that the final aired out stance can be adjusted to get the perfect rake.
Old 11-02-2014, 01:18 AM   #115
TazmanB
TazmanB's Avatar
Yesterday and today was spent making all the body mounts and rear suspension. There was a lot of plasma cutting and welding going on. After 2 days of fab work, grinding and welding all the body mounts were made and installed along with most of the rear 4 link and cross members. Still need to make the upper link bars and bag mounts but I'm tired and need a little family time.
I'm not sure about putting a sway bar or a Z link on the rear but I mocked up a sway bar to see how I could mount it and what it would look like. What do you guys think, sway bar or Z link?
Old 11-02-2014, 01:27 AM   #116
TazmanB
TazmanB's Avatar
Oh and I forgot about getting the Porterbuilt hood hinges installed.
Sorry about the multiple posts back to back but had a couple of busy days of thrashing on the truck to get yall caught up on.
Old 12-11-2014, 06:07 PM   #117
thumpros@yahoo.com
thumpros@yahoo.com's Avatar
Exclamation Re: Taking the leap to build
Nice truck. You mentioned a spare frame and suspension you were interested in parting ways with? That one has rear drum brakes,correct ? Do You have any pictures available to post? This picture was taken after body media blast in Grand Prairie
Possibly very interested in seeing your frame assembly.
Rodney
thumpros@yahoo.com is offline   Reply With Quote
Old 12-11-2014, 06:28 PM   #118
TazmanB
TazmanB's Avatar
Rodney I don't have any pics of just the frame. I will try to get some this weekend
Old 12-11-2014, 07:51 PM   #119
mooseknuckles
nice work!
Old 12-12-2014, 09:06 AM   #120
TazmanB
TazmanB's Avatar
nice work!
Thanks man
Old 12-12-2014, 12:35 PM   #121
gringoloco
A guy with a truck
gringoloco's Avatar
Wow! Started reading what I thought was a basic re-fresh--really took a turn. Nice work so far and the wheels are sick! Keep it up
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 12-12-2014, 01:02 PM   #122
TazmanB
TazmanB's Avatar
Yes Sir..it started out as a basic re-fresh and took a hard right turn to full blow custom build. Thanks for the nice words
Old 12-12-2014, 02:08 PM   #123
VDOG
Grand PooBaa Member
VDOG's Avatar
These rims and tires are massive, what size are they?
VDOG is offline   Reply With Quote
Old 12-12-2014, 04:06 PM   #124
TazmanB
TazmanB's Avatar
They are 29x18.00x20's mounted on 20x14 mobsteel wheels.
