Old 10-11-2015, 02:15 PM   #101
66Submarine
66Submarine's Avatar
Re: Junkyard C30 stepside work truck "build"
On a positive note, I managed to find a tool box for a full-size stepside truck. Very nice to finally have one!
1965 C30 pickup 350/SM420/4.10's (daily driver) thread
1968 Impala 4 door sedan (future driver project) thread
66Submarine is offline   Reply With Quote
Old 10-11-2015, 03:43 PM   #102
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Sounds like valve train to me.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 10-11-2015, 04:22 PM   #103
66Submarine
Runs fine up high.
Old 10-11-2015, 04:25 PM   #104
deejaaa1
X2. had it happen on my 81.
also had a 307 in the 70 Chevelle. never missed a beat.
love your build. down to earth work truck. hope to have mine on the road one day.
also like the fender top work stations. white paint looks great.
Black 93 CCLB 3500 6.5 diesel, GV OD, TCI Ez-TCU controlled 4L80E, back on road 10/25/16 after sitting 4 years.
96 ECLB 2500, 6.5 diesel, auto, gone.
Originally Posted by gottattooz View Post
...68 Chevy Shortbed... guy clearcoated..and...threw glitter all over it...like he was feeding chickens!!!...
deejaaa1 is offline   Reply With Quote
Old 10-11-2015, 07:13 PM   #105
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Originally Posted by 66Submarine View Post
Runs fine up high.
All the more reason to think its valves. lol Idle fine....under load fine...but when cruising you get a little misfire....usually valves not seating perfectly. I've seen my fair share of rebuilt engines do that. My 305 V6 does that...under load its smooth and at idle its the same...but cruising along at 2000-2500 rpm there's a little pop here and there.......Valves.
Old 10-11-2015, 11:26 PM   #106
66Submarine
No valve job was done on the heads, the valves all went back where they came from, seats and valve faces showed good contact, and when I hooked up a vacuum gauge the vacuum at a fast idle was so steady you'd think the needle was painted on. No problems there.
It only runs smooth at idle and WOT. Part throttle light/moderate load is like you left spark plugs out. If you go WOT it picks up and smooths out.
Old 10-11-2015, 11:40 PM   #107
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Some guys were also saying they'll misfire like that because the engine is carbed and not injected and getting that "perfect" a/f ratio. Weather that is true or not I don't know....my BBC is carb and it doesn't miss a beat at Any rpm. lol
Old 10-11-2015, 11:42 PM   #108
66Submarine
Thanks. The tables on top of the fenders are certainly very handy.
Old 10-11-2015, 11:55 PM   #109
66Submarine
If you have a lean (or very rich) spot somewhere in the fuel curve, but with the tuning somewhere on the correct planet it shouldn't be any issue at all.
Old 10-15-2015, 09:32 PM   #110
66Submarine
After I posted this I took the still-warm carburetor off another truck and it ran fine. I then put the original Holley 600 off of this truck on that truck, which drove fine with it.
I put the carb back on this truck and it works fine now. Not sure what to make of it. I put the mechanical throttle linkage back on it and changed nothing else on the truck. The only thing I can come up with is that the mechanical linkage could be a ground to the carb/intake if the distributor somehow wasn't grounding, but I still don't get why it would run high up if that was it.
I'll have to investigate further and see if I can come up with anything. At least it works now...
Old 10-16-2015, 10:33 AM   #111
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
If it works ok you might wanna leave it alone. lol Eveytime I tried to investigate further I had problems again. lol
Old 10-16-2015, 07:21 PM   #112
jdl71
jdl71's Avatar
x2
Psalm 23
64 C10
66 K20
jdl71 is offline   Reply With Quote
Old 10-19-2015, 01:10 AM   #113
66Submarine
Old 10-19-2015, 01:12 AM   #114
66Submarine
Originally Posted by hotrod66 View Post
No longer looks like I belongs in a horror film I'm kinda sad now.but good job
Now it kind of sounds like it belongs in a horror movie...lol
Old 10-19-2015, 10:20 AM   #115
deejaaa1
sounds nice and strong. any hiccups after the "fix"?
Old 10-21-2015, 12:44 AM   #116
66Submarine
Hasn't done anything totally insane like that since. The carb needed/needs some tuning, but no crazy stuff.
General update copy/pasted from another thread FWIW:
It's the 307 out of my '68 Impala with 98,000 on it. I took it apart, cleaned it up, honed it, replaced all the bearings, new brass freeze plugs, moly rings, steel shim head gaskets for correct quench distance, double roller timing chain (to replace the BS nylon one with the nylon all shucked off), new oil pump, quickly smoothed the heads up a little with a die grinder (made me feel better?), and used a mild Elgin E860SM GM blueprint HO 305 cam (202/207@.050, 114LSA, .404/.414).
