Old 10-20-2014, 10:53 PM   #101
Bigru
Bigru's Avatar
Re: 66 c10 big window shortbed dropmember build up.
Freaking nice Bruh!!!
1965 Short Fleet
http://67-72chevytrucks.com/vboard/s...d.php?t=637478
1983 Short Fleet (Under construction for my 13 year old son)
2008 GMC Denali
2012 Harley Roadglide
Follow me on Instagram: Ru_django
Bigru is offline   Reply With Quote
Old 10-22-2014, 07:53 PM   #102
chevy6guy9
Thanks bigru.
Worked in the shop for. couple tonight. Got the floor hump and firewall cut out. Recieved my chunck of 2x2 aluminum block for the driveshaft bearing spacer today also.
chevy6guy9 is offline   Reply With Quote
Old 10-24-2014, 10:50 PM   #103
chevy6guy9
Recieved the new driveshaft today and man is it nice. The 2" spacer block I was planing on wasn't enough. So I called my neighbor at jist unlimited and see if he could give me a hand. We cut down an aluminum chunk to 2x3 1/4 X11 1/2". Nice to great friends and neighbors with machine shops. I'll drill the holes for it tomorrow on the drill press.
Old 10-24-2014, 10:51 PM   #104
chevy6guy9
New shaft in
Old 10-24-2014, 10:54 PM   #105
chevy6guy9
Top view of new carrier bearing spacer
Old 10-25-2014, 01:55 AM   #106
w00dst0ck
w00dst0ck's Avatar
Nice mod on the trans member. Mine is on the way along with bag stuff. I'll probably do the same. What diameter round stock did you weld in there?
w00dst0ck is offline   Reply With Quote
Old 10-25-2014, 07:39 AM   #107
chevy6guy9
I used a 4" tube 3/16 wall, was the same as the round bar on the trans. Allowed for up to 3" exhaust with room not to scorch the paint.
Old 12-07-2014, 06:22 PM   #108
chevy6guy9
It's been a little bit since I've had a chance to work on the truck.got the cab set back on the frame,trimmed and fitted the fenders and got those ready to rework.i wasn't impressed by the fit of the aftermarket header panel so I used one from the daily and I'll blast it and get it ready for work.mocked up the hood with the new gas assist strut hood hinges from porterbuilt, also recieved the rear notch cover with redesigned mount for panard bar. I also welded the high hump firewall section in and trimmed the floor, ready to drill the rear holes and nutcert the floor for a bolt in like factory.
In the next couple weeks I'll blow it all apart and send everything needed out to be powdercoated.its slowing down a bit on progress,time and energy to work on it is hard to come by.
Old 12-07-2014, 06:25 PM   #109
chevy6guy9
New hinges installed.
Old 12-07-2014, 06:27 PM   #110
chevy6guy9
High hump welded in
Old 12-08-2014, 09:12 AM   #111
Johnny_Lamebridge
Johnny_Lamebridge's Avatar
Mad skills Bro! You're doing some really nice work.
My 63 C10 SWB Fleetside (converted to BBW):
http://67-72chevytrucks.com/vboard/s...58#post6851558
@johnny_lamebridge on Instagram
Johnny_Lamebridge is offline   Reply With Quote
Old 12-08-2014, 10:45 AM   #112
chevy6guy9
Thanks Johnny.
Old 12-08-2014, 10:33 PM   #113
chevy6guy9
Put the bed together this eve. Light mockup to see what and where welding is needed.
Old 12-28-2014, 05:43 PM   #114
chevy6guy9
It's been a couple weeks but this past Monday I took of to spend some time with my son while he's out of school.. So after tearing the frame and all suspension down we took the parts to get powdercoated. Had to extend some arms on the rotisserie. Now I was able to finish welding the rockers in and start on the cab corners. Well after 5 hours and 5 diffrent section cuts and welding and grinding and grinding and welding. Have only one more cab corner left, hop to do that this week.then weld up all the holes in the firewall.
Old 12-28-2014, 05:45 PM   #115
chevy6guy9
Another angle of the drivers side.
Old 12-28-2014, 10:04 PM   #116
kidscustoms
Thumbs up Re: 66 c10 big window shortbed dropmember build up.
hey man what size and offset are you wheels ( and tire size ) the truck sits perfect .
kidscustoms is offline   Reply With Quote
Old 12-28-2014, 10:09 PM   #117
chevy6guy9
22x9" with a 5 1/2" offset I believe with 265/35 22's thanks kidscustoms.
Old 12-30-2014, 02:42 AM   #118
rwade
rwade's Avatar
Awesome build. I need to watch this one. Nice metal work
Wade
rwade is offline   Reply With Quote
Old 12-30-2014, 08:03 AM   #119
chevy6guy9
Wade
Thanks wade..
Old 01-03-2015, 09:13 AM   #120
chevy6guy9
Late Friday evening score. Factory rust free rad support, a pair of really nice inner fenders for the daily, a set of powder coated original front bumper brackets some radiator side shields powder coated, a delco radio and a new big back glass... Wish I had more cash. He had a California rust free hood and an extremely nice set of doors and a lot more that I really wanted. But ya can't have it all.
Old 01-04-2015, 06:15 PM   #121
chevy6guy9
Cut and disected the aftermarket passenger cab corner and finished fitting and welding it up.welded in new verticle rain gutters on both sides. Welded up holes in the floor today, the back cab wall where someone had a gun rack installed and 95% of all the holes in the firewall leaving the main ones for steering, brakes, throttle, speedometer and park brake holes.. not sure if I want to leave the factory antenna or shave it? Well I'll figure that out later.
Old 01-04-2015, 06:16 PM   #122
chevy6guy9
Drivers side firewall
Old 03-03-2015, 10:35 PM   #123
chevy6guy9
It's been a few months since I've last updated.. Well frame was completely striped down and sent of to powdercoater. Took about 3 weeks as they were extremely backed up due to some weather and christmas. Got it all back, did it a simple semigloss black. Had the rearend housing done also along with backing blates and brake drums.
Old 03-03-2015, 10:38 PM   #124
chevy6guy9
Had a good friend come over and setup the rearend with an eaton posi and 3.73 gears. Put a nice aluminum cover on it along with new 5 lug axles.
Old 03-03-2015, 10:41 PM   #125
chevy6guy9
Got the frame all together and started making brake lines and new brakes on.
