Old 04-15-2017, 10:12 PM   #101
Dads79GMC
Dads79GMC's Avatar
Re: Dad's 1979 GMC Heavy Half Transformation
Today I installed my Built By Brooks LWB to SWB kit on Dads frame that has been sitting in the barn for about ten years. Here is where I got the idea:
http://67-72chevytrucks.com/vboard/s...d.php?t=717809
I performed the install basically by myself until the very end when I had one of the boys help me slide it together, which took a couple attempts and some additional grinding on the original cut. Yes, had to slide it apart and grind about a 1/16 off the forward cut, then everything lined up.
I plan on having a buddy of mine weld around the outer bracket. I left the bolts loose for for now and will tighten prior to welding when I'm sure everything is square, which it pretty much is now. Once I get the outer bracket welded, I'll take some of the bolts and the inner bracket out and weld the original cut, grind down and reinstall the inner plate and bolts. Will also weld in the inner bracket too. I believe it'll hold!
Enjoy the pictures. Mike
Instagram @HomeBuiltC10s
Dads 79 GMC Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=642929
1978 Silverado Build
http://67-72chevytrucks.com/vboard/s...d.php?t=756016
Dads79GMC is offline   Reply With Quote
Old 04-15-2017, 10:15 PM   #102
Dads79GMC
Dads79GMC's Avatar
Additional pictures.
Old 04-15-2017, 10:18 PM   #103
Dads79GMC
Dads79GMC's Avatar
And more!
Old 04-15-2017, 10:27 PM   #104
Jaysonb
Jaysonb's Avatar
Looks good Mike! There's no turning back now!
Jaysonb is offline   Reply With Quote
Old 04-15-2017, 10:28 PM   #105
Dads79GMC
Dads79GMC's Avatar
Nope! Now I have two SWBs!!
Old 04-15-2017, 10:36 PM   #106
Dads79GMC
Dads79GMC's Avatar
Everything under the other frame will go under this frame, which is where the pieces came from to begin with. Haven't decided on the LS/4l60E, might put Dad's original 350/350 back on the original frame. Gonna have to start another build thread at some point on the other truck.
Old 04-15-2017, 10:41 PM   #107
OutlawDrifter
I've always been a big fan of the 327/350hp cam for a nice streetable setup in a 350. I had one in a 67 swb with a 283/PG that ran awesome, also put one in a 305 I drove daily in a 78 El Camino.
1991 Z/28, 6.0L/T56
Instagram @aceshighspeedshop
Old 04-17-2017, 09:19 PM   #108
Dads79GMC
Dads79GMC's Avatar
This retirement life has me pretty productive around the house and on the truck(s).
Noticed that my back crossmember was bent inward and suddenly remembered that I had purchased a crossmember from "thinair" in Omaha some time ago to replace it if I ever planned to use the frame. It is truly remarkable how these frames use common holes. I figured the one that I purchased would go in the same holes vacated by the old bent crossmember; nope! There are another set of holes, six inches toward the front that the new crossmember will go into. It's also nice to have another SWB factory frame laying around to compare cross-measurements with etc.
Does anyone know if I have to move the spare tire piece forward (toward front of truck) six inches as well if I plan to use it?
Thanks Mike
Old 04-19-2017, 08:31 PM   #109
Dads79GMC
Dads79GMC's Avatar
Had a couple hours this afternoon to wrap-up the LWB to SWB kit on Dad's frame. Kind of a pain getting the replacement rear crossmember holes to line up by yourself, but an old jack, a ratchet trap, a couple solid blocks and a brick came in handy. Time to take it to the welder!!! Mike
Old 04-26-2017, 08:18 PM   #110
Dads79GMC
Dads79GMC's Avatar
Today I decided to attempt to recreate one of the wood bed pieces. Of course I picked the most difficult piece to take the dive on. So, I had a scrap piece of 16ga sheetmetal, kind of rough, that I found in the barn last week; thought it would be a good piece to practice on. Before beginning, I measured the thickness of the original and it was pretty much 16ga - had to find the cleanest piece to measure.
Pictures:
1. Piece to be recreated laying on sheetmetal.
2. Traced piece laying on garage floor.
3. After metal brake, laying next to original piece (neighbor has one).
4. After rolling the bead.
More to follow:
Old 04-26-2017, 08:20 PM   #111
Dads79GMC
Dads79GMC's Avatar
Continued:
5. After welding inside corner piece.
6. Falling in line. Picture looks distorted??
7. Checking Fitment on inner fender.
Seven more pieces to go.
Gotta emboss the end now?????
Mike
Old 04-27-2017, 09:12 PM   #112
Dads79GMC
Dads79GMC's Avatar
Creating the right rear piece that has been shortened six inches:
Pictures:
1 Original Cut Down 6"
2 Template
3 Template 2
4 Rough Piece, had to hand bend the bolting flanges
5 First Test fit
In pic #2, you can see that there's a tab that makes up the thickness of the wood. At some point i'll have to create all of them, I'm just waiting to do that until all the pieces are made and I have some wood to test fit with.
Old 04-27-2017, 09:18 PM   #113
Dads79GMC
Dads79GMC's Avatar
Pictures:
6 Looks to be short
7 Yep, it's short; had to do some extending; cut and weld scrap piece in extending the bead
8 Fits now
9 Better, second fit after welding in piece and building up the weld by bed post
10 Screwed to bed side after drilling holes
Six to go!!
Thanks Mike
Old 04-27-2017, 09:38 PM   #114
Dads79GMC
Dads79GMC's Avatar
In order for the bead to work, you have to leave some excess material to the outside in order to pass through the dies. After rolling the bead, I cut off the excess then smooth it out.
Mike
Old 04-27-2017, 10:24 PM   #115
81k
81k's Avatar
Those are some fine fabrication skills you are showing off. Great work!
81 GMC K2500/C6P
81k is offline   Reply With Quote
Old 04-28-2017, 12:05 AM   #116
evan
evan's Avatar
Cool project. I'm in for updates.
Evan B.
evan is offline   Reply With Quote
Old 04-28-2017, 08:52 AM   #117
Dads79GMC
Dads79GMC's Avatar
Thanks 81k and even.
Old 04-28-2017, 12:55 PM   #118
daddyjeep
daddyjeep's Avatar
Very nice work. It sure is nice to have the proper tools.
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939
87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html
04 1500 crew cab
http://67-72chevytrucks.com/vboard/s...d.php?t=786514
daddyjeep is offline   Reply With Quote
Old 04-28-2017, 04:15 PM   #119
Dads79GMC
Dads79GMC's Avatar
Thanks daddyjeep! On the second piece I made, the neighbor was gone and I resorted to bending over the piece myself with a plain old hammer and a piece of steel. May not be able to rely on the neighbors hydraulic brake; he tends to be gone a lot seeing grandkids and other activities. The only real tool I have is a cheap bead roller from Eastwood ($139) that isn't suppose to do 16ga, but I'm pushing it through OK, for now. Six pieces to go, hopefully I doesn't fail! All I use for cutting the sheetmetal is normal DeWalt Jig Saw, or cut-off disc on a grinder. Nothing special.
Mike
Old 04-29-2017, 06:40 PM   #120
Dads79GMC
Dads79GMC's Avatar
Three more pieces complete. I have the two driver side inner fender pieces and one passenger inner fender piece to complete. Then the detail work. All of the straight piece have 3/4" risers that need to be welded in to compensate for the wood and will be drilled for attachment to the x-members. I did order some strips (whatever they're called) and hardware for the SWB stepside. Haven't decided on what wood to use. May go with hickory??? Thanks Mike
Pictures:
1. Three templates laid out after cutting (jigsaw)
2. Bead Roller (Eastwood). Had to reinforce to eliminate deflection or whatever you call it.
3. Working the back driver side piece
4. Same
5. Need to trim the piece by the bead then DA sand
Old 04-29-2017, 06:46 PM   #121
Dads79GMC
Dads79GMC's Avatar
Pictures:
1. Front passenger side piece
2. Front driver side piece
3. Rear driver side piece
4. Started work on the rise in the floor for gas tank filler thingy. That shouldn't be too difficult?????
Gonna have to go out some larger sheet metal piece(s) to do the curved pieces around the inner fender(s).
Thanks Mike
Old 05-03-2017, 09:43 AM   #122
Dads79GMC
Dads79GMC's Avatar
Shifted some things around the garage and brought in the Dad's frame from the barn. Going to weld the LWB to SWB kit tonight and hopefully get it cleaned so that I can paint it this weekend. Plan is to then, as mentioned before, transition everything over to Dad's frame from which it came from originally. The cab in the picture is the 85 I picked up in November that will one day go one on the frame to the left, that's for another build thread.
Also ordered some SWB step-side wood bed strips to see how they'd work out on the floor I'm working on. Six came in the pack. kind of relieved that all the holes lined up and they'll work just fine. Nothing fancy, just steel strips and bolts that'll end up being the color of the truck.
Thanks Mike
Pictures:
1. Dad's frame moved into the garage
2-4. Test fitting bed strips
Old 05-03-2017, 09:46 AM   #123
Dads79GMC
Dads79GMC's Avatar
Pictures:
1. Bed temporarily moved other frame to make room for the Dad's frame
2. A look inside bed
Old 05-03-2017, 10:44 AM   #124
Jaysonb
Jaysonb's Avatar
That's turning out awesome Mike!!
Old 05-03-2017, 12:44 PM   #125
Dads79GMC
Dads79GMC's Avatar
Thanks Jayson! One bad thing about retirement; honey-do list is must longer than when you have an excuse Been putting up new trim and painting inside the house, then sneaking outside during this evening to work on whatever my ADD wants to work on.
