Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > Heavy Haulers
Old 11-13-2013, 08:57 PM   #101
atvpro
atvpro's Avatar
Re: C50 Pick-up Drill Sergeant
I like the look of the hubcap and beauty ring combo with the black wheel. Pretty sure this is what I am going to go with.
The piece underneath everything is what I started with. The parts on top are what I cut them down to.
The next three are the process of installing the curve at the bottom with a body line.
This is what it looks like with the flare on.
Went to Pull-n-Save and picked up a Suburban gas tank, unforunately they like to drill holes into them. I am not going to complain though, with the sending unit it came to a grand total of just under $10.00. For that price I do not have a problem welding them up.
Just in case
Welded but will still be JB welded to insure an absolute seal. The tank will be painted with black zero rust.
Tank in the truck.
atvpro is offline   Reply With Quote
Old 11-13-2013, 11:58 PM   #102
phaus01
phaus01's Avatar
The truck looks really good. Love the color you picked out. What is the choice of front bumper that will be used?
phaus01 is offline   Reply With Quote
Old 11-14-2013, 02:29 PM   #103
Mater/10
Mater/10's Avatar
That is Awesome! i love the look of the wheels with caps and rings!
1964 Chevorlet Custom 10 350/350 ,ps,mb,A/c,BBW -Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=608625
1969 Chevy Nova 2 dr I6 250/powerglide
1967,68,69,70,71,72 Chevy Frankenstein
Mater/10 is offline   Reply With Quote
Old 11-14-2013, 09:13 PM   #104
l79m20
I feel like if you added a running board to connect the front and rear fender flares that it would look awesome. Just my own opinion...
l79m20 is offline   Reply With Quote
Old 11-16-2013, 12:15 AM   #105
bojak
bojak's Avatar
Flare looks great. The black steelies are the way to go. I would suggest black wheels with rings and chrome lug nuts. Like the style on older power wagons and 50's style GMs. I think the style of sarge is overland/classic. Like your version of a GM power wagon. Rings and center caps looks good but not as in keeping with the style thus far. Just my opinion, and it would probably look good with anything except 20" rock stars. Sarge would probably make those look good too.
bojak is offline   Reply With Quote
Old 11-16-2013, 12:19 AM   #106
bojak
bojak's Avatar
Old 11-20-2013, 02:43 AM   #107
NewType72
NewType72's Avatar
Man that flare has been wracking my brain too guess well need a video of how it all works when she's all painted up. I plan on being at next years hot August nights in Reno as well so hopefully I'll see ya there.
Project NewType 1972 Chevy C/10 Cheyenne Super ( Daily Driven Showtruck ) http://67-72chevytrucks.com/vboard/s...d.php?t=507903
Project Great Grandpa's Legacy 1973 Chevy C/10 Cheyenne ( Current daily driver collecting big time parts ) http://67-72chevytrucks.com/vboard/s...89#post7084289
- Dylan
(209)-985-7721
NewType72 is offline   Reply With Quote
Old 11-23-2013, 01:58 PM   #108
lowrollin70gmc
Too many projects
lowrollin70gmc's Avatar
This is an awesome project, very thought out and executed nicely. I've kept an eye out for a retired grain truck to tinker with, but something has to be said that you're actually doing it.
As for your wheel problems, have you considered putting dually axles under it? The rear would get you extra width to fill the flare with a regular wheel on it and the front would widen out as well. Just a thought, or I run a 2005 AAM 14 Bolt that's wider than the stock 70s/ 80s 14 bolts at 69 1/2" WMS and has factory discs and parking brake.
I look forward to the updates and finished product.
Andrew
84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck"
70 GMC C1500 LWB My first truck: shaved, bagged, and more: the lowrollin70gmc
68 K20 Suburban 12V Cummins/NV5600/NP205/D60/11.5AAM 3.73s "Dakota Cadillac"
63 Chevy II Nova Coupe 250 I6/T56/4.56s "Economy car"
53 Willys Wagon 350/NV4500/BW4401/HP D44/9inch “Winter Wagon”
30 Model A 16 Focus ST
lowrollin70gmc is offline   Reply With Quote
Old 11-24-2013, 03:01 PM   #109
atvpro
atvpro's Avatar
Originally Posted by bojak View Post
Hey Bojak, those are pretty damn cool tires. I think I will try to get more information on my application size. The tires I have on Drill Sergeant are probably going to have to stay but those tires on that Dodge look like the ones I need to put on my C50 Crew Cab project coming up after Drill Sergeant.
BTW, your killing me man, how was the biscuit?
Old 11-24-2013, 03:11 PM   #110
atvpro
atvpro's Avatar
It's funny you should mention that on the very morning I woke up at 3:00 am thinking about it. My intention was after I got up, and it was light outside, I was going to go measure axle widths, keeping in mind I am not planning on going away from an Eaton, one of my most favorite axles. I guess you could say it's in the same league as a 205 transfer case. So this is what I came up with; I am going to have to stick with the 2wd 411 possi I have in it. The only other option that I could think of, is to bolt on one ton dually hubs which seem to be quite a bit wider, just not sure I would do with the axle shafts. With all that said, camper special wheels in the front and custom camper special wheels in the back to end up with a even stance front to back.
