Old 10-06-2015, 11:52 AM   #101
Blown06
Blown06's Avatar
Re: Project: "ResuWrecktion" '71 Custom Deluxe C-10
Originally Posted by WarMonger View Post
frame is great looking. Your work is top notch
Thank you, I'm trying.
Most importantly, I'm having a blast with it.
Me: Jarrod
My project: http://www.67-72chevytrucks.com/vboa...d.php?t=646563
Blown06 is offline   Reply With Quote
Old 10-06-2015, 04:53 PM   #102
Xeen
Xeen's Avatar
I like that you are fearless and just go for it no matter how extensive the reconstruction is.
Man you lay down a nice weld.
Please call me Brian.
Check out My 1972 SWB Fleetside 5.3L Vortec Restomod Build
Xeen is offline   Reply With Quote
Old 10-06-2015, 10:37 PM   #103
Blown06
Blown06's Avatar
Haha thanks Brian, I'm not scared that's for sure. Sometimes I wonder what I'm doing but I just keep at it. It's therapy and this old truck has been with me for a very long time. Thanks for the compliment
Me: Jarrod
Old 10-09-2015, 10:00 PM   #104
Blown06
Blown06's Avatar
Ordered some shock mount bolts from Summit, pretty beefy studs and less than $12 each. They have a 9/16" mounting bolt so I drilled out the 1/2" holes in the lower control arms and shock re-locators.
Picture with part number for anybody that's needing to get some.
Checked the mounting position.
That factory shock mount location with the bump had to go, so I cut it out and welded a plate in place.
I welded the bracket on instead of bolting it.
I have a few of the fittings I need to start running the air lines so I bent the tube for the bag. Going with aluminum line and AN fittings, I have some bulkhead 90's in transit. Cheapest place I found online was www.anplumbing.com if anybody knows of a cheaper place feel free to let me know. Jeg's and Summit were both about 15% higher than this place.
That's all I've gotten done hopefully more in the next few days.
Me: Jarrod
Old 10-11-2015, 09:44 PM   #105
Blown06
Blown06's Avatar
Worked on the driver side shock mount, cut out the factory bump and welded the Porterbuilt bracket in place.
My sway bar bushings arrived so I mounted the sway bar up and slapped the 15" rally wheels on it to move it around.
Made some temporary air lines with ball valves and rolled it out of the garage. It's a small accomplishment but it sure felt good to see it together.
Got the frame turned around and rolled back inside, time to start the rear install.
Me: Jarrod
Old 10-11-2015, 10:18 PM   #106
Pinky6872
Your build looks awesome! I've done/am doing a lot of the same work to my truck. Keep up the good work
My Dropmember Equipped Build
Instagram @chrispinkosky
Pinky6872 is offline   Reply With Quote
Old 10-11-2015, 10:23 PM   #107
Blown06
Blown06's Avatar
Thanks. Yeah I've gone through your build thread and really liked a lot of the things you're doing so I'm trying to do a few of them on my build. You do some nice work too.
Me: Jarrod
Old 10-12-2015, 05:19 AM   #108
highanglehell
Love it fallowing
highanglehell is offline   Reply With Quote
Old 10-12-2015, 07:15 PM   #109
Blown06
Blown06's Avatar
Originally Posted by highanglehell View Post
Love it fallowing
Thanks and welcome aboard.
Went to the local metal shop today and got a couple of sticks of 2x2 tubing. Fired off a couple of emails to Porterbuilt with a couple of questions and got a reply within a few minutes confirming what I was thinking. With that boost in confidence I began jigging up the frame in my garage floor. Got it all level and started framing it out to hopefully keep everything in the correct place when I cut it for the huge notch.
Had the latest C10 Talk podcast on repeat listening to the interview with Josh.
Pretty happy with the progress.
Me: Jarrod
Old 10-13-2015, 11:47 PM   #110
Blown06
Blown06's Avatar
We've all heard of that point of no return, well I crossed it today. Measure, measure, check, grind, cut and tack. That's pretty much how my day went, there's still a ton to do but I'm up for the challenge.
Notches are tacked in and the bridge is bolted up. Put a brace under the notches to keep things in place.
Now I get to start working the frame rails in and getting the transition pieces in place and boxed in.
Me: Jarrod
Old 10-14-2015, 03:05 PM   #111
Blown06
Blown06's Avatar
Half of the rear notch is tacked in place. I just didn't like the looks of how the frame rail has that factory sweep outward and the Porterbuilt 24 X 15 kit is obviously tucked in for wheel clearance. A few installs that I've seen online, just angled the transition pieces back in toward the notches. So visually you still see the slight bulge outward then tucking back in, I wanted a more natural look, like the notch was meant to be there. Not an afterthought...
So here's the misalignment before I tweaked it in.
After pie cutting the upper and lower flanges and moving the rail in.
Me: Jarrod
Old 10-14-2015, 11:28 PM   #112
tucker69
tucker69's Avatar
Thumbs up Re: Project: "ResuWrecktion" '71 Custom Deluxe C-10
Hey man, thought i would take a peak at your build since you have been watching my posts. That PB stuff is SEXY!!! Keep up the good work. Looks like you got all the skills & tools you need. If you change something you don't like..... change it. Got a couple questions!!