The Holley 600 and Performer RPM intake were already on it when I got the car, and some short GM chrome valve covers I had and a couple cans of Duplicolor DE1607 made it look less hideous. I used a HEI I had with some light advance springs and ended up with 20º inital for 36º total + 14º from an "AR-12" vacuum advance can.
It's just a very mild and inexpensive "build" that runs nice and should last a long time. It makes 16.5" of vacuum at idle and I haven't noticed any detonation on 87 octane.
The exhaust is some old 1.5" truck headers and dual 2.5" pipes (eventual BBC power?) kicked out in front of the rear tires with Summit turbo mufflers. So far no one has said it's too quiet...
It also did this the other day warming up:
Apparently the factory carb jetting was way too lean (it hesitated pretty badly and the plugs looked like they were never ran in anything). Swapping the 65's out for some 68's yesterday made it run much better (still need to check what the WOT jetting is like). I also swapped the orange accelerator pump cam and 31 nozzle out for the smaller white cam and a 25 nozzle.
Old 10-21-2015, 10:20 AM   #117
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
The lope sounded kinda cool. lol
Old 11-28-2015, 11:12 PM   #118
66Submarine
I bought a 4.10 SF 9.5" 14 bolt with a Gov-Bomb out of a '98 2500 this evening for $75. Missing one brake drum, but it seems to be in very good shape. Being from a 2wd 88-98 it's about 65" WMS-WMS like the OE Eaton, so my current tire and wheel combo still works.
(My narrow C&C FF 10.5" 14 bolt is currently still trapped under a motorhome, so I figured this one should fit the bill fine for now. I need to finally get around to swapping stuff...)
Old 11-29-2015, 07:39 AM   #119
Eric15chevys
Eric15chevys's Avatar
Nice score on the rear end. I like that axle. I have a 94 C2500 2wd as my daily driver. I would love the 4.10 gears in it. It has 3.08 in it right now.
84 GMC One ton 4x4 454 4 speed
62 Chevy C10 short fleet
plus about 13 previous gm trucks
from 1960 to 2000
Eric15chevys is offline   Reply With Quote
Old 09-19-2016, 02:09 PM   #120
66Submarine
Might as well make an update or two. I finally replaced the rear end a while back (well, six months is a while)...and not a mile too soon for my taste...lol. IIRC I moved the new rear end back 1" via another hole in the perches so I didn't have to mess with the driveshaft. The width was fine, no other problems.
Old 09-19-2016, 02:19 PM   #121
66Submarine
Also finally wore out the remold 235/85's And got some new ones. Well...more "new" remolds, anyway...
265/75R16 "Claw" from Treadwright. The old ones got slid quite a bit and still went 40,000 miles, so I can't complain much. Used another set of 16x6.5 wheels; wouldn't really want to go any wider, but I think they work fine. I'd still like a wider wheel for better stability, but those aren't free like these were...sometime in the future. Probably should attack the fenders with a hammer a little bit, too. Running around 45PSI now with no load, seems to be good.
Old 09-19-2016, 02:30 PM   #122
66Submarine
And I decided I wanted to make some changes to the 307, so I stuck the 350 I put together for my Impala in there yesterday to run it a while. Basic 350 .030 short block with forged flat top pistons, moly rings, Vortec heads, steel shim head gaskets for correct quench distance, $99 Performer RPM copy intake from Competition Products, 214/224@.050 white box cam from Summit (1103). Basically the CT350 350HP/390TQ GM crate circle track engine with another point of compression. Inexpensive combo that should last a long time and run well for a daily driver.
Old 09-19-2016, 02:36 PM   #123
66Submarine
Ended up with my wiring stuff all an hour away (oops), so I did some Roadkill engineering and used my pocket knife, tape, cable ties, and some wires I got out of a garbage can to extended the alternator harness using lineman's splices. Unfortunately, it still might be better than any PO wiring I've found...lol
Old 09-19-2016, 03:35 PM   #124
Deer_hunter_088
Deer_hunter_088's Avatar
subbed
1994 k1500, Oldredz71(ext shorty 4x4 6 in lift)
1998 S10ZR2
2005 Silverado 2500hd(tow pig)
Made in the USA, just like my trucks
Deer_hunter_088 is offline   Reply With Quote
Old 09-19-2016, 10:37 PM   #125
66Submarine
Clip of new 350 running:
