Old 04-07-2015, 12:38 PM   #101
99 to Life
99 to Life's Avatar
Re: My 52 GMC Build
I'm assuming your running 2600lb bags up front? 150 psi seems high, even with that weight you have up front. You could add a bag cup to make up the height and run a lower psi. easy fix if you feel its too ruff down the road.
looking good out in the light for sure. I like how the dually aspect is almost hidden.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 04-07-2015, 01:04 PM   #102
Advanced Design
Advanced Design's Avatar
Re: My 52 GMC Build
Very cool build Lower50's. Truck looks really good sitting out!
Advanced Design is offline   Reply With Quote
Old 04-07-2015, 06:08 PM   #103
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Re: My 52 GMC Build
Your bag pressures do seem really high. How big of a bag do you have in there?
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 04-07-2015, 10:45 PM   #104
yawdie1
yawdie1's Avatar
Re: My 52 GMC Build
Nice!
1950 chevy PU work in progress.
yawdie1 is offline   Reply With Quote
Old 04-07-2015, 11:56 PM   #105
lower50's
lower50's's Avatar
Re: My 52 GMC Build
Thanks guys. I have 2600lb or 6" bags up front and 3055lb or 7" bags in the back. I wasn't really concerned about the pressure I figure 120psi will be my norm. At that pressure my front arms are close to level. But I do have some ideas if it rides like crap. What are typical air pressures in other trucks?
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 04-08-2015, 12:06 PM   #106
99 to Life
99 to Life's Avatar
Re: My 52 GMC Build
I wish I could be of more help there. As my first bagged ride still hasn't hit the road (though very very soon it will) I'm running sleeves in the back so its gonna differ from your monsters. I feel 2600lb bag up front and sleeves is about 60/40 front to back. I just never hear of guys running over 100psi up front but you might find some info out there where guys are. If you just put a put a cup in there, I think that would help you out alot. I'm running cups top and bottom. I had to angle cut my bottom cup to work with my stock lower control arm. which you prolly won't need to do with yours.
Old 04-08-2015, 04:48 PM   #107
Dieselwrencher
Re: My 52 GMC Build
Where are you getting your pressure reading from?
Ryan
Old 04-09-2015, 11:46 PM   #108
lower50's
lower50's's Avatar
Re: My 52 GMC Build
Thanks 99. At 60 psi mine is not even off the ground, but the way I figure it. A 350 is about 550lb dry, my motor is about 1000lb dry. So if your running 60psi I'll need to run about 120psi because I have about double the weight. It all comes down to pounds per square inch, a bigger air bag would give more lift for the same psi. Ride height on my rear bags is around 25psi.
1951 MG TD
Old 04-09-2015, 11:49 PM   #109
lower50's
lower50's's Avatar
Re: My 52 GMC Build
The gauges are plumed into the 1/4" npt gauge ports on my accuair valve
1951 MG TD
Old 04-14-2015, 03:31 PM   #110
lower50's
lower50's's Avatar
Re: My 52 GMC Build
Got some stuff I ordered end of January. My GF's parents brought it home for me last Friday from the states.
S10 big brake conversion kit. It feels like Christmas.
My inter-cooler.
1951 MG TD
Old 04-14-2015, 04:24 PM   #111
ptc
ptc's Avatar
Re: My 52 GMC Build
Originally Posted by lower50's View Post
I'm thinking of running the 16" rims that are on it for a while. I'm not putting spacers because I want to keep all that weight under the bearings. Going to get 245 or 255/60/16 tires before I drive it. There is 235/60/16 on it now.
You should find some cool looking old school dually front wheels.... dont need to be chrome or anything.... just 16.5" phat wheels!
My Build: 57 Chevy Pro-Street
ptc is offline   Reply With Quote
Old 04-14-2015, 09:23 PM   #112
lower50's
lower50's's Avatar
Re: My 52 GMC Build
Maybe I'll get some 16" steel rims and dually hubcaps. Never thought of that option.
1951 MG TD
Old 04-15-2015, 06:44 PM   #113
lower50's
lower50's's Avatar
Re: My 52 GMC Build
I put the order in to local rad shop for my custom radiator today. The core size will be 21"X 24" 4 rows thick (about 3 1/4") That should take care of things. They said it should take about 2 weeks.
1951 MG TD
Old 04-15-2015, 10:49 PM   #114
CHIZZLER
SAVING ONE TRUCK AT A TIME
CHIZZLER's Avatar
Re: My 52 GMC Build
Really diggin your build.
53-suburban (99% done)
40-pick up (99.9% done)
12-cc lb dually D-max (dd)
61-crew cab D-max
"PAY LESS FOR WHAT YOU NEED PAY MORE FOR WHAT YOU WANT"
53 BURBAN BARN FIND:http://67-72chevytrucks.com/vboard/s...d.php?t=404091
1940 PROJECT MOON SHINE:http://67-72chevytrucks.com/vboard/s...d.php?t=551088
1961 CREW MAX: http://67-72chevytrucks.com/vboard/s....php?p=6957999
CHIZZLER is offline   Reply With Quote
Old 04-17-2015, 05:28 PM   #115
lower50's
lower50's's Avatar
Re: My 52 GMC Build
Got my locker installed in the diff today. Also worked on some air leaks on the bag side.
Also here is a size comparison from my Dana 44 out of my jeep. To my Dana 70HD in my GMC. Spider gears, carrier bearings, cross shaft is about 1.25" in dia.
1951 MG TD
Old 04-17-2015, 10:35 PM   #116
99 to Life
99 to Life's Avatar
Re: My 52 GMC Build
that looks stout, wish I could man up and get a locker. I'm siiiiick of one wheel drive in every vehicle I own.
Old 04-20-2015, 02:13 PM   #117
Dieselwrencher
Re: My 52 GMC Build
Nice parts in the D70!
Ryan
Old 04-22-2015, 07:37 AM   #118
lower50's
lower50's's Avatar
Re: My 52 GMC Build
Well last night I just needed to fabricate something, so. I built my trailer hitch. Fit exactly where I wanted it to. 1/4" X 2.5" gussets and 2"X 2"- 1/4" wall tube.
I have a 1/8" gap on bottom of tailgate to receiver. Welded tube and gussets to frame.
1951 MG TD
Old 04-22-2015, 11:17 AM   #119
99 to Life
99 to Life's Avatar
Re: My 52 GMC Build
nice job. I need to get my hitch on. they are so nice to have. plus i like to run the license plate right between the hitch and tailgate. Though about building one rather than buy. Sux for me cause my gas tank is already in, so don't really want to weld around it. might just have to make it bolt on, which will prolly suck too. I may just drop the tank and weld one in. your gonna be able to pull a house!
Old 04-22-2015, 11:35 AM   #120
Dieselwrencher
Re: My 52 GMC Build
Nice work on the hitch!
Ryan
Old 04-22-2015, 11:45 AM   #121
lower50's
lower50's's Avatar
Re: My 52 GMC Build
Thanks guys!! Yes 99 I can't have a dually that can't pull.
1951 MG TD
Old 04-23-2015, 08:49 AM   #122
lower50's
lower50's's Avatar
Re: My 52 GMC Build
I got the rear bumper tacked in place. It is tucked in and just below trailer hitch. It is 3.5" off the ground when aired out. I have to put the truck on hold for about a week or so. Have to get my Jeep ready for a offroading weekend in the bush up north May 1st.
This is from our last trip:
1951 MG TD
Old 04-23-2015, 09:09 PM   #123
Dieselwrencher
Re: My 52 GMC Build
That looks like a sweet Jeep! Good luck with it!
Ryan
Old 04-27-2015, 11:53 PM   #124
lower50's
lower50's's Avatar
Re: My 52 GMC Build
A little update. I picked up my radiator today.
1951 MG TD
Old 04-29-2015, 02:08 AM   #125
lower50's
lower50's's Avatar
Re: My 52 GMC Build
Found a cool article about copper vs aluminum radiators.
http://www.hotrod.com/how-to/engine/...l/#.VUBXomvQKE
1951 MG TD
bagged, build, diesel, gmc, hot rod
