07-18-2015, 09:09 AM | #101 |
Re: power window regulators on the cheap
Subscribed
Posted via Mobile Device |
07-31-2016, 05:52 PM | #102 |
here is a pdf of the plate that another reader has come up with that has more measurements
09-09-2016, 05:34 PM | #103 |
Anybody have issues with the glass binding after install? I am having trouble with both sides binding up. I do have all new weatherstripping, but I lubed them up and it still binds. I also lubed the rollers. Any suggestions would be appreciated.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Power windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
09-09-2016, 05:56 PM | #104 |
Are the window glass channels adjusted? sounds like they maybe off kilter.
1956 Chevy Bel Air 2 door 1956 Chevy 210 4 Door 1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD 1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E 1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD* GO GO!!! |
09-10-2016, 10:52 AM | #105 |
I moved the glass forward and backward and still binds.
09-10-2016, 02:45 PM | #106 |
I assume that the windows did not bind with the old manual regulator?
Is it the front edge of the window or the back that binds and by binding is the leading edge of the window digging into the felt in the channel or is it something else? I did this about two years ago and have had no issues at all.
1967 Red, C10 Short Bed 6.0L T5 5 speed 1967 Orange and Black C50 6.2 Detroit Diesel NV4500, 2 Ton Pickup 1972 White, Chevy Blazer 2WD 67 Dog house 5.3 4L65 2016 Power Tour LH 1955 Red-Cream, Chevrolet Nomad, restoration on hold 2004 Black, Corvette Z06 LS6 convertible (Rock solid Fun) 2011/2018 Power Tour |
09-10-2016, 04:45 PM | #107 |
Dave it seems to be the glass is digging into the felt on the vent window channel.
09-10-2016, 04:46 PM | #108 |
They were not binding with the manual regulators.
09-11-2016, 09:55 AM | #109 |
I should have asked this before but is the felt in the vent window channel the same or did you change it when you did the motor upgrade? Either way I think you may have a bind on the little short channel that is welded on the door. I know it's a pain to get at but it maybe gummed up or dirty not allowing the roller to move when it should. And I am sure you have attempted to adjust the rear guide but I can't believe that would cause the binding in the front. I guess you have run something along the vent window channel to see if there is something in the channel but I had to say it just in case.
Let us know if you fix this as I have seen it happen before but more with worn out channel material. Oh, does it happen right away when it first starts moving or later? Best of luck with this.
09-11-2016, 12:34 PM | #110 |
All the weatherstripping and felts are new except the beltlines. It wants to bind about a third of the way down. I did try to adjust the rear guide, to no avail. I put Sil-glide on the window channel runs and the vent channel felts and lubed the rollers also. Could be cheap LMC vent channel felts?
09-11-2016, 07:22 PM | #111 |
I have the LMC felts to but mine could not work much better. You got me with this one. Hopefully someone else will chime in with a plan for ya.
02-18-2018, 09:49 AM | #112 |
Great idea! You must have spent a lot of time to perfect this.
Thank you for sharing. |
02-18-2018, 02:06 PM | #113 |
Another project to add to my never ending list, thanks
03-17-2018, 09:11 PM | #114 |
I took a crack at this but didn't bother trying to modify the stock regulator to add a motor. I was going to but as I was searching for the motors I found that it was almost just as cheap to buy a complete regulator with motor from a late model truck. The regulators I ended up buying were only $23. The ebay listing said they were for a 99-00 escalade.
03-17-2018, 09:16 PM | #115 |
Trimmed the bracket that came with the Escalade regulator and grafted on the part of the stock bracket. Also swapped out the arm that pivots and the roller on the main arm of the Escalade regulator.
03-19-2018, 09:04 AM | #116 |
Subscribed
03-19-2018, 09:32 AM | #117 |
That was interesting.
03-19-2018, 10:00 AM | #118 |
Stankgtjk do you have anymore pictures that show how you did your conversion? Looks good, would like to see more.
Thank you Sir! |
04-14-2018, 01:53 PM | #119 |
I have looked closely as I could, over & over, but to clarify the gear, is it the OEM manual driven gear from the regulator as found on the OEM 67 - 72 C10? The teeth pattern is the only thing I can not verify. My window regulators are in the truck right now, so I can not see them or measure the tooth pattern.
From your description, it appears that it is the OEM driven gear, just turned 90 degrees...correct? It looks like it has one rivet retained to allow turning it the 90 degrees. Just wanted to make sure as this is sweet. Well done fabrication, fitment and function! Thanks very much, bonnieclyde100 |
04-14-2018, 03:18 PM | #120 |
It is the stock gear. You need a 9-tooth motor to mesh properly with the stock gear. And yes, you turn it 90 degrees and weld it fast.
04-15-2018, 09:51 AM | #121 |
Thank you, 70STOVEBOLT!
In Omaha, this Sunday AM, we have 2.5" of snow. I will check the tooth count on the motors I have, then look at the calendar for April the 15th for a few minutes! Last edited by LH Lead-Foot; 04-15-2018 at 12:29 PM. Reason: To add photo |
08-29-2018, 08:38 PM | #122 |
This is great, and at the top for new views of this great mod!
09-02-2018, 05:13 PM | #123 |
Hey all, Happy Labor Day, I’m hiding from my wife. I wanted to add something I ran across that MAY be a part of making our own power regulators a little easier. I found this on Amazon, it was about $15.00. The second pic has the dimensions noted out for your thought. I don’t quite know if this will work, but it does solve the issue of locating appropriate metal stock and drilling a clean hole. It’s made out of 18 gauge I believe and hopefully someone else will try to get our auto windows on the cheap, a little easier. I hope this is helpful. Let me know if you have any questions and I’ll post my trials, success or failure for all of us to learn from. Always think positive!!!
12-02-2018, 09:48 AM | #124 | |
12-02-2018, 10:01 AM | #125 |
You have to reinstall the spring? I don't recall seeing that in the steps. Any tips?