Where is Burnet, Tx ?
Have you bolted your hood back on since installing those hood hinges, if so do you like em?
Are you planning on going to the DFW swap meet next weekend?
Thanks and keep up good work....Casey
P.S. as soon as i figure out how???? i'll be following along for your build
tucker69 is offline   Reply With Quote
Old 10-15-2015, 01:11 AM   #113
Blown06
Blown06's Avatar
Thanks Casey.
Burnet, Tx is about an hour northwest of Austin, it's a little town with a couple of stop lights.
No I haven't bolted the hood on yet. I got hung up with front fenders on back order for so long that I just tore the whole truck apart. I'm still not sure that the hood is even straight after it was wrecked. There is some minor rust in the support channels too, so I haven't even figured that situation out yet. I may even just go with a cowl hood???
I won't make it to that one but I will be going to the one in Conroe in November. I work in Beaumont during the week so Conroe is on my way home Fridays.
On the top header of the thread there is a little thing titled "Thread Tool", clip the little arrow at the side of that. It will bring up a drop down menu and you can choose to "Subscribe to thread". You may already be subscribed to any thread you post in. If you get an email notifying you of my reply, then you're all set and will get an email each time an update is posted here.
Thanks for the kind words.
Me: Jarrod
Old 10-15-2015, 07:56 AM   #114
mcbassin
Still Learning
mcbassin's Avatar
Very nice progress on the chassis!
mcbassin is offline   Reply With Quote
Old 10-15-2015, 08:45 AM   #115
boostedc10
boostedc10's Avatar
Hey Blown06 any chance you still have the shock locators you cut out? I need one for my passenger side? Message me if you do, it would save me a ton of time!
Brandon
Instagram: DRVFSTR
Current Project: Beatrix - 1967 SWB LQ4/78mm Turbo/4L80e/ on bags
Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=634691
boostedc10 is offline   Reply With Quote
Old 10-15-2015, 10:05 AM   #116
Blown06
Blown06's Avatar
Thank you.
I'll check when I get home Friday night, I'm pretty sure I tossed them already but there's a chance they are still in a scrap pile. If I have them I'll PM you then.
Me: Jarrod
Old 10-15-2015, 10:10 AM   #117
boostedc10
boostedc10's Avatar
Thanks I really appreciate it.
Brandon
Instagram: DRVFSTR
Old 10-15-2015, 12:04 PM   #118
tucker69
tucker69's Avatar
Thanks, I am kinda learning the in & outs... i'll get it someday. good work on your truck.
Old 10-18-2015, 12:59 AM   #119
Blown06
Blown06's Avatar
boostedc10, I looked for those shock mount cutouts but I had already tossed them out, sorry.
Got an order of AN fittings, had a plastic organizer so I dumped them in there so hopefully I don't lose any of them. We all know they aren't cheap..
Got home Friday night and started welding the notch, my wife wanted a couple of action shots. lol
Started working in the passenger side frame rail and transition piece. You can see how the factory rail kicks out.
Pie cut on the upper and lower flange.
Pushed the rail over and put the transition piece on and clamped everything in place.
Now I have many hours of welding to do.
Working on the boxing plate on the driver side.
Still have a ton of welding but it's looking good, this Portebuilt stuff is well worth the money.
Me: Jarrod
Old 10-18-2015, 07:26 AM   #120
boostedc10
boostedc10's Avatar
No worries, thanks for looking though. Nice progress on your frame too!
Brandon
Instagram: DRVFSTR
Old 10-21-2015, 09:05 AM   #121
Hart_Rod
Hart_Rod's Avatar
The transitions came out really Nice! Can't believe I missed this one, !
Hart_Rod is offline   Reply With Quote
Old 10-21-2015, 09:49 AM   #122
Hart_Rod
Hart_Rod's Avatar
Hey when you get ready to finish your bed, take a look at my rear wheel tubs. I've been working on a new mold for some super large ChubTubz. These are designed to cover 24x15's. Let me know what you think.
Old 10-21-2015, 09:55 AM   #123
Blown06
Blown06's Avatar
Thanks and yes I definitely plan to get with you on the chub Tubz. I widened a bunch of these many years ago for fat back tires but have never widened and shortened any. I know how much time the chub Tubz will save me. Haha you'll be getting a call when I get to that point believe me.
Me: Jarrod
Old 10-21-2015, 10:09 AM   #124
Hart_Rod
Hart_Rod's Avatar
Sound good!
Old 10-26-2015, 08:58 PM   #125
Blown06
Blown06's Avatar
Well the pics don't show the amount of worked that have gone into it to get to this point but I'm gonna throw them on here. Nothing but welding and grinding this weekend. All of the notch pieces are in place just have a bunch of grinding to do to smooth out every weld.
Me: Jarrod
az pro, baer, cpp, porterbuilt, porterbuilt 24x15
