08-10-2014, 10:21 PM | #101 |
Re: 1953 Burb build
Very nice. I like you choice of wheels. They will tie in nicely with your color scheme. That white looks so sanitary.
Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
08-10-2014, 11:25 PM | #102 |
Re: 1953 Burb build
Looking sweeeet...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
08-11-2014, 01:55 PM | #103 |
Re: 1953 Burb build
Best part ...picked them up for $450
08-11-2014, 04:18 PM | #104 |
A320 Pilot/USAF Retired
Re: 1953 Burb build
Very nice! What wheels are those?
JJ My 1957 build: http://67-72chevytrucks.com/vboard/s...d.php?t=334552 http://www.trifive.com/forums/showthread.php?t=22037 Instagram - Chuckdriver57 |
08-11-2014, 09:15 PM | #105 |
Re: 1953 Burb build
08-12-2014, 06:38 PM | #106 |
Re: 1953 Burb build
They do look good! Same size on all four corners?
08-12-2014, 07:03 PM | #107 |
Re: 1953 Burb build
wheels yes tires no
8" wide up front 10" in the back |
08-16-2014, 08:53 AM | #108 |
Re: 1953 Burb build
Tremendous build.
What radiator are you running?
1950 GMC Suburban Carryall |
08-16-2014, 10:19 PM | #109 |
Re: 1953 Burb build
Got it from R&D fabrication. They are a vendor here. Very happy with it. Only issue I have is they used my good original rad as the mock up piece. They were to send it back and never did. Couple hundred bucks I could have sold it
08-18-2014, 09:38 AM | #110 |
Re: 1953 Burb build
Too bad about the radiator Iceburgh.
looks like you are going with a firewall mounted brake mc....what mounting are you using? thanks! |
08-18-2014, 04:24 PM | #111 |
Re: 1953 Burb build
Advanced Design
I used the CPP set up with discs all around Sorry, my attachments keep ending up sideways for some reason
08-19-2014, 09:20 PM | #112 |
Re: 1953 Burb build
I got mine from the bone yard from a 94 caprice along with the pedal assembly and the drive shaft.
Had to cut a little out of the drive shaft. All in $25 |
08-20-2014, 06:41 AM | #113 |
Re: 1953 Burb build
Oh yeah I like that.
10-07-2014, 08:49 AM | #114 |
Re: 1953 Burb build
Iceburgh,
I just found this build and congrats on a great build so far. I have a 49 burb w Camaro clip, 454 BB/TH400. I have been thinking LS in future but didn't think it would fit as BB w headers was a chore to shoe in. Your build is great blueprint to what needs to be done so will keep watching progress. Do you have any pics of the roll pan you built. Did you use a shrinker to make the curve fit or cut a top piece and bend to it? I've wanted to build one but don't on shrink / stretcher . Also you mentioned shims to help relieve twitched power steering please explain. I have a junkyard PS pump that I need to reduce pressure on. Thanks for the help |
10-07-2014, 08:47 PM | #115 |
Re: 1953 Burb build
The roll pan has been an experiment for sure. I don't have a Shriner but I do have a English wheel. The center section was made with that. The end with multiple bends worked out better for me using parts of a cab corner,hammer,English wheel and now plastic to smooth.
As far as the clip...I have a mustangII on this. Camaro clip would have been easier as far as fit....a/c would have been easier. I have a camaro clip on my truck and it was cheaper and easier for parts |
11-05-2014, 10:00 PM | #116 |
Re: 1953 Burb build
11-05-2014, 10:03 PM | #117 |
Re: 1953 Burb build
11-05-2014, 10:04 PM | #118 |
Re: 1953 Burb build
11-05-2014, 10:52 PM | #119 |
Re: 1953 Burb build
Your progress looks great...The emblem turned out nice as well.
Marc
11-05-2014, 11:11 PM | #120 |
Re: 1953 Burb build
Very nice progress and the emblem will look great on the truck. Who did the chrome?
11-05-2014, 11:15 PM | #121 |
Re: 1953 Burb build
http://www.carchrome.com/
Thanks....not bad $125 |
11-06-2014, 12:25 AM | #122 |
Re: 1953 Burb build
Iceburgh, moving right along and looking good...Jim
11-06-2014, 09:18 AM | #123 |
Re: 1953 Burb build
Beauty job on the emblem. Must feel good to have all that in final primer.
1952 Canadian Chevy 1300 C4 IFS & D44 IRS 5.3 HO L33 My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=632938 |
11-08-2014, 02:26 AM | #124 |
Re: 1953 Burb build
Coming along nicely!
http://67-72chevytrucks.com/vboard/s...d.php?t=592642 '48 Chev extended cab with attitude http://67-72chevytrucks.com/vboard/s...d.php?t=592769 My daughter's '46 International PU |
11-13-2014, 04:20 PM | #125 |
Re: 1953 Burb build
I still have the original here at the shop, in our prototype room. There is a note that the prototype was sent out and waiting for final comments. I looked back through our conversations and see that everything was resolved, but that wasn't relayed to the prototype guys (my fault). PM me with your address and we'll get it boxed up and out next week.
