#101 |
Re: The "Wrecker"
Also might be interested in seat belts for my 74 if you dont have plans for them .
#102 |
1 thing at a time is progress.
Re: The "Wrecker"
I can do that this weekend or you can come over and see it. The seatbelts aren't good.
Alan
Philippians 2:14-16 |
#103 |
Re: The "Wrecker"
John here's a shot of the bed. The deck measures 79.5X109
Alan
#104 |
Re: The "Wrecker"
Flatbed eng stamp code CKX. Shows to be a 72, 73, 76 camaro or corvette. 3970010 block cast #. Same block that's in my 65
Alan
#105 |
Re: The "Wrecker"
I was crawling around under the 85 flatbed and saw this brake valve. It looks like a sort of progressive proportioning valve. It has the hydraulic line running to it then feeds the rear brakes. It is mounted to the frame and has arm that goes to the axle.
Alan
#106 |
Re: The "Wrecker"
Alan, it is a load sensing valve. Keeps the back wheels from locking up when it's unloaded. Then after a while they go bad and people take them off.
72 GMC C2500 402/Th400 first truck (still have) 77 GMC C3500 CC dually Sold ![]() 70 C50 dump truck "Rusty" 87 K10 Suburban Sold 93 K2500 xcab 6.5TD 96 GMC K2500 Suburban 6.5 TD |
#107 |
Re: The "Wrecker"
Thank you sir.
Alan
#108 |
Re: The "Wrecker"
With Shannon's assistance, tree, chain and come-a-long we slid the flatbed off.
Alan
#109 |
Re: The "Wrecker"
Alan ,I have not forgotten about the bed ,been busy cutting and splitting firewood but I may have to leave my 1 ton on hold for a while til my budget recovers .
#110 |
Re: The "Wrecker"
Subscribed
#111 |
Re: The "Wrecker"
Cab is off donor.
Alan
#112 |
Re: The "Wrecker"
Let the mayhem begin.
#113 |
I'm just glad to be here!
Re: The "Wrecker"
Alan
I might have missed it, but what are your overall plans for the donor? Use the complete chassis and just swap bodies or something else?
Karl ![]() 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
#114 |
Re: The "Wrecker"
Maybe a little mayhem.
![]() I will be using everything except frame, body and bed.
Alan
#115 |
Re: The "Wrecker"
The 85 suspension is temporarily hung with a few bolts.
![]() Motor and trans waiting to go in once it gets some paint. ![]()
Alan
#116 |
Re: The "Wrecker"
Progress!
#117 |
Re: The "Wrecker"
Alan ,what is the reason for going with the later suspension ,disc brakes Im sure is one ,what else ?
#118 |
Re: The "Wrecker"
![]() That's pretty much it. I'm also going to use the hydroboost off the 85
Alan
#119 |
Re: The "Wrecker"
#120 |
Re: The "Wrecker"
I dropped the donor engine/trans in temporarily. I was thinking of making the hydraulic clutch work. The trans mounts are different. The late model trans mount is at tail shaft. The 68 trans mounts are in bell housing. I could have swapped the trans crossmember but then I will have the PTO clearance issue.
![]() I pulled the trans and clutch to inspect. The throw out bearing came out in 3 pieces (not good) and the pilot bearing is toast ![]() I wanted to use the later model engine mounts but it seems to raise the engine up and pushes it back and the trans won't bolt up. ![]() ![]() Left over parts ![]()
Alan
#121 |
Daring to be Different
Re: The "Wrecker"
Let the fun begins.
Dennis ![]() http://www.67-72chevytrucks.com/vboa...d.php?t=327644 KUSTOM RIDES FACE BOOK PAGE: https://www.facebook.com/groups/291198124258863/ 1965 C-10 Short Bed 350/700r4 2012 Silverado 1500 Crew Cab 2016 Honda Accord w/ 18" rims 2007 Honda Goldwing Trike w/ NAVI 2001 Yamaha Roadstar Indian look alike "Life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways, totally worn out, shouting "...WOW!...what an amazing ride!" Live Life Passionately!!! [/COLOR] ![]() I AM WE TODD IT, I AM SOFA KING WE TODD IT |
#122 |
Re: The "Wrecker"
totally diggin on seeing that 3970010 number.
#123 |
Re: The "Wrecker"
Due to life I'm going to stop this project and sell it off as a lot or part out.
Alan
#124 |
Re: The "Wrecker"
WOW Alan ,sorry to hear this ,hope all is well.
#125 |
Re: The "Wrecker"
Wow man, I saw this announcement on FB today, this is equally sad as it is sudden.
I hope all is well, in this day and age it is hard not to imagine the worst though..... Rock on buddy, what ever you turn your hand to next will be outstanding I am sure !! ![]()
Michael McMurphy My 66 Stepside My 64 Tow Truck My 66 Tempest Table Of Contents Added to Page1 |