Thank you for your comments, your compliments are appreciate it and respected.
Old 11-25-2013, 08:08 PM   #111
atvpro
atvpro's Avatar
Well showing the process of installing the jerry can recess/shadow box on the passenger side now. It went a lot quicker this time do to the fact I made the box on the bench and not piece by piece on the bed.
I finally figured out what I am going to do with the wheels. I talked to a guy here in Spokane, that is set up better to do the work than I am. What I am going to do, is use the camper special wheels in the front and on the back I am going to widen the camper special wheels by 3" each giving me 6'' overall. I think it will be harder for somebody to tell by looking at them that they are different front and rear but regardless, this is the way I got to do it.
Old 11-25-2013, 08:15 PM   #112
atvpro
atvpro's Avatar
Sorry I forgot to reply to your question earlier to answer it what I am considering is making running boards that go from flare to flare that are completely independent from the body. They will be mounted to the frame and have a very slight gap between the body and the running boards, enough to clear any frame to body flex but they will still maintain the body style of the original running boards of a C50. One of the major differences, they will only be 2 to 3 inches tall overall rather than the stock C50 running boards which I believe are at least 12" tall.
The only other thing I can say about the running boards I will be building, they will be able to sustain I pretty good side impact, ie they won't be just sheet metal.
Please keep in mind everything I am doing on this project is the precusor to the C50 Crew Cab that is next in line.
Old 11-25-2013, 08:44 PM   #113
duallyjams
duallyjams's Avatar
This is going to be so cool when it's done.
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 11-25-2013, 09:26 PM   #114
bojak
bojak's Avatar
Running boards. It's a GM power wagon! That's awesome. You make recessing fuel cans look easy, but I know it's not.
About the wheels, so are you actually going to have a really wide rear wheel tire combo or is it just changing the offset ?
Your truck is killer. You should be proud.
You ever check out icon 4x4's website? If not, check it out. Good place to get some ideas from. Good use of products but retaining original styling. Interesting projects including a sick dodge crew. Go to there derilects section.
Old 11-25-2013, 09:48 PM   #115
NewType72
NewType72's Avatar
Okay so it's probably already been mentioned but what is the purpose for the fuel cans? Obviously it would be a pain to get up in the bed everytime so you mounted them on the exterior but what will you be doin that will require fuel cans on the side permanently?
- Dylan
(209)-985-7721
Old 11-25-2013, 11:18 PM   #116
atvpro
atvpro's Avatar
the same reason that I'm building a C/50 pickup truck. because I can.
Old 12-16-2013, 10:08 PM   #117
bojak
bojak's Avatar
Yo. How's the sarge?
Old 12-17-2013, 12:38 AM   #118
rustSpot
*NO REGRETS*
rustSpot's Avatar
One of my favorite builds! Super cool! Nice work as well!
rustSpot is offline   Reply With Quote
Old 12-17-2013, 12:46 AM   #119
Zoomin
Man of Mini-Talents
Zoomin's Avatar
Gotta love that!
It's really cool to watch you take your ideas and some old metal to make something uniquely yours.
Well done sir.
Zoomin is offline   Reply With Quote
Old 01-01-2014, 11:37 PM   #120
bojak
bojak's Avatar
Bump.
Old 01-02-2014, 02:51 PM   #121
atvpro
atvpro's Avatar
In keeping a very important body line clean, I came up with a sanding block made out of bondo the exact shape of the lower part of the grill on Drill Sergeant. I used it last night, and it worked flawlessly.
First I put tape down, and then basically made forms and poured in the bondo and waited for it to dry. Oh by the way, this much bondo and thickness gets really frickin hot.
Old 01-02-2014, 05:18 PM   #122
mcbassin
Still Learning
mcbassin's Avatar
Awesome work as always. Love the filler sanding block idea..
mcbassin is offline   Reply With Quote
Old 01-02-2014, 07:26 PM   #123
Z16
That sanding block is an awesome idea!
98 GMC Sierra Ex Cab, cowl hood, Euro LED lights, 30 bar billet, Whipple Supercharged 350 Vortec: Forged flattops, E-Tec aluminum heads, Comp Cam, Scat crank and rods, Granatelli Mass air flow, Headers, Flowmaster exhaust , Complete MSD Ignition, Custom Tuning, intake spacer , ported throttle body, AC Delco port injection upgrade, Roller Rockers, Power Pulleys. Gear Vendors Overdrive. Soon to hit a dyno. 2/4 drop(for now).
95 Chevy S-10 Ex Cab 4.3 5 Speed 2/3 drop, Euro lights, billet grill, More to come. The Daily Driver
Z16 is offline   Reply With Quote
Old 01-05-2014, 12:44 PM   #124
AMERICAN PICK-UP
Lookin good!
AMERICAN PICK-UP is offline   Reply With Quote
Old 01-05-2014, 01:14 PM   #125
BMERDOC
BMERDOC's Avatar
Absolutely killer work! I've been eyeballin' some of the local Big Trucks on CL but am not really sure what I would do with one. Your work is inspiring! I'll be watchin from now on.
Nick Carter
1967 C10 Short bed Fleetside
Project Cheap Thrills!
2WD C10 Modern/Performance Alignments
Easiest Alignment Ever!
BMERDOC is offline   Reply With Quote
